Question about Vacuums
Is it possible to remove the suction head off the metal hose?
  • 171 Answers
If it is the wand you want to take out of the head there is a small button that will release it just push the button and try twisting at the same time . If it has not been off before it may take some force as it may be a bit stuck. Good luck
P.S. If this doesn't work write back with the make and model of the machine.
Posted on Oct 07, 2010
I have a kenmore model 116.25512506. The roller is spinning but no suction from the head. The attachments have suction but not the head. How do I remove bottom cover to check for blockage?
Is the suction control plastic ring shut?. If it's wide open you get almost no suction. See picture.
25823072-bhx41vpbxgcw2fhkwng0wody-1-0.jpg If that is closed check the long metal wand. Disconnect from the beater bar head and check the whole length of the wand and look into the beater bar head opening for something plugging it.
Aug 15, 2015 | Kenmore Vacuums
No suction when using hose attachments - motor runs and under cupboard vent works - just not able to use just the hose with attachments
does the vacuum turn on when hose plugged into wall outlet assuming your using central vac. if it does not turn on then the metal band in the hose end is possibly cracked.
Jan 03, 2015 | Vacuums
Wertheim x3000 motor running but little suction?
Check all of the filters. When there's extra heat, it's usually blocked filters.
If not, dismantle the wand and use long pipe cleaners or a bottle brush to clear any possible jams in the wand or head. Remove the hose from the main unit and if possible, drop ball bearings or marbles down the hose to try and clear any blockage. Remember to recover all of the ball bearings or marbles before you reassemble the hose and wand.
Aug 13, 2014 | Vacuums
Why would a Hoover Windtunnel have no suction?
It could be clogged at the head or throat, or you might have a hole in the hose. Unplug the hose; if you're getting suction where the hose plugs in then the problem is in the hose or the head. If you're not getting suction where the hose plugs in then the problem is in the body, probably the throat. If the problem is in the hose or head, detach the hose from the head and check for suction at the end of the hose. If there's not suction there, then you've got a clog or a hole. If there is suction there, then you've got a clog in then head.
May 20, 2014 | Vacuums
The hose suction on my Dyson Animal (DC41) is fine, but will not disengage when you put the hose back and want to use the floor sweeper.
Hi Stacy, it's Jack at Dyson.
This issue you've described with your DC41 sounds unusual, as the changeover valve will divert suction to the cleaner head automatically when you recline the machine into the vacuuming position. If it's not doing this, it's possible you have a blockage somewhere in the cleaner head, internal hose or changeover valve.
To check for this, please follow the steps shown in our online Support guide: http://www.dyson.com/support/dc41/dc41-irspu/diagnosis-root-menu/performance-flo-area-check-dc41/flo-brushbarvid-dc41/redirect-to-performance-flo-base-dc41-checking-the-internal-hose/performance-flo-base-dc41-checking-the-internal-hose
If you'd like some further advice after you've given us a try, please email our experts with your details at askdysonUS@dyson.com. Someone will be in touch to help as soon as possible
Feb 27, 2014 | Dyson Bagless Upright Vacuum DC41 Animal
My Electrolux guardian C135 vac has lost suction. replacing the bag does nothing. removing the HEPA filter has no effect - what do you suggest? Will a replacement HEPA filter make any significant...
No you have a clog in the hose, wand or at the power head. Remove the hose wand and power head from the the vacuum. Turn on the vacuum, put the palm of your hand over the hole in front, you should feel plunty of suction. Then replace just the hose and put the palm of your hand over the end of the hose. If you do not have suction the clog is in the hose. You can try putting the hose on the blower port to blow out the clog or use the wire from a coat hanger. If you have suction, then add just the wand and repeat. If you have suction, then the clog is in the neck of power head, you will have to use a coat hanger to clear it.
May 08, 2010 | Electrolux Guardian Bagged Canister Vacuum
A Dyson dc 17 Animal and the wand/hose has lost suction
Hi its Darran at Dyson.
From your description of the problem, it sounds as though the wand/hose is blocked. To check this, remove the wand/hose assembly from the machine, switch it on and test the suction from the top of the wand with your hand. If the suction is poor, remove the wand from the hose and test the suction from the top of the hose. If its good here, then you know that the wand handle is blocked.
For the full diagnostics, check out the Support section on our website at www.dyson.com or call our Helpline on 1866MYDYSON.
Kind regards
Darran
Dyson Customer Service
Jan 30, 2010 | Dyson DC17 Animal Bagless Upright Cyclonic...
Floor attachment does not suction, no clog in the hose, hand held works when dettached from floor attachment
Have you checked the floor head? Use a pipe cleaner or twisted metal to carefully and gently see what's in there. It sounds like dirt or something has definately sealed up the main suction channel.
May 07, 2009 | Vacuums
Dyson DC 14 lost suction to beater bar/ suction to hose/stick
My Dyson DC14 had no suction...see if this works...turn the Dyson upside down...there is a length of hose that connects the bottom of the vacuum to the top, careful remove one end of the hose and check for debris...mine was clogged. Removed the clog and voila...it works. Thanks for the above info on checking the hose for cracks.
Apr 11, 2009 | Dyson DC14 All floors Bagless Upright...
Suction loss when handle is tipped back to clean carpet
can any one help,
Our Dyson Animal vacuum has plenty of suction when it is upright and the attachments are being used off the hose, but when the handle is tipped back to begin cleaning carpets the beater head is getting no suction. As the handle is being tipped back you can hear what sounds like a flapper valve in the body of the vacuum opening and then all the suction just goes away.
Nov 19, 2008 | Dyson DC07 Animal Bagless Upright Cyclonic...
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
