Question about Jenn-Air JSD2789GES Side by Side Refrigerator
Hello, My Jenn Air refrigerator will make a humming sound and click and continue this for about an hour and then the compressor will start.
  • Jenn-Air Master
  • 43,501 Answers
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Oct 08, 2010
Temperature Alarm is sounding - Freezer at 20 degrees...typically near zero
Ohhhh nooo hope its not the compressor... Take off back panel and see if your condenser fan is running...also check if compressor is running....if its clicking out may only be the compressor start relay which is cheap to fix...good luck...
Oct 02, 2012 | Jenn-Air JCD2295KES Stainless Steel
I have a Jenn Air side by side refrigerator that started making a humming and clicking sound last night and this morning it stopped cooling on both sides. What could it be?
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
Nov 24, 2010 | Jenn-Air JCD2389G Side by Side...
Buzzing/humming noise with jenn-air bottom freezer
i have this problem too on my GE Profile. A youtube video seems to suggest a compressor problem. Turn off the fridge for a while and let it cool down and try again? I tried but to no avail. Would someone answer this? Please :)
Mar 21, 2010 | Jenn-Air Refrigerators
Buzzing from lower area - replaced relay and cap - not freezing - staying cold but not freezing - Synptom: Click -humming for 15 sec-click cycles like that every 5 minutes Compressor is warm to Hot - fan...
If the defrost cycle was stuck on then the compressor would not be humming trying to start. You may have a shorted compressor. Especially if its a frigidaire they are known to have the worst compressors. You can use a meter to check your compressor windings. You can check for a short by scratching the paint off the compressor and checking from each terminal to the bare metal on the compressor. If you have continuity then its shorted. Also check continuity from each pair of pins on the compressor. Good Luck _MJ_
Mar 14, 2010 | Jenn-Air JCB2282H Side by Side...
Jenn-air JCD2389DES stopped cooling in both the refrigerator and freezer. I hear a click sound every now and then. It sounds like it is clicking on but then nothing happens. The clicking sound is coming...
2 things may cause this condition.
1. The relay and overload which starts the compressor has failed.
This is an easy fix.
2. The compressor has failed.
The compressor can be replaced and is worth doing if the unit is in good shape.
Jan 15, 2010 | Jenn-Air Refrigerators
Buzzing and clicking sound every few minutes
Compressor start relay - white plastic part - sitting right on the compressor, disconnect it shake it - u'll here it if it's damaged. :)
Oct 01, 2009 | Jenn-Air JCD2389G Side by Side...
Jenn Air bottom freezer refrigerator not cooling properly,
This may be your compressor. You'll probably need a hard start kit put ont he compressor if it's not still under warranty. I hope this helps you out!
Aug 13, 2009 | Jenn-Air JBR2086HES Stainless Steel Bottom...
Jenn-Aire Refrigerator Shutting Down
sounds as if the control board has gone bad unless you have an extended warranty that you purchased extra this will probably not be covered, but check with jenn-aire to be sure. I dont think I would worry about a 3rd compressor being bad but I would unplug the unit to prevent any further damage to it. good luck peyton
Jan 30, 2009 | Jenn-Air JCD2295KE Side by Side...
Jenn-Air JSD2789GES Side by Side Refrigerator Logo
113 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
