Question about Sebo Vacuums
My sebo cleaner keeps almost cutting out but comes back on again after a couple of seconds. I.ve checked for blockages and changed the bag and filters.
  • 171 Answers
Sounds like a bad sensor or a possible loose connection electrically. If you are very handy with tools you could try taking things apaet but a dyson is expensive nso I would leave it to the pro's and take it to the local used vacuum shop. They give the best advice in these situations.
Posted on Oct 07, 2010
Testimonial: "My husband took it all apart and put WD40 on the connections, its working fine now. Thankyou for the advice"
It just keeps saying that my bag is full and cutting out, bag not full and have tried changing it anyway, but still cutting out
I would check the air filter. It sounds like it's over heating and shutting off because it doesn't have good airflow.
Jim
Oct 05, 2010 | Sebo X4 Bagged Upright Vacuum
Bag full or clog light comes on but new bag and no blockage... Sebo x4 upright cleaner
Have you checked the filters to see if they are blocked and need cleaning/replacing. Failing that it could be the sensor at fault.
Jul 25, 2010 | Sebo X4 Bagged Upright Vacuum
Red light comes on saying bag full or clogged. Bag has only recently been changed so what do I look at next?
You look for a blockage - almost certainly in the flexible hose. Remove the hose from the machine completely (both ends, that is), then switch the machine on and the red light should not come on unless you block the hole on the top of the bag compartment with your hand. Then you need to investigate the hose, to find and remove any blockage. This is not always easy. You can try sucking a blockage out, back the way it came in, either with a second vacuum or simply by reversing it on your Sebo as best you can. This will often pull the blockage to the point where you can get hold of it with pliers or a bent wire or the like. Unless all else fails, and you get desperate, don't try pushing a blockage out with a broom handle or anything like that as you will probably only consolidate the blockage. You should also check in the little trap-door on the underside of the base to make sure all is clear there.
If you need further guidance, just post a reply here and I'll answer as soon as I can. Good luck!
Mar 26, 2010 | Sebo X4 Bagged Upright Vacuum
Sebo automatic X1. After switching on the motor
As sure as possible without actually seeing your machine, the carbon brushes on the motor are worn out. They are quite easy to replace (and not expensive). If you need help with doing the job, just post a reply here and I'll guide you as best I can. If you choose to have a professional do it for you, it should take no more than half an hour's labour.
I hope this has been helpful - please remember to score me! Good luck!
Feb 10, 2010 | Sebo Automatic X1 Bagged Upright Vacuum
The red light on the cleaner keeps coming on. I
It could be clogged or there is a sensor adjustment for this machine and it takes a very small screw driver to adjust it. Take it to a certifies Sebo dealer and he can fix it in just a minute.
Nov 26, 2009 | Sebo Automatic X1 Bagged Upright Vacuum
Machine keeps cutting out intermittenly
My Sebo Air Belt C2 Total. The automatic electric cable wire won't stay out when pulled, it just springs back. When I'm hoovering I have to wrap the wire around the small wheels so that it doesn't shoot back in the machine.
Oct 18, 2009 | Sebo Air Belt C2.1 Bagged Canister Vacuum
My SEBO vacuum cleaner keeps cutting out which seems to suggest an dodgy electrical connection...any ideas ?
If it just cuts out then comes back on after a while, it might be overheating.
Sep 22, 2009 | Sebo Vacuums
Sebo vacuum cleaner cuts out ?why
it might be the bag.just check with your local vacuum store
Jun 04, 2009 | Sebo X4 Bagged Upright Vacuum
Sebo x5 vacuum cleaner
The full bag light comes on when it is getting full or a blockage in the hose or the dirt inlet by the brush roll. Other then that, there is a circuit board called the computer controller, part #5740ER and is giving you a false reading and causing a shut down.
Jun 22, 2008 | Sebo X4 Bagged Upright Vacuum
Vacuums Logo
555 people viewed this question
Top Sebo Vacuums Experts
Nick Olsen
Masters Engineering
Level 1 Expert
Are you a Sebo Vacuum Expert? Answer questions, earn points and help others
