Question about ASUS P4S800D-X Motherboard
Are there Win7 drivers for this motherboard? - ASUS P4S800D-X Motherboard
    President:
  • 2,571 Answers
You could have always looked on the asus support site :)
Always check your makers support page first, They should always have FREE drivers and software downloads, many of the other sites that offer drivers try get you to pay for them.
And No, there is only up to XP drivers, the support page is here http://support.asus.com/download/download.aspx?modelname=P4S800D-X&SLanguage=en-us
Posted on Oct 07, 2010
Is my linux computer compatible with windows xp software? are the parts interchangeable? example= installing a linux video card in a windows 7 tower?
Most devices that have Unix drivers will also have drivers available for some versions of Windows. Asus lists XP drivers for this board: http://www.asus.com/Motherboards/AMD_Socket_754/K8V_SE_Deluxe/#download . The K8V-SE Deluxe motherboard is not listed as Win7 compatible (but it's not listed as known incompatible either). To test if this board is Win7 compatible, update to the most recent BIOS, then use a Win7 install DVD to search for drivers and other support. (I know the Windows Update disc confirmed that my WinXP box would support Win7.)
For moving components into another computer, you will need to identify the exact device that you want to move and the slot/interface for that device. For example, since ASUS K8V-SE Deluxe motherboard has an AGP video card slot, it will not fit in a newer tower with only PCIe or PCI slots. If your Win7 tower does have an AGP slot, you may need to look in will amongst the drivers for "legacy cards". Finding an XP driver will be fairly easy. The Windows 7 driver may not exist and Win7 may not run without an external video card (if it can load at all).
I hope this helps. If you are looking at a different motherboard or wish to check specific components, please add a comment with the make and model of those parts. I'll be glad to try to find additional information. Include in your comment whether the Win7 tower is/will be running Windows 7 32-bit or 64-bit. Drivers for the 32-bit Windows are more common since they don't need the signature. (To check if a Windows machine is currently running Win7 64-bit, click Start > Control Panel > System and Security > System. If the title ends with x64, it's the 64-bit OS. Otherwise it's the 32-bit version.)
May 11, 2012 | ASUS K8V-SE Deluxe Motherboard
Ethernet drivers looking P5LD2 motherboard OS win7 help my please thanks
I am not sure if the motherboard has been certified for Win7.
However the Vista LAN drivers are available from this site.
Sep 15, 2011 | ASUS P5LD2 Motherboard
I need a driver for motherboard asus M2V for win7 os i havent sound on my compuer
looks like your motherboard cannot support win7 operating system.
make sure if *********** compatible with windows 7 version.
if the motherboard cannot support , no drivers fit for it.
Feb 05, 2011 | ASUS M2V Motherboard
I have istalled windows 7 and sound not there and no transpirancy pack .i want drivers
No drivers for Win7 available for hardwares....the only way to get drivers is to update your Win7 ffrom MS website after registering your copy of Win7....
if found fake..it will block all updates...
Nov 01, 2010 | ASUS P5PE-VM Motherboard
Hello! I have the exact same problem that widdejay had on 27th january 2010. I have the same asus motherboard and just installed Win7 but i don't have sound because of the same error on the high definition...
ASUS P5GD2-X Driver Download
Select Product: Motherboard
Select Series: LGA775
Select MOdel:P5GD2-X
*If the driver for Windows 7 is not available you can use the Windows Vista Driver. Just make sure to check the version of the OS for Win7 32bit download Windows Vista 32bit Driver for Win7 64bit use Windows Vista 64bit
Thanks for using Fixya
Jul 15, 2010 | ASUS P5GD2-X (610839128686) Motherboard
Drivers for win 7
*This motherboard dont have a driver for Windows 7 however you can download the Windows Vista driver for you Windows 7, If youre using Win7 32bit download WindowsVista 32bit for Win7 64bit use Vista 64bit.
Download Here
*Product Type: Motherboard
*Select Series: SocketAM2/AM2+/AM3
*Model: M2N-MX
*Operating System: Depends on your OS
*Chose which driver you want to install and download.Thanks for using Fixya.
May 20, 2010 | ASUS M2N-MX Motherboard
Lan drivers & draphic drivers are not installing. Im using win7
There are no drivers available or needed for this board under Win7.
Optionally you may use this tool (http://www.intel.com/support/motherboards/desktop/detect.htm) to detect any drivers you may be missing. Your biggest problem may be that Win7 hasn't detected your Lan card and update isn't possible. If this is the case try installing a USB Wifi Card and doing the update. Win7 will automatically find the drivers and install them for you with update.
Mar 07, 2010 | Intel D845GVSR Motherboard
Cant detect MSI 661FM3-V LAN driver for win7
eventually through continued research, i found out that this is a common issue with several mobo ang win7... SIS driver for LAN was the answer. i just downloaded the driver then install manually. although there is still no driver support intended for win7 as of the moment, vista driver does the trick...
Feb 01, 2010 | MSI 661FM3-V Motherboard
ASUS P4S800D-X Motherboard Logo
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
