Question about Toshiba 61HX70 61" Rear Projection Television
Was told power unit had to be replaced how much will that cost?
  • 20 Answers
If you are handy with a soldering iron you can do the repair yourself. 90% of power problems stem from cracked solder joints on power board & convergence board. All you need to do is heat up the existing solder and add a little fresh solder to the joint. I had a power problem on my Toshiba 50". Service guy told me a new board would be $165 + $150 for labor. I wasn't paying that so before trashing it I grabbed my soldering iron and resoldered every joint on the power board and convergence board. Bingo! No more power problem and it only cost me $25 in supplies.
Posted on Oct 07, 2010
I have a Carrier split air-conditioner which is flashing 7 indicating a communication problem. On inspection of the outside unit I found the supply fuse had blown. After replacing fuse unit continued to...
Does the board power off 24 volts or 220? Be sure you have low voltage to the board as well. I would bypass the board if possible before scrapping the whole unit. Good Luck!!
Apr 25, 2017 | Carrier Heating & Cooling
Hiyundai i10 power streering problem
you can ask for a part number & try to buy it from another source.
you can ask that they return the old item to you after replacement, the part numbers on the invoice & on the old unit should match.
May 19, 2017 | Hyundai i10 Cars & Trucks
I am told that getting a replacement coil for this ac unit would be next to impossible. Where could I find one for this unit.
who ever told you that gave you good advice. IF you find a new coil the cost to insall it will be ... welll .. costly. I am not certain how old the unit is but if it needs a new coil because its been punchered or has corroded . Your mony ahead in the long run to replace it. If its just a small puncture it can be fixed easily .. Hope this helps let me know
Aug 02, 2011 | Goodman PHKJ048-1 Air Conditioner
No Picture
Just replace the unit. There's only 2 replaceable parts on this unit, both costing over $300, add on labor charge and you're easily over $500. There used to be a recall on these units but the manufacturer is no longer honoring that.
Apr 05, 2010 | Memorex MLT3221 32 in. LCD TV
Fuel guage light always on even when full. engine light always on. i was told it would cost 500 to 800 dollars to fix the fuel light issue. i was not told what the problem would be but this sounds rather...
your feul sending unit is bad. everybody replaces the whole unit nowadays because it includes a new feul pump as well. that is a good price if it is the pump and sending unit together. our suburban repair shop was $1238. we did it our selves for $300 and it took 8 hours to do
Dec 31, 2009 | 2006 Chevrolet Trailblazer
WE have a Carrier 38HDC AC unit outside. The
Get a second opinion from another service company. Most all service companies give free estimate. That way you know up front the cost. Russ
Aug 24, 2009 | Heating & Cooling
Cl500 cd tv radio unit
if you dont want to buy a new radio install a toggle switch to both of the power wires. you will keep losing your presets btu at least it wont run your battery down.
Jun 10, 2008 | JVC KD-LH7R CD Player
Accordianman--Dual deck VCR not responding...
No. Sound like the Switch mode power supply is or has failed, to repair this would involve replacing capacitor and or some componets, Many repair shops these days have discontinude repairing VCR's becuse most of the time you can replace the entire unit for the cost of repairing it
Feb 24, 2008 | Televison & Video
Dell 4201c power problem
I am an actual Dell repair tech for a non-Dell refurbishing company. I fix this model exact model, as well as all the other plasma TV's that Dell has come out with. If you are looking for a replacement part I suggest starting with either the power supply. But if you are electronicly inclined, I suggest taking voltage measurements across the labeled parts on the power supply that are the following: VS, VSCAN, VSET, VE, and VA. These correct voltage measurements are labled on a sticker in the top right corner of the TV. If they all come out right then your best bet would be the Y-main board with both upper and lower buffers. They are the circuit boards on the left hand side of the TV. As far as getting the parts, thats a whole other story but I hope this helps to narrow down your parts search.
Feb 03, 2008 | Televison & Video
The unit powers on and off.
There is a short somewhere in the sweep Horizontal, or vertical, or the sweep power supply has a fault. not really a job for the consumer , unless you know about solid state electronics.
Sep 13, 2006 | Sony Grand WEGA KF60XBR800 60" Rear...
Toshiba 61HX70 61" Rear Projection Television Logo
57 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
