Question about Frigidaire Dishwashers
I have mod#GLD4355RF53 ser.#TH83039469 When you turn it on it turns off.I found out that it is vent system and this mod# has a manufacture flaw because they have vented to the back.
My sollution is to buy something else but buy the extended warranty. Keep reading to find out why.
I have the same model. Only 2 years old and either the control panel or module is out. $150 or $130 depending on part and I install. Then you have the risk of it going out again. It was a $600 + dishwasher. I'm pissed.
I am trying to sell it on Craigs to someone for parts as I hate to scrap it. Probably the moisture problem and the power surges did it in.
I bought a new maytag with the extended warranty and will probably extend it more. The problem is that all the electronics are sensitive, fragile, and expensive. No sense buying a new appliance without the warranty because no new appliance is reliable anymore. I threw away $600+ before and had I paid an extra $100, it would be fixed and still warrantied.
Posted on Jul 31, 2011
What is mfg date for Winchester mod 71, 348 wcf, ser # 12563
I believe the manufacture date to be 1937. This is according to the Blue Book of Gun Values 32nd edition.
Hope this helps.
Bob
Jan 18, 2015 | Winchester Optics
Can you guide me where can I find the right part number for Relay overload starter for my Whirlpool Gold Side-by-side fridge.Mod: GD5YHEXLS01 Ser: SP2325250 MFR DATE:06-03 I am not 100% sure if I rea
Go to sears parts direct web site and put in the model number. Found the page with unit parts our the page that list the compressor. It will have the newest part number
Feb 03, 2013 | Refrigerators
I have a goodman pack unit. mod. pgb036075-1-rev-a ser. 9703825493. Control board is showing a 3 flash which is a vent switch error but the two wires that come from the inducer motor go strait to the...
Make sure the plastic on the boards terminal connections are not disguising a weak connection. If those are good, use a manometer to check vent pressure at the inducer connection. If it falls below the measurements listed on the pressure switch then the problem is in the flu system or lack of combustion air. If the pressure does not drop below the listed measurements replace the pressure switch.
Dec 09, 2010 | Goodman GPC1342H21A Air Conditioner
Hi, In my refrigrator there is no water and ice coming.and i dont find where is the fiter.my refrigrator type is 2255a mod # ed2choxkb07 ser,# issu4235315.thanks
Since you did not provide a model number this is the best guess. On 25 Cu Ft and above models no matter the manufacturer most of the filters are in the left portion of the grille at floor level. You turn the tab and the filter pops free. If yours is not in this are just respond here with a model number and I will help you.
Kelly
Oct 03, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have a kenmore elite dryer mod c60952990 / ser mk0501696. it keeps shutting off after only about ten min. if you set the timer to 90min it still turns off after about ten min. same if you use the ''auto...
It sounds like it might be overheating. Could your vent be clogged up? When you start the dryer go outside to the vent to see if there is a real good flow of air coming out. If not, the hose or the insides of the dryer are clogged, or the hose is kinked. Sorry, I can't come up with anything else that would be an easy fix. Best of luck.
Jul 26, 2010 | Kenmore Dryers
My dryer is ot blowing hot air
Remove the heater vent, then turn dryer on. Does this fix problem? If so then you have a block in your vent hose.
Dec 31, 2008 | Kenmore 75962 Gas Dryer
Gas dryer won't dry
kbaker926:
This is a purchased product manufactured by another manufacturer for Sear.
It sounds as if have a flame sensor or a thermostat opening turning power off to the burner thus flame goes out.
If you are able to to catch the dryer just as it shuts off you would be able to do some ohms readings to find out what components have opened in the curcuit.
((((This is only if you are able to properly use and read a Volt-Ohm meter))))
These checks should only be done with the Electrical supply turned OFF and at least one wire disconnected from the component being tested
Woodychoppers
Oct 31, 2008 | Kenmore 75944 Gas Dryer
I HAVE DRYER GE MOD #DWSR488EB2WW SER#ZG743601A ***HAVE GRINDING NOISE. RELPACED THE BEARING IN THE BACK. BELT SEEMS OK. PUT BACK TOGETHER NOISE CONTINUED. THE NOISE HAS A SLIGHT GRIND/SCRAPE IN ONLY PART...
The most likely cause is the front drum supports. There are 3 or 4 teflon strips (about a half inch wide and 2 inches long) on the top of the front panel that the dryer drum glides on. When these wear down, the drum can scrape on the plastic that holds them or on the metal frame around the door frame. Another possibility is if the drum touches the dryer exhaust vent pipe, most often only if the dryer is vented out the bottom of the dryer and the vent pipe has shifted up just a bit, allowing it to contact a spot on the drum with each revolution.
Oct 02, 2008 | Dryers
Alignment page prints whenever I turn on printer. HP PSC 1401 Mod:Q7299A Ser:CN59622173
when you turn your printer on and it printed the alignment page, try to scan the alignment page. and then try turn it off and on if it still print an alignment page.
Aug 28, 2008 | HP Office Equipment & Supplies
Dishwashers Logo
96 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Garth Jackson
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
