Question about Kenmore Refrigerators
The lights are on when I open the door but the firdge is not cold tried turning it u but nothing happens.
  • Kenmore Master
  • 43,501 Answers
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Oct 08, 2010
I am getting an error it is as follows: finished, spin, and wash lights blinking plus 3 beeps. What does this mean?
Try restarting it, make sure the load isnt to heavy, if that does not help, call a local repair man.
Nov 06, 2013 | Bosch Nexxt 100 Series WFMC1001UC Front...
My hotpont aqurius wml 560 has a problem once you have loaded the machine closed the door set your cycle press start the door locks and the led illuminate but nothing happens it normally starts to pump in...
g'day, sounds like the solenoids in the back aren't letting water in. The solenoids are what the hoses are hocked onto. They are like an electrical tap. These are not pumps, water is only pumped out of a washing machine. Some reasons why water is not coming in: - Taps are not turned on (Keep it simple), turn taps on. -Hot, or cold solenoids are not working. (Lets hope chances are only one has broken). Swap cycle options, try just hot, or just cold options. If one works and not the other, a solenoid is not working. just put either hot or cold on the solenoid that is working. Note, some new machines only have one hose at the back, this is because they heat the water internally - like dishwashers. If this is the case, a new solenoid can be purchased and installed. -Another reason might be that solenoids aren't getting power. This cold be because the trip switch in the door. A common problem. Think of the trip switch just like the light in the fridge. When door is opened, switch is opened. If u can test machine on spin cycle ie, the machine spins, then this is not the cause. Some appliances even have switches on soap draws so check that out aswell. hope this helps
Aug 07, 2011 | Washing Machines
Firdge turns on but never gets cold. Runs constantly. Refridgerant maybe?
Is the condenser fan turning? Is the evaporater fan turning? Check the evaporater at the freezer compartment it should have fine frost all the way if no frost or partly frosted may be low on freon.Be sure there is no air leaks around door or something. Hope this helps.
Dec 23, 2010 | LG (LRBC22522ST) Stainless Steel
Security light will not work
You must have a three function wall switch. This means in addition to a button that opens and closes the door there are two other buttons on the same wall switch. One is marked LIGHT and the other is marked LOCK.
To have your lights come on automatically when you walk into an open garage you must START with the lights ON. To turn the feature on, turn the lights on manually with the wall switch, then press and hold the LIGHT button for about 10 seconds until the motor unit light bulbs flash. Now, if the light bulbs are on, manually turn them out and then walk out through the open door. The light bulbs should come on.
To disable this feature, start with the light bulbs OFF and everything else is the same.
Aug 12, 2009 | Sears Craftsman LiftMaster Chamberlain...
Flashing lights on hotpoint fridge
I have a hotpoint future FF187E both lights are flashing how can i stop them flashing ?
Aug 04, 2009 | Refrigerators
Garage door opener won't open garage door
Remove the cover and take a look at the drive gear. It sounds like it is stripped.
May 23, 2009 | Sears Craftsman LiftMaster Chamberlain...
Firdge not cold on a combi fridge freezer
possible ice build-up behind the inside rear panel. you have to remoive panel defrost ice with hair dryer then replace the heater/defrost cable. the job cost around 125. for an appliance tech to fix it hope this helps...
Sep 22, 2008 | Refrigerators
Fridge freezer door alarm continuously beeping
make sure gasket is sealing also make sure light is going out.
Jul 17, 2008 | Freezers
Firdge freezer
This is caused by one of several things:
  • door left open
  • bad gasket
  • open liquids in fridge
  • dirty condenser radiator...clean it
  • low gas in refrigerant system
Defrost the unit completely and restart. If it happens again, suspect the last and get a service person in.
May 27, 2008 | Freezers
Refrigerators Logo
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
