Question about MSI K7T Turbo Motherboard
AGP 4x-8x compatability on msik7t turbo
Can i use a 8x agp graphics card on my old msi k7T Turbo motherboard. I currently have all in wonder 128 card?
  • 1 more comment
  • hogsdom May 31, 2008
    what is the best 4x agp card i can get. I currently have an ati 'all in wonder 128'! Is there better and how cheap could i pick a better card up for if there is one? Thanks for your help by the way. It's appreciated.
    how do i know this is 4x agp? THere are others that say 4x/8x support but when you read the specs it just says 8x? Confusing!
  • Anonymous Mar 23, 2014
    sound
I NEED a card sound of these pc celsius m410
model. mtr-d 1356
serial. itl- 665 115 - 001
ybtb002856
serial nr. k665- v115- 466
Posted on Feb 10, 2009
    Scholar:
  • 187 Answers
It seems you can't, no. Your board supports AGP 1x, 2x and 4x; http://global.msi.com.tw/index.php?func=proddesc&prod_no=327&maincat_no=1&cat2_no=&cat3_no=
Posted on May 29, 2008
Sorry, posted to the wrong page (please ignore my reply)
El único manual que pude encontrar es en Inglés, sino que debe contener información de conexión (inc diagrama) que puede utilizar.
Si el vínculo con el manual en la parte superior de la página da problemas, puede encontrar los enlace de descarga para que, en la parte inferior de la página; http://www.ecs.com.tw/ECSWebSite/Downloads/ProductsDetail_Download.aspx?detailid=422&DetailName=New&DetailDesc=741GX-M%20%20&MenuID=0&LanID=8
What AGP graphics card is compatible with AGP
AGP 4X (1.5 Volt)
http://www.firingsquad.com/hw/1719/Iwill_P4S/
Suggest you use a graphics card that is AGP 4X/8X
Example, ( Not an advertisement for graphics card manufacturer, nor website),
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4103516&CatId=318
Jan 14, 2010 | Computers & Internet
Is my mobo compatible with a 256 mb 128 bit fx5500 agp video card?
youre motherboad support intel pentium d 800mhz fsb processor and ddr 400, it has built in graphics, yes it will support a 256 128 bit fx5500 agp card, the agp 8x/agp 3.0 enhance graphics performance it support a high bandwidth speeds up to 2.12gb/s its twice faster than agp 4x,
Nov 22, 2009 | EliteGroup 865G-M8 (V1.0) (MB865GM8)...
Will a NVIDIA GeForce FX 5500 video card work on a P4B533-E motherboard?
HI Lau_kua08,
First off, your motherboard is a AGP 4x slot, and the Card is a AGP 8X card. However, NVIDIA based graphic cards which support AGP 8x mode (Accelerated Graphics Port) follow the AGP 3.0 specification. The AGP 3.0 specification retains backwards compatibility with older AGP 4x technology. All NVIDIA Geforce and Quadro GPU's which support AGP 8x mode are downwards compatible with AGP 4x motherboards. When a graphics card which operates at AGP 8x mode is installed on a motherboard which only supports up to AGP 4x mode, the card will automatically switch to AGP 4x operation.
So, yes it will work.
Good Luck,
Mark
Oct 27, 2009 | ASUS P4B533 Motherboard
Is DFI AK75-AL compatible with 128Mb/128 bit video card?
Yes, the DFI AK75-AL motherboard has a VIA KT-133A chipset which is compatible with a FX5200 videocard, but not at the full 8x AGP speed (as the videocards supports) but only at 4x AGP speed (maximum speed supported by the motherboard).
PS: Make sure you use the newest motherboard BIOS en VIA chipset drivers to ensure compability.
Apr 09, 2009 | XFX NVIDIA GeForce 8500 Graphic Card
For adding an additional graphics card
Your board only supports AGP 4x graphic cards. You should be able to use any AGP 4x card or even some AGP 8x cards. Some of the 8x cards are backwards compatible but will run at the slower 4x speed. You can try places like TigerDirect.com or Newegg.com to see what they have available. Hope this helps & please remember to rate my answer. Thanks.
Jan 24, 2009 | Computers & Internet
Looking to upgrade video. is there a limit to uprade old mboard
Only cards that work with this board are AGP 4x graphics cards or possiblly AGP 8x cards that are backwards compatible. If you buy an 8x card do your research to make sure it's backwards compatible before purchase. Newer graphics cards are pci-express x16 or pci-e 2. These will not work with your board. Hope this helps & please remember to rate my answer. Thanks.
Jan 10, 2009 | Matsonic MS9327E (MS9327E+(USB))...
Intel P$ 1.8 mhz on a D845HV/D845WN board
Before removing your current card swap video outputs on the PC. If currently connected to the VGA output switch to the HDMI connector AT the video card. Use the HDMI to VGA adapter that came with the video card. Check & see if the display loads Pc starts. Taking the information directly from your motherboard manual pg. 25, your AGP video can only run at, AGP supporting 1.5 V 4X AGP cards. The 9600pro runs at 8x & it is not backwards compatible. (able to run at either 8x or 4x). You could run the Sappire ATI Radeon 256MB 9550 DDR AGP 4x/8x 1.5volt card.
Here is one site: http://www.colordrives.com/sapphire-ati-radeon-9550-256mb-ddr-agp-4x-8x-video-card---retail-box.html
When you do get the video card be sure to set your bios AGP to the correct size as listed in your manual pg. 109 subsection 4.4.7
I hope this helped.
Feb 20, 2008 | Intel Motherboard
Grapics card
Most current AGP video cards are now 8X and they will still work with your motherboard but will just be limited to 4X. Trying to find a 4X might be time consuming whereas using an 8X downgraded to 4x would be comparatively easier and faster.
Additionally most Video cards will work under XP with the appropriate drivers but Vista has a limited list of compatible Video cards.
Hope that this be of some help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Dec 08, 2007 | Nvidia GeForce2 MX200 64MB 4x AGP Graphic...
MSI K7T Turbo Motherboard Logo
197 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
