Question about Singer 5050 Mechanical Sewing Machine
Where is the tenshion nob? - Singer 5050 Mechanical Sewing Machine
  • Singer Master
  • 7,365 Answers
The nob should be above the needle area- with numbers from 0-9
Posted on Oct 07, 2010
WhenI turn the inside nob the needle works but not when I turn the outer nob, it just turns and nothing happens WhenI use the peddle the outernob spins but again the needle doesnt work (nob=handwheel)
On most machines, when the inner wheel is turned counter clockwise, it engages the bobbin winder and disengages the needle movement.
To disengage the bobbin winder and sew, turn the inner wheel clockwise as far as it will go. This should engage the sewing capability and it should work either by hand rotating the large wheel (always counter clockwise!) or with the foot pedal. If it does not, then you most likely need to have your machine serviced.
Jun 29, 2016 | Sewing Machines
385 19000 touch screen is blank
There is probably an electronic problem with the circuit behind the knob.
Do you have a manual?
Kenmore 385 19000 Owner Manual
Feb 15, 2015 | Sewing Machines
How to thread Singer merritt#9608? Probledm with birdnesting
what size bobbin and do you have pictures to show how to thread 9608 singer machine
Mar 10, 2012 | Singer Sewing Machines
The clutch on my kenmore 1310 won't disengage when i go to wind the bobbin. i turn the clutch knob toward me, and the clutch is still engaged.the machine needle continues to operate while i wind the bobbin
May be one of two problems.
1st you should be able to turn the nob about 90-120 degrees. Not a full turn.
If this is not the case follow these steps.
Turn the small screw on the nob about 2 full turns
Carefully turn the nob all the way off.
Inside there is a round part with 3 small prongs on it.
spin that 180 degree and put everything back together.
2nd your clutch is gummed up
You will need to remove the handwheel and motor belt for this.
Remove the nob, small 3 prong part, and motor belt.
Pull the handwheel off (it may be stuck on and hard to get off).
Clean inside the handwheel and the machine main shaft.
Lubricate the Main shaft and put handwheel back on.
When you put the small 3 prong part back on it needs to have the prongs sticking away from the machine.
Hope this fixes your machine
Apr 06, 2011 | Kenmore Sewing Machines
NECCHI, model 4795. Thread bunches up at bobbin.
it sounds like the thred tenshion is to loos or the timing has sliped a little and its off a bit this can also happen with wear on the gears or just a loos fixing letting the timing slip back a bit,
Nov 20, 2009 | Necchi Sewing Machines
Upper thread catching in bobbin casing area
tighen up the top thred tenshion a bit if that dont sort it out i gess the timeing has sliped a bit on you
Oct 25, 2009 | Sewing Machines
My machine is skipping stitches....Why? And the Bobbin doesn't seem to be catching.
try changing the needel first,,, then rewind a new bobbin, also try ajusting the thred tenshion, if thats not sorted it out its down to the repair mans for a good service as its sliped its timeing a little,
Oct 25, 2009 | Singer 2638 Mechanical Sewing Machine
Why does the top thread keep on breaking
its not put round the machine quiet right like its twisted or looped over some thing or the tenshion is to tight? even the cotton reel could be to tight? you will need to forgive me,, on this,,, im just a man who cant sow a button on?
Oct 25, 2009 | Janome Sewing Machines
Singer 5050 Mechanical Sewing Machine Logo
23 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
