Question about LG Super Blu BH200 Blu-ray and HD-DVD Player
DVD BD-300 BLU-RAY, Don`t play regular DVD or AVCHD Serial:809KVN031175 Note:It`s like that since I bought it in 2008
  • leo_drouin Oct 07, 2010
    Note, BD300 play Blu-Ray from the stores,but won`t play reg, dvd or copy!
  • 712 Answers
This is a very common problem to BD300. LG customer service says that it's a known problem, but they don't have any fix for it.
Posted on Oct 07, 2010
    President:
  • 2,777 Answers
This unit has never played DVDs? It definitely should, that means there is something going on with the DVD module in the machine. It has had this problem since day one?? You should have definitely returned the unit and got a new one, or at least sent it back to the manufacturer for a replacement...
At this point it needs fairly major service here.
Thanks
Tim
I have region free blu-Ray discs and they won't play in my Samsung bd-h6500. Can you help me unlock the player?
If you have region free blu ray disks then they will play in any blu ray player, the player does not have to be unlocked!
Sep 05, 2016 | Samsung BD H6500 Smart Blu ray Player
How do i get my samsung c5500c to play my blu ray movies
If none of the bluray movies playing then your BD optical has failed. Get a technician to check the unit phisically.
Jul 04, 2014 | Samsung Televison & Video
Dmp-bd87p-k won't play avchd videos
Through simple steps, this professional AVCHD to DVD Converter gives you an easy way to convert AVCHD to DVD without video quality loss so as to burn AVCHD to DVD to play AVCHD on DVD Player.You find it at
http://www.avdshare.com/play-avchd-on-dvd-player
Aug 19, 2012 | Panasonic Televison & Video
I bought a Samsung BD C6900 from USA designed for region 1 and A . Living in Europe I cannot play my european DVDs and BDs ? Are there any solutions to change the region code ?
Here is a solution: http://www.videohelp.com/dvdhacks/samsung-bd-c6900/10895
Please note, however, that even after region code hack, it may remain NTSC only, so if you are planning to play European DVDs recorded with PAL system, it may not work.
Feb 27, 2011 | Samsung BD-C6900 Blu-ray 3D Player
My Samsung Blu-Ray player P1590 doesnt play regular DVD's. is this normal? Whenever I put a regular DVD it tries to load but it eventually posts a message on my TV screen saying "unable" to...
I have a Samsung BD-P1490. When I turn is on the display reads "Load." It never displays "No Disc", or trys to play a disc if one is present. I have never updated the firm ware. Any ideas?
Jan 20, 2011 | Samsung BD-P1590 Blu-Ray Player
BD-p1500 no disc error plays blu ray movies fine but will not play regular DVDs. Comes up and says no disc
need to contact SAMSUNG CUST. SERVICE, they will inform you about a new firmware update need to be done to your unit , beware shipping will cost you around $40.00 , hope this information is helpful , AJ
Aug 08, 2009 | Samsung BD-P1200 Blu-Ray Disc Player
Did not burn dvd
The DW-100 burns files in the same format as they were originally recorded by your camcorder. The Canon Vixia HG-21 records in AVCHD--a high-definition format--which is completely different from standard-definition DVD and which is not compatible with regular DVD players (even though the disc itself is a standard DVD-R). As it states in the manual for the camcorder, "High-definition (AVCHD) discs created using the optional DW-100 DVD Burner can be played back only with AVCHD-compatible DVD players."
The DW-100 is really more for archiving your files in their native format than for creating standard DVDs that can be played on regular DVD players. Regular (standard-definition) DVD players can't play AVCHD, although many Blu-Ray players can. Unless you use a Blu-Ray player that supports AVCHD playback, there are two solutions to your problem:
1. If you want to keep your recordings high-def, you can view them by playing them back with the DW-100, which must be connected to your camcorder via the USB cable, then from your camcorder to your TV via an HDMI cable.
2. If you want to have standard DVDs that you can play on any DVD player, either import the files to your computer and convert them to standard-definition using video-editing software, then burn them to DVD with your computer's DVD burner, or connect the analog output (component=better, composite=good) to a stand-alone DVD recorder (i.e. not the DW-100).
I've used the route of Vixia HF-10 camcorder > composite output > Panasonic DMR-ES25S DVD recorder (about $65 used on eBay) with pretty good results when I've wanted to give videos to relatives who don't have Blu-Ray players. You just have to make sure to set the camcorder 's analog (composite) output to 480i so that it formats the picture in the right aspect ratio, or else the 16:9 image will be squeezed to 4:3 instead of letterboxed.
Hope this helps. Good luck.
Mar 19, 2009 | Canon DW 100 DVD-RW Burner
I have a Samsung BD-P1000 Blu-Ray Disc Player that will not play Blu-Ray discs rented from BlockBusters in Calgary, Alberta, Canada. To Date, of all my 100 regular DVD, and approximately 25 owned Blu-Ray...
BD-P1000 Update Solution
The solution that worked for me: I went to www.samsung.com/ca and downloaded the Samsung BD-P1000 player's firmware update to my desktop. When opened, I was directed to"burn" a DVD on my computer. I then inserted the new DVD in my Blu-Ray player. The player automatically checked and confirmed player model number and registration and uploaded information from the DVD and the update was complete. The BD-P1000 then flawlessly played the rented Blu-Ray disc of "The Scorpion King".
Thank You Samsung!
Nov 27, 2008 | Samsung Televison & Video
LG Super Blu BH200 Blu-ray and HD-DVD Player Logo
131 people viewed this question
Computer Repairing
Computer Repairing
