Question about Canon imageRUNNER 2200
IR 2200 Fixing Assy
I am looking for a fixing assy for a IR2200. tried many suppliers - none in stock. any idea who has one to day for sale?
Thanks
  • Canon Expert
  • 1,326 Answers
What are you looking for???? The whole unit or the heating element with the fixing film or just the film it self??? The whole unit can be fould along with the other parts on th web. Look up copier parts.....
Posted on May 30, 2008
Error E007
Dear
This error arises due to the rotation sensor of the sleeve at fixing assy. The fixing film assy.to be replaced or the film (to minimise the cost)may be replaced if the heater contact points are ok.
If problem still found check the rotation sensor .
Thanks.
Feb 06, 2015 | Canon iR 2016i Black and White Copier
My canon ir 3300 have fixing assy error e00001-0002
The fixing film unit faulty.Thermistor might have a short circuit.May also be the main power supply or DC controller PCB
Oct 22, 2014 | Canon 2 Ir3300 Ir3300i B/w Copier/ Network...
E000007 ir 2420l
problem with fixing assy
Feb 06, 2014 | Canon imageRUNNER 2200
Error code E000002-0000
try under service mode to clear error.
Press *
Press 2
Press 8
Press *
Choose COPIER
Choose FUNCTION
Choose CLEAR
Choose ERR
OK
Turn off and on.
If these doesnt helps, You need to change the fixing heater ( fixing film assy ).
Oct 05, 2010 | Canon imageRUNNER 2200
Canon Image Class 2200 Error code 0322 Can you help me with this problem It will not print at all
this means that you have problem with fixing assy. Best solution would be to replace fixing unit.
And,... did you consider to buying new one,... try with Canon image runner 3225N. Its a NORMAL copier. :-)
Jul 06, 2010 | Canon imageCLASS 2200 Black and White...
WILL NOT PRINT CODE E000002-0000
this means that there abnormal readings of temperature in fixing assy.
To get rid of the error you can do two things:
First:
Press * ( add. function key )
press 2
press 8
Press *
This will allow you to enter service mode.
Choose COPIER
Under FUNCTION tab, choose CLEAR and choose ERR
This will clear E002 error.
Turn off and on.
If it works, that means that because of i.e. blocked vent cover, or too much of a/c,... had influence on temperature readings in fix. assy.
If that doesnt help, you need to replace fixing film assy.
Hope that helped
Jun 04, 2010 | Canon (6981A002AA) for imagerunner 2200,...
I have Canon iR 2016 it show E808 code error
i have canon Ir2016 it give 808 error code can u help me please
May 29, 2010 | Canon iR 2016i Black and White Copier
CANON IR 3300 HAS ERROR CODE: E000002-0000
OK, but first try to clear the error under service mode, then replace fixing film assy, for EU 240V is FG6-6041.
To clear the error:
* 2 8 *
COPIER
FUNCTION
CLEAR
ERR
OK
Turn off and on ( main switch )
If this dont help - replace fixing film assy.
Dec 02, 2009 | Canon (6981A002AA) for imagerunner 2200,...
000014-000 this the error code. When I turn the copier on ... it tries to start ... then this code come on and it says call a tech.
E014
000 After the fixing motor drive signal is generated, the clock signal does not
arrive within 3.0 sec.
Main cause The fixing motor (M19) is faulty. The DC controller PCB is faulty.
Action
1. Connector
Is the connector of the fixing motor connected?
NO: Connect the connector.
2. Main power supply PCB
Is the drive voltage (24 V) of the fixing motor supplied by the main power
supply PCB?
Main power supply PCB: between J202-3 (24VU1-S) and J202-4 (OVU1)
NO: Replace the main power supply PCB.
3. Fixing motor (M19), DC controller PCB
Press the Start key. Is the lock signal of the fixing motor present at the connector
(J312) on the DC controller PCB?
Lock signal: J312-B4 (FSRM_LOCK*)
the DC controller PCB change from 0 to about 5 V?
YES: Replace the fixing motor.
NO: Replace the DC controller PCB.
BUT FIRST: did you removed fixing assy from any reason? If you did try to repositioned it. Check for any foreighn matters inside or around the fixing assy. Try to reconect the fixing assy connectors. Check gears of fixing assy and drive assy.
Nov 18, 2009 | Canon (6981A002AA) for imagerunner 2200,...
Canon Imagerunner 2220i Error Code E000000-0000
canon printer ir 2200 error E000000-0000 my help
Feb 05, 2009 | Canon imageRUNNER C3220 Color Copier
Canon imageRUNNER 2200 Logo
62 people viewed this question
old marine
old marine
