Question about Cameras
Canon 400d DSLR error 99
Put my new 50mm EF f/1.8 lens on came up with error99. Never happen with kit lens.
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 480 Answers
Hey cookie8,
According to the manufacturer you should try cleaning the lens contacts, which I usually use a rubber eraser to do this. If this doesn't work try removing the battery, and if it's not charged charge it then reinsert the battery. If neither of these options work I would have the lens looked at by an authorized service technician, and of course if there is something wrong with the lens and if it's new you might be able to exchange it for a new one thru the retailer you purchased it from and if not it should be covered under the manufacturers warranty. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Posted on May 29, 2008
Can u tell me how i fix error 99 of canon zoom lens 75-300mm
This article will lead you through the steps to identify the cause and a possible fix for this error.
http://www.richardsnotes.org/archives/2005/04/29/50mm-lens-contact-points/
Oct 12, 2010 | Canon 75-300mm f/4-5.6 III USM EF Lens
Canon ef 50mm 2.5 macro autofocus broken. Buy new or have it fixed ?? can u advice ?
I thought mine was broken but i cleaned off the copper tips on the bottom with a clean eraser very gently, and afterwards i put on the lens and it worked. I would give that a try if you have not already
May 10, 2010 | Canon Normal EF 50mm f/2.5 Compact Macro...
What is error 99
What wide angle lens is it need f number it may be to old to work on eos 400d
Dec 27, 2009 | Canon EOS 400D Digital Camera
My new 400D with kit lens produces dark pictures. I tried everyth
take it back and get it replaced sound like your shutter Assembly went out.
Jan 06, 2009 | Canon Digital Rebel / EOS-300D Digital...
Error 99
WHAT IS THE SOLUION OF ERROR 99
Aug 05, 2008 | Canon EOS 400D / Rebel XTi Digital Camera...
Error code 99 canon E0S 450D
Try this:
Jun 14, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Error 99
i had the same problem and i found this guide online fixed my problem
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99′ message appear? If it does, then the camera should be
serviced. If it does not, then please proceed to the next set of steps:
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the “ERR 99′ message appear? If so, then the CF card is the most
likely source of the issue. Try using a different card.
If the message does not appear, please complete the following steps:
2. Clean the lens contacts by gently rubbing them with a pencil eraser
or soft cloth. Be careful that you do not let any debris fall into the
camera body.
3. Reattach your lens.
4. Turn on the camera.
Apr 19, 2008 | Canon 75-300mm f/4-5.6 III USM EF Lens
Error 99 in canon 400D
You will get that error when using some lenses other than Canon. A lot of the older Sigma lenses have that issue. Do you get this error when using newer Canon EOS lenses?
Apr 01, 2008 | Canon Digital Rebel / EOS-300D Digital...
Cameras Logo
405 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
