Question about Cameras
My camera is froze with no display screen and just the one green light stuck on
  • Cameras Master
  • 17,130 Answers
The error is due to failure of the main control system. You can remove battery and card replace battery and while switching on tap the lens hood on your palms so as to disengage any dirt or mechanism being struck that is making the power switch off or hang up.
Use some air to blow between the lens to dislodge any sand particles struck inside.
If none of these works then you can think of taking consensus with the service centre.
get estimate before you decide.
Posted on Oct 07, 2010
No picture display or image when I turn the camera on
Did you try to press the display button on the back of the camera?
With the display button you can cycle through different things on the display. One is power save and it will display nothing. Perhaps that is everything you have to do. If that does not work, let me know.
Dec 16, 2013 | Canon PowerShot SX30 IS Digital Camera
Lens froze position
I've just got the same problem, don't know what to do!
May 04, 2013 | Nikon COOLPIX L810
Last week I was taking pictures outdoors, later on that day my screen went totally black, the green light comes on but the screen continues to stay black, I have changed the batteries
One of three possible problems. First check that you didn't accidentally press the DISP or DISPLAY button. If that's not the problem...
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Finally, it could be a loose or poor connection of the screen's flex cables, a very common problem for your model camera. The A620's vari-angle screen is a great option for a camera, but with this moveable screen, the screens data and power cables can and do wiggle loose. It is actually relatively easy to fix by just reseating these cables, but will require opening the back face of the screen of your camera.Please see this other person who had a similar problem with an A630.
May 05, 2010 | Canon PowerShot A620 Digital Camera
Just froze! Stuck on nokia screen, wont turn off without taking the battery out
I just fixed this problem on my 5800 nokia screen problem doing the following: waited till the battery ran off took off my mini sd card and then charged it for a while and switched on.
hope it helps! :D
Nov 03, 2009 | Nokia 5800 XpressMusic Smartphone
The stupid thing won't power up anymore. I try and cut it on and the green light just flickers then goes off. it froze when the lens was out too which means its been stuck that way for a while. I didn't...
I found that cheap (new) batteries will not work in my camera. Duracell or Rayovac seem to work best.
I added 2 (new) cheaper batteries it took 1 picture the lenses would not retract and the battery light flickered. I found 2 new Durnacell and it works fine now. Hope this helps.
Oct 14, 2009 | Samsung S860 Digital Camera
NO LCD IMAGE / LENS STUCK
hi ban ive same problem bloody nusience lens wont retract what did u do with urs?
should i return it?
thanks leeanne
leeannehutchinson@btinternet.com
Feb 17, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Les extended, screen remains black
tuen on camera then press display a few times. it sounds like the display is just turned off. the lens system should be open.
Jan 03, 2008 | Pentax Optio S50 Digital Camera
Camera will not stay on.....
the 3 beeping sound means that the camera has low battery capacity. the lens is stuck out because there is incorrect battery connection. there is an option on the camera setting for the battery type. try this one:
-turn the camera on
-click on Menu button
-select options using left/right, up/down button
-select Set up 2
-Select Battery type
-Select Alkaline for non-rechargable
or Ni-MH for rechargable
-click OK button
this setting should be done when using camera for the first time and whenever you are switching battery types, from rechargable to non-rechargable and vice versa.
Dec 04, 2007 | Samsung Digimax S500 Digital Camera
Canon ixus 55 - stuck in open position after sand intrusion
DON`T OPEN THE COVERS - YOUR SELF!!...You have to use ESD!!! Your cameras optical-unit needs operation. It`s not "self-made"-project!
May 10, 2007 | Canon PowerShot S400 / IXUS 400 Digital...
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
