Question about Stackhouse Seiko S129 Printing Stopwatch
I have 2 Seiko s129 system stop watches. New, tested batteries. The paper advance will forward the paper, but nothing else seems to work.
  • 3 more comments
  • aj_utterback Oct 07, 2010
    Not helpful, no code on back of unit.
    Anything else.....?
    Seiko system stop watch/printer s129 does not start. Has good batteries and the paper advance works. Help!
    Arnold
    Not what I wanted to hear. I have an event Saturday morning and do not have time to return these. The third one I have I cannot turn off. It works the stop watch without the batteries even installed.
    If nothing else, can you point me to owner's manual or user instructions for this unit. Can you refer me to an actual shop in the Sacramento, CA 95816 area to check these out or repair. Desperate for help
    here. Thanks!
    Arnold
    Any response to my last comment.............?
  • 3,083 Answers
Sony uses a thermal paper, so the most suspect component would be the heating element for the head, or perhaps old paper, which has lost it's thermal capabilities. Since it's new, the paper should be good, but could be shelf-aged perhaps.
Here's a page link to order new paper:
http://www.google.com/#sclient=psy&hl=en&q=+Seiko+S129+thermal+paper&aq=f&aqi=&aql=&oq=&gs_rfai=&pbx=1&fp=6248f386b3c06fd8
Some sites report this watch as being discontinued, so you may have to contact Sony for support or parts, if available:
http://www.seikowatches.com/support/customer/index.html
I couldn't find any blogs about these units being repaired, so couldn't get any hints about testing the thermal head unit.
Good luck, and hope this helps.
Posted on Oct 08, 2010
    Genius:
  • 1,478 Answers
From my point of view, what could have cause this problem is the battery, but since you said you have anew battery, the problem could be factory defects on the unit, i will advice you return the unit for replacement.
Take care.
Posted on Oct 07, 2010
    Brigadier General:
  • 3,513 Answers
Please check the bellow link if it helps:-
http://caliber.seikowatches.com/
Please accept the solution if it's helpful. Do get back to us for any further query.
Thanks for contacting fixya.com
Hi my edifice era300rb second hand does not stop at 00 whereas it stops two seconds forward 00
I had this on a Seiko after having the battery changed. With mine, you pulled out the crown one stop, and pressed the button that controls the hand you want to move. Each press advances one second.
Sep 05, 2015 | Watches
Seiko SGF204 second hand hesitates or jumps a second and looses probably 10 minutes an hour. Any suggestions would be appreciated. Thanks
When the watch jumps a second or seems to stop then tick twice, it indicates that the battery is low. You will need to take your watch to have the battery replaced.
Feb 28, 2011 | Seiko SGF204 Wrist Watch
I have a seiko stop watch s129 that only has a streight line going through the middle of the screen horizontal
The LCD is having issues. The Seiko Service Center is the only place to repair this watch. Contact them at:
(800) 722-4452
Jan 19, 2011 | Seiko S149 Stopwatch with Built In Printer
I have a Seiko Titanium Chronograph certified water resistant to 20 BAR. The movement # is 7T62-0BZ0. I recently had a jeweller put a new battery in the watch and it has not been working properly since. I...
DO AMASTER RESET TO YOUR WATCH!PULL FULL OUT THE STEM(CROWN)THEN TURN THE HANDS TO THE RIGHT TIME THEN RESET THE CHRONOGRAPH AND THE ALARM WITH THE TWO BUTTONS(SEE YOUR MANUAL.IF YOU HAVENT TRY TO DOWNLOAD IT FROM ANY SITE OF SEIKO SUPPORT).THEN PUT THE CROWN IN.IF THE PROBLEM REMAINS THE ONLY SOLUTION IS THE SIKO SERVICE!THEY ARE NOT EXPENSIVE AND MAKE GOOD WORK!DONT GIVE THE WATCES EVEN FOR THE BATTERY TO THE MONKEYMAGICIANSGURU JEWELERS THEY ARE WATCH RUINERS!
Dec 06, 2009 | Seiko Alarm Chronograph Titanium CASE AND...
Seiko flightmaster fitted new battery watch wont work atall
Most likely the watch was damaged when the battery was installed. Quartz watches have fragile parts in them. The coils for instance are made of wire thinner than the hair on your head. It takes almost nothing to damage these wires and the coil. Dirt is a big problem. Since a quartz watch has no force behind the gear train the smallest particle of dirt can stop a quartz watch.
Either your watch will need a cleaning or damaged parts will need replacing.
A qualified watchmaker can do this work and get your watch back in working order for you.
Hope this helps,
Ken
Yellowstone Watch Inc.
www.yellowstonewatch.com
Oct 31, 2009 | Seiko Diver's Watch
The Seiko s149 will not display anything on the screen.
We had to change the internal battery on ours today. There are 4 screws on the back of the case and 3 inside the AA battery compartment. Careful pulling the front and back apart as there are some wires that attach between the two. Two of the three screws need to be removed to get the CR2430 battery out to replace it. We now have the watch screen...just need to remember how to operate it...need a new users manual.
Sep 25, 2009 | Seiko 300 Lap Memory Stopwatch
My seiko kenetic watch stopped, and will not say wound
I thing required cleaning for the movement and new capacitor.
AmFix Jewelry & Watch Repair
203 N. LaSalle Street,
Chicago, IL 60601
Ph: 312 641 7000
Email: info@goamfix.com
Web: www.goamfix.com
Sep 24, 2009 | Seiko Kinetic watch
Seiko M705 - 5A10 series divers watch. Time is Frozen
Have the batteries checked and an "AC" done to it. These watches generally have several batteries and the die off can be slow and only fail partially. The "AC" or all clear function will reset the circuit board and bring all your functions back.
As with any dive watch, be sure that you take it to a watch maker/technician that can reseal and pressure test the watch to insure it is safe for diving.
Sep 18, 2009 | Watches
Seiko Kinetic that doesn't work
This watch does not have a battery, but has a capacitor which is rechargable. It is not taking a charge, and needs to be replaced. You should take it to a store with a watchmaker ON THE PREMISES. Or you could send it to: www.bscwatchrepair.com
Jun 27, 2007 | Seiko SKA192 Wrist Watch
Stackhouse Seiko S129 Printing Stopwatch Logo
580 people viewed this question
Top Stackhouse Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you a Stackhouse Exercise and Fitnes Expert? Answer questions, earn points and help others
