Question about Gestetner DSm618d Copier
I want to replace the charge roller, Charge cleaning brush roller and Cleaning blade assembly. Thanks
  • rogerwcall Oct 07, 2010
    These are only user manuals, I already reviewed these manuals before I contacted Fixya. I need technical help in replacing these parts.
Click on the link below to view all of the original documentation for your Gestetner DSM618D copier, inside these manuals will show you how to change the cleaning brush roller, charge roller, and cleaning blade assembly.
http://www.gestetnerusa.com/manuals/gestetner/gestetner_comV4.nsf/DownloadManualPageb8d1.html
http://www.gestetnerusa.com/supportdocumentation.html
Posted on Oct 08, 2010
  • 857 Answers
Go to the website mentioned below and downlaod the manuel as per your need,
else call support at :973-882-2000
Posted on Oct 07, 2010
2330 drum repair
Drums are cheap. Replace it along with cleaning blade cleaning roller and charge roller. Perform F8-14 and F8-20.
Jul 28, 2014 | Panasonic Workio DP-2330 Printer
Black line on copies
Check the drum history? If the yield is not yet reached, you should clean the charge roller, cleaning blade brush and cleaning blade. Remember to vacuum beneath the cleaning blade! See if that works, otherwise you should call a techie to replace the drum. If yield is not reached they will charge you for a new drum.
Jul 21, 2014 | Ricoh Aficio Office Equipment & Supplies
Replace photo conductor
Charge roller and charge roller brush must be cleaned and the cleaning blade should also be cleaned. I the copy was made through the doc feeder then your optics are dirty. Take a damp cloth and clean the slit glass and exposure glass.
Jan 24, 2014 | Gestetner DSm415 All-In-One Laser Printer
Streak in the middle of the copie/print with drum and blade replaced
Please clean the drum charge roller use the izopropilalcool,clean the charge roller cleaning roller,clean use the vacuum cleaner the waste toner (located under transfer assembly 6 screw),activate the ATDC and AIDC sensor configuration.
Jan 08, 2012 | Ricoh Aficio 1035 Copier
My problem is , to many black lines in image in aficio 2045
the black lines ( narrow ones ) can occure because of worn out charge roller and drum cleaning blade.
First of all You need to replace drum, drum cleaning blade and clean the charge primary roller or replace it.Also if the times was came for drum section, repace also the developer and do the preventive maintenace on copier.
Call service!
Hope that helps!
Sep 10, 2011 | Ricoh Aficio 450 Copier
I have a savin 2522 and it has a few lines running down my copies
few fine lines is due dirty optics mirrors and lamp, and it may also came from dirty charge rollers due to dirty/worn out charge roller cleaner, worn out cleaning blade and seal blade. to check this, clean/wipe off toner or dirt from charge roller with cloth wet from alcohol or water. then run some test copy.
Mar 03, 2010 | Savin Office Equipment & Supplies
I had a Ricoh Aficio 2035 and i encountered Frequent toner spilling. almost everyday i clean the toner disposal tank located under the transfer charge belt. what part or remedy should i do? i try to lower...
Clean the PCU unit components:OPC drum,cleaning blade,charge roller.
Clean in the developer unit the development roller,and the entrance seal plate.
Raise the toner bottle holder lever,push the lever to the side and then pull the toner bottle holder out and clean this unit to use a vacuum cleaner.
Clean the transfer belt cleaning blade and the rollers.
Nov 22, 2009 | Ricoh Aficio 2035 Copier
Brush roller lines in feed direction of pages
Maybe the charge roller. Make sure it is very clean. You can also stop a copy before it enters the fuser to rule the fuser rollers out.
Feb 08, 2008 | Panasonic Workio DP-2330 Printer
Need to replace the drum cleaning brush how do I get it out????
The drum cleaning blade removal is pretty straight forward.
1. Remove the charge unit above the drum.
2. Remove the cover that sits above the cleaning blade.
3. Release the pressure spring at front of drum unit.
4. Remove 1 screw (front side of blade at top) holding blade in place.
I noticed that you had also had a E3-40 code previously. If toner is dropping on to your copies, the toner support blade will also have to be replaced.
Jan 31, 2008 | Panasonic FP-7735 Black and White Copier
Gestetner DSm618d Copier Logo
128 people viewed this question
Top Gestetner Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
CheckitRight
CheckitRight
 Larry
Larry
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
