I have a dynex rf modulator that I am using in between the computer and the tv because the tv only has a coax connector. When everything is hooked up, the tv is on channel 4, the computer video only shows up while the computer is coming on. Once the computer is fully booted up, the tv screen goes black. I am coming out of my computer with a s video cord directly to the s video jack on the modulator. then from the modulator to the tv by coax. Please HELP!!! Jimmie Bond
    President:
  • 2,571 Answers
Have you been into the display options to choose how you would like to use your external display.
You should be able to change the settings by right clicking on the desktop and looking for display settings
Posted on Oct 07, 2010
How do I hook my old PS2 to my RCA TV with my converter box?
RF cable coax out to TV from the RF Modulator .....RCA jacks "red-yellow-white from ps2 to RF modulator "its not called a converter box"//lol Put the TV on channel 3 you should see the ps2 screen. Same way you would hook up a DVD player to a CRT TV..heres a video
TVs DVD Players How to Connect TV DVD Player VCR With Modulator
Mar 22, 2015 | RCA Televison & Video
I dont know what chords to use to hook up a dvd player to the pfm-42v1 tv. the tv doesnt have a yellow, red or white connection
Hello bobbylanetra,
if your tv does not have the composite connection (the red, white and yellow), I am going to assume that you have a coax in though. So what you should do is get an RF modulator. Connect your dvd player OUT to the RF modulator IN with the composite cable, then use a coax cable and connect the RF modulator OUT to the coax IN of the tv. That should solve your issue. I hope this helps or if not give me a feedback, good luck.
- Joe
Aug 31, 2011 | Sony PFM-42V1 42 in. HD-Ready Plasma...
I have an analog tv (coax cable) and a new dvd (av plugs) player. How do I inexpensively connect them? i saw the solution posted about the rf modulator. I have a digital to analog tv convertor. Is this...
NO. An RF modulator and your digital-to-analog (DAC) TV converter are 2 different devices. The DAC will convert over-the-air (OTA) digital television signals from your antenna to analog NTSC format so your older analog TV can receive OTA broadcasts. The RF modulator converts base-band video (composite cable/RCA connector, or S-Video cable connector) to channel 3 or 4, so you can watch video/audio on your set. To use both the RF mod. and the DAC converter to the same TV, use an A/B switch for F-connector coax, or follow the directions for the RF modulator to make the correct connections.
Jun 12, 2010 | Televison & Video
I am trying to hook up my Philips 19PR19 (made in 1998) tv to the dish network receiver, it has 3 prongs diff. colors attached and the cable cord is already to go in the wall...I don't see anywhere on the...
Because your TV is an older one, it might not have, what they call RCA inputs (the 3 colored cable) Red-audio right, White-audio left, Yellow-video. If I understand you.
You do have the option of using the 75-ohm coaxial cable inputs. Signal comes in from outside to the 722k, Output of the 722k to the 75ohm coax input on the back of the TV. Tune your TV to ch. 3 or 4. Make sure the switch on the back of the 722k is set to the same.
If you really want to use the RCA colored cables, then you need to buy an RF modulator, which integrates older tv's to newer products. But usually dvd players, not necessarily cable boxes, but it would work if hooked up correctly.
You plug the RCA red, white and yellow from the 722k, into the rf modulator, choose channel 3 or 4 on the modulator
Connect 75ohm coax cable from rf modulator to TV 75ohm coax cable input. Choose channel 3 or 4 on the TV.
Hope this helps.
Apr 07, 2010 | Philips 19PR19 19" TV
PS2 won't work with magnavox dtv converter box
first off make sure u have the box turn off
this is what i would do:
i would get a short coaxile cable and splitter and hook them up to your tv
........................TV.........................Coax input
.........................|..............................Coax Wire
......................../\.......................................Coax Splitter
....................../...\.......................................Coax wire from ps2 and dtv box
...............PS2......DTV box......................
Hope this helps
Apr 28, 2009 | 1991 Honda Accord
Connect magnavox dvd to ge tv HELP!
You need to go get an RF modulator. They can be purchased at Radio Shack or a number of other electronic shoppes for a reasonable price.
The RF modulator connects to the coax cable connector and it has inputs for the RCA connectors.
Cheers ... Best wishes
Jan 30, 2009 | Televison & Video
Installing DVD player/RF Modulator with Star Choice
The RF modulator probably had a red, white, yellow trio of RCA jacks (A/V jacks), a coax jack marked "antenna" and another coax jack marked "TV"
Putting the DVD output to the A/V jacks allowed it to play out to the TV, which couldn't otherwise accept the DVD player.
The satellite box probably has coax and a/v jacks as output. Use the coax as output to the antenna input of the RF modulator, and the A/V jacks of the DVD player to the A/V jacks of the RF modulator. Hopefully the modulator allows the A/V jacks to have priority over the coax input, so that when the DVD plays it "wins"
Jan 12, 2008 | Televison & Video
Magnavox MWR10D6 can't record from camcorder wrong channel
OK...try this...plug your RCA cables from your camcorder into the RCA input jacks on the back of the recorder. If you have a VCR, it can be plugged into the coax input on the back of the recorder. Use the coax output and plug it into a RF modulator (about $20 at Wal Mart). Plug the RCA output cables from the recorder into the RF modulator as well (Don't ask me why, but it seems to work on mine). Connect a coax cable from the RF modulator to the TV. Make sure the TV and Recorder are both on the right channel. The RF modulator will have a channel switch to use channel 3 or 4 on the TV. Make sure the recorder is set to E1 (Rear). You can check this with the channel +/- buttons on the bottom right of the remote. Good luck.
Jan 06, 2008 | Philips Magnavox MWR10D6 DVD Recorder
RF Modulator
The RF modulator changes the outputs from RCA (red, white, and yellow) to a Coaxial Cable (COAX).
You connect the DVD players RCA outputs to the RCA Inputs on the RF Modulator, then connect the COAX Output from the RF Modulator to the television.
Best of Luck.
Oct 23, 2007 | Car Audio & Video
No A/V!
DOES THE SYSTEM POWER LITE GO ON? IF SO THE PROBLEM IS MOST LIKELY A DIRTY GAME. YOU NEED TO CLEAN EVERY GAME BEFORE PUTTING IT IN. MIX ALCOHOL AND WATER, 1 TO 1 AND USE A Q TIP TO CO UP AND DOWN THE CONTACTS. IF THEY ARE BEHIND A PLASTIC DOOR, STICK A SMALL SCREWDRIVER IN THE HOLE AND IT WILL MOVE BACK. OTHER THAN THAT, YOU SEEM TO HAVE DONE EVERYTHING RIGHT.
Aug 30, 2007 | Atari 7800 Console
Computers & Internet Logo
David Payne
David Payne
