Question about Canon Office Equipment & Supplies
I have a canon mp560 I cannot figure out how to get the ink cartridge out to change black and white cartridge
  • slonde Oct 07, 2010
    yes, perfect thanks so much..
  • 2,272 Answers
You just need to lift up and open the printer`s cover, wait for the cartridge cradle to stop, unplug , slowly pull out cartridges, remove the protective tape from new ones and then replace them gently until the new cartridge clicks. Here is the link to the canon mp560 manual which shows all instructions and pictures to remove and install cartridges. http://gdlp01.c-wss.com/gds/6/0300002426/03/MP560_GS_U2_V2.pdf
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation
Posted on Oct 07, 2010
My Canon MP560 won't print black
I have problem with my canon IR 2420 DISPLAYING E000007-0000
WHAT CAN BE APROBLEM
Nov 17, 2013 | Canon MP560 All-In-One InkJet Printer
My canon pixma MP560 is not printing black even though I have a full cartridge
Remove your black cartridge and check that the ink might be over flow or block.... so clean it up with soft paper... thanks
Aug 31, 2011 | Canon MP560 All-In-One InkJet Printer
Hi. I have a Canon MP560. How do I print in only black and white, using only the black ink? Grayscale mixes in coloured ink. The printer will not print at all unless there is colour ink in it. I only print...
Hi
Follow these steps;
- Open the document you want to print - Go to 'file' - 'Print' - click 'properties' in the print window - in the menu select 'Maintenance' - in the 'Maintenance' click 'Ink Cartridge Settings' - select 'Black Only' - click 'OK' - again click 'OK' - now you can print only using the black ink in the printer.
Hope this helps, Please rate if this solution was helpful. thanks!
Aug 27, 2011 | Canon MP560 All-In-One InkJet Printer
Can not find the serial number
In the Canon PIXMA MP560 printer the serial number can be found inside the printer. Lift the lid as if you were going to change the ink cartridge. When the cartridge slides to the left, you will be able to see a small white sticker inside the track with the serial number printed on it
Thanks,
E-ware
Jul 26, 2011 | Canon MP560 All-In-One InkJet Printer
I have set the Canon MP560 printer to print grayscale (black and white) but it still uses the color cartidges, apparently to periodically clean the nozzles so they will be able to print when needed. So I...
Canon has made there printer this way to SAVE on your black in and also to lubricate the print heads and other technical reasons.
To be honest I do not think its in your best interest to override the settings on this print due to the cause of damage to the print head and other sorts of failure.
There are chip re setters and other forms of ways to trick the system, These Void the warranty and thus Canon does not allow for this type of compromise to save ink. the best thing you can do here is purchase a ink kit with a chip that uses a contentious flo system to save you on ink purchases and money.
Here is a link to a example http://www.amazon.com/FantasyBuy-Bulk-Continuous-Ink-System/dp/B002T046TU
Good luck with your printer I hope this is a solution that best suites your needs to save money.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Nov 30, 2010 | Canon Office Equipment & Supplies
Where is the serial number on my pixma mp560 printer?
Good day.
It is normal to locate the serial number at the back of the printer but in the case pf MP560 printer, the serial number is located inside the printer. Open or lift the LID just like when you are changing Ink Cartridge. The cartridge assembly slides to the left, there you will see the white sticker inside the track with the serial number.
Just let me know if you still need some help.
Good luck.
Tedmac
Oct 01, 2010 | Canon MP560 All-In-One InkJet Printer
My Canon Mp560 wont print because one of the black cartridges does not have ink although the others do. and i want to print but it is telling me that i need to change that one cartridge. please help!
This printer has and ink flow detection system to prevent "dry-firing" of the printhead which can cause damage. You will have to replace the cartridge in order to print on this model.
Sep 30, 2010 | Canon MP560 All-In-One InkJet Printer
Hi, I have a Canon Pixma MP560, and whenever I try and print something in black and white it comes out with a pink tint to it. Hope you can help.
Possible that the Ink cartridge or the head is faulty. Ink drying can make this imbalance of colours , so check to correct with the properties of the printer, If not clean several times to see any changes come about with a test print.
The last can be the ink/head unit.
Sep 20, 2010 | Canon Office Equipment & Supplies
Where can I find the serial number on my canon mp560
For Canon PIXMA MP560 printer the serial number is INSIDE the printer. Lift the lid as if you were going to change the ink cartridge. When the cartridge slides to the left, you will be able to see a small white sticker inside the track with the serial number printed on it.
Feb 11, 2010 | Canon MP560 All-In-One InkJet Printer
Canon MP560 ink level override
Just press and hold down the STOP button :) Works a treat :)
Dec 28, 2009 | Canon MP560 All-In-One InkJet Printer
old marine
old marine
