Question about Health-O-Meter Health O Meter Adapter for Remote Display Scales
We have a Doctor's Scale Model 230PB with a broken part. Where can we get a replacement?
Taylor precision digital diet scale model 1250-49 displays "88888",theno "UNSt" , even when level and solid platform
The display or internal electronics might be broken. Firstly, try removing and replace the batteries and cleaning the scale. If that doesn't work you may want to contact the manufactuters.
Nov 04, 2016 | Taylor Health & Beauty
Just replaced battery in my Conair WW87 scale and the numbers now do not display fully. Broken up
Recheck the battery connections and check the batteries, this type of display most times means low battery voltage.
Sep 12, 2016 | Conair Weight Watchers WW-87 Body Fat...
Second request re: taylor lithium electronic scale model 7000 not working after changing battery twice. Yes interested correctly
On Amazon this scale got 24% 5 star and 43% 1 star rating.
In many cases it quit working or broke in some way.
"I owned this model for 1 year before it gave me the "batt" signal. after I spent another $7 on new lithium batteries, it turned out the scale was broken. looking on the web, I discovered lots of other stories like mine. advice: find another brand."
Aug 03, 2016 | Taylor Health & Beauty
Undefined
Most likely the old battery was so low the scale was reading low.
Oct 13, 2014 | Health & Beauty
How can i make sure my health o meter scale gives accurate weight measurement
Call Health o meter Professional's customer service department at 800-815-6615
Sep 13, 2011 | Health-O-Meter Health o meter 400EXP...
Scale is not weighing correctly. Weighs correct
The scale must be on a hard, level surface. Make sure there is absolutely no dirt on any of the pivot points. Calibrate it with a KNOWN 25 pound weight.
Jan 04, 2010 | Health-O-Meter Health o meter 402KLWH...
Can I adjust the weight on the scales to match my doctors scales. Mine weight 6lbs less.
Adjusting the scale is not a solution but adjusting your weight all in 60 days.
No strees, side effect or bitter drinks but all natural flavour beverages. Tested & trusted ISO 22000-2005.
YES U CAN, ITS BETTER TO BE ON THE SAME PAGE WITH YOUR DOCTOR.
Oct 13, 2009 | Taylor & Digital Scale Lithium Scale
Broken hinge on reservoir cover
The hinge itself and the lid are not orderable parts, unless you grabbed one off of a broken unit of the same model. The product does, however, have a 3-year warranty.
-Tha Mp3 Doctor
Feb 26, 2009 | Cuisinart DCC-2200 14-Cup Coffee Maker
Err 1 message on Taylor Lithium Elec Scale model 7346
This is a reply I received from Taylor customer support. I have followed this procedure enough times to wear out the original battery and still get the Err 1 message. You may have better luck.
Thank you for your e-mail. The reboot below may clear the error from
your scale. You may need to do this several times to completely reboot
the system. Please let us know if you have any questions or continue to
display the Error.
1. Remove the battery from the scale
2. Set the scale on the floor without the battery in place.
3. Stand on the scale for 10 seconds (still without the battery)
4. Carefully replace the battery without turning the scale on.
5. Using only one foot, tap the scale or apply just enough pressure to
turn on the display. (It should show dashes or zero's) IMMEDIATELY
REMOVE YOUR FOOT.
6. Let the scale turn off
7. Step on the scale for a weight reading
Regards,
Linda DLT
Consumer Relations
Taylor Precision Products
& Salter Housewares
2220 Entrada del Sol, Suite A
Las Cruces, NM 88001
Toll free - 800-289-0944
866-843-3905
Direct - 575-526-0944 ext 3172
Feb 11, 2009 | Taylor & Digital Scale Lithium Scale
Health-O-Meter Health O Meter Adapter for Remote Display Scales Logo
51 people viewed this question
Top Health-O-Meter Health & Beauty Experts
creative_lac
Level 1 Expert
Ernest
Ernest
Paula Hamilton
Are you a Health-O-Meter Health and Beauty Expert? Answer questions, earn points and help others
