Question about Whirlpool Washing Machines
Problem i don't know where is the problem that is why i m here and i don't know where i should go that is why i m here, tthe water did't come into the machine
    Novelist:
  • 142 Answers
Lets start on the simple things...
1. All hose connections are in place and connected to the washing machine.
2. All valves supplying water to the machine are in the open position (ie: if the hoses were removed from the back of the machine, water would be flowing)
3. The machine is plugged in and otherwise operating.
If this is an older machine nd it used to work then I'd check to see that the flow valve (kind of like a relay that allows water to enter the machine) is functioning properly. Do you hear it click when water is supposed to be entering the machine? If not, it might be bad. Consider also trying to change the water selection switch on the machine to a different setting. If water starts to flow, look at one of the flow valves.
If this is a newer machine and it has never worked, review the 3 items above. If all seems to be OK and it still does not work, get in touch with the company you purchased from and exercise your warantee rights.
let me know what happens. Please rate accordingly.
Posted on May 30, 2008
TThe water only drips drops of water to maybe 1/4 of a cup.
Unit needs to be cleaned. Read the manual for directions.
Mar 02, 2017 | Coffee Makers & Espresso Machines
Audi A4 1997 it have reverse and shift only one gear forward transmission
you would need to inspect all wiring leading to the transmission solenoid for short or break in the wiring and/or replace the solenoid inside the transmission - they either work or don't -- One last thing -s ince the information was ommitted, do you know the manufacturers recommend method to check the transmission fluid? Have you checked tthe trans fluid????
Best regards,
Ck
Jul 17, 2012 | 1997 Audi A4
I have no power to my 19 inch sylvania flat screen
I'm going on the assumption you are not a television technician in which case your ability to troubleshoot the problem will be very limited
. If your television is still under warranty, you will void the warranty if you attempt any repairs.
Tthe first thing you want to do is be certain the outlet the television is plugged into is working. Don't assume because one outlet in a duplex receptacle is working that the other one is also, verify it by doing a voltage check, or at the very least plugging in a lamp.
I hesitate to give anybody advice about working on any product that has capacitors.
If you don't know why I would say that, I think you will be taking a chance of hurting yourself or ruining your television if you attempt to go any further.
Even if you understand my reason for saying that and the warranty has expired, I can only think of two things you may want to try to do yourself.
1. With the TV unplugged check the continuity of the wires from each prong on the plug to where they terminate in the TV.
2. Locate and check any fuses.
If you don't know how to do those two things, do yourself a favor and take it to someone who does.
Nov 14, 2011 | Sylvania LC195SL9 19 in. LCD TV
Water leaking under fridge when I turn on water to filter
its the cooled water tank may be leaking. take all of tthe shelves out of the fridge and wipe it all down, turn water on and use a newspaper to wipe it down again, stopping and looking at the paper to see if it is wet, this will give you a idea where to focus your new leak detecting skills.. good luck ..jay
Jun 06, 2011 | Kenmore Side by Side Refrigerator
My fan don't come on .
thers afew thing you can check (fan no good at all,wireing problem or faulty,fan fuse,not comunication between heat sensor and fan.i mean if the heat sensor is not working properly tthe electronic system wont let fan know when to start. so you can start checking those essues 1 by1 and may sure each 1 of them are working properly .that will be the easy way to start looking for this problem.if you find any of this working wrong , then you just found the problem resolved.good luck
May 20, 2011 | 2000 Volvo S80
Every 15 seconds the refrigerator beeps and i noticed the refrig light was out. I replaced the bulb which is now working but it still beeps every 15 seconds. tThe temperature in both the frig and freezer...
I don't know if you have an ice maker but when my ice dispenser is full my fridge beeps because the ice can no longer go into the tray because it is full so I have to empty the tray. and the beep stops it also beeps when the water filter needs changing. I hope this helps
Feb 23, 2011 | Refrigerators
HOW TO CHANGE SERPENTINE BELT ON 96 IMPALA SS
Rotate the tensioner pully clockwise using a 13 mm 1/2" socket. (the tensioner pulley is the only one with a hex head bolt). Follow tthe routing guide inside your engine bay and replace the pulley. They can squeak from age even if they don't have any cracks.
Apr 11, 2010 | 1996 Chevrolet Impala SS
I need to know tthe size of the connection for the
Hi. These are all standard. the tubing is 1/4 inch as are the compression fittings
Aug 20, 2009 | Refrigerators
Chainsaw doesn t start because is cold
give it a shot of starting fluid and see what happens , should start
Feb 02, 2009 | Garden
No water to machine
Start checking the water supply connected to the machine, if water is regularly coming to the machine, the problem is either a faulty inlet valve, a defective membrane water level switch, or a faulty timer control (the first two are more likely).
Call a local technician and have the appliance fixed.
You find replacement parts and diagrams here.
Dec 27, 2008 | Maytag PAV3240A Top Load Washer
Washing Machines Logo
37 people viewed this question
Dan Webster
Dan Webster
Sal De
