Question about Gateway GM5084 PC Desktop
I replaced my mobo but need help with rewiring it. I have 2 cables, 1 solid black the other twisted orange,black & green wires with a twisted blue & white wires. Both have 9 female connectors. I see 2 9 male connections on the mobo but I don't know which goes where. I took pictures before removing everything but my wife lost the camera. I don't want to gamble connecting them to the wrong spots & possible short out the mobo. Any help would be greatly appreciated.
billspeer
  • 180 Answers
SOURCE: The male pin connector for the cpu fan shorted out .
Not so much a reroute as a different source. Do I assume you have perhaps a smaller 3-pin connection and would rather go with a larger 4 pin (or vice-versa)? There are splitters that will let you run a second 4 pin off of a single connection (about $5). If you want a 3-pin, there will be a space for that on your motherboard. Ensure when buying a new fan that it has the proper connector if it doesn't come with both.
If this isn't what you were looking for in an answer, could you explain what it is you're trying to do? Thanks
Posted on Feb 11, 2009
ipodslinger
  • 688 Answers
SOURCE: HP W2338 MONITOR GATEWAY 6800
you should be able to either get the right cable or get an adapter at a computer store.
Posted on May 31, 2009
  • 1082 Answers
SOURCE: Replaced the Ram and Hard Drive.Green light on
Leave the disks off and see if you can get to the BIOS. If so, that probably is your problem. Set the BIOS to reflect the disks you have.
Posted on Mar 14, 2010
  • 318 Answers
SOURCE: Hello. I was cleaning the dust out of my computer
Those are the power switch button wires. They should slide onto the motherboard only one way. Look very carefully and the plastic should be molded for one fit.
Posted on Jun 14, 2011
  • 131 Answers
SOURCE: motherboard layout diagram Gateway GT5654
usually if the wires have a name on the end of them check your motherboard very carefully probably with a torch or lamp you will see the same name as on the end of those wires on pins connectors on the motherboard if it says audio ac'97 on the end of the wire you will find the ac'97 pins on the motherboard then connect if it doesnt work take out and turn the connection around the other way to see thats all i can offer hope it helps
Posted on Dec 17, 2011
I have two phone lines one for phone and one for fax is there any way i can connect my fax machine to the fax line only and not have to use an adapter
You can have the single out jack replaced with a dual outlet jack. To rewire it yourself, use the Blue/Blue White wires for Line 1 and use the Orange/Orange White wires for Line 2. If you older wiring then the colors are Green/Red for Line 1 and Yellow/Black for Line 2.
Jul 08, 2014 | RCA 25201RE1 Corded Phone
Tip
Telephone jack wiring
Most cheap jacks have 4 wires, red, green, yellow & black. Most modern houses have wires paired up (twisted pair) like blue & white with blue line or stripe. Line 1 is red/green or blue/white. Line 2 is yellow/black or orange/white(with orange line/stripe).
on Feb 21, 2015 | Lands Phones
GE Network & Coax Wall Plate has 8 wires of solid colors. My CAT5E cable has 8 wires, only 4 of which are solid and correspond to 4 of the solid colors on the wall plate. The other 4 wires on the CAT5E...
Hello
Your cat5 will make up 4 pair. org/org/wht being one pair and so on.
So as long as you keep them in pairs you will be ok.
Meaning. Pair one from cat5 org and org/wht to wall plate wht and brn.This would be one complete pair.So the wall plate colors are different from cat5 but as long as you stay in pairs and go from left to right on your conections you should be ok.
Jun 05, 2011 | Computers & Internet
Wiring a TPH553 Surface Mounted Jack by RCA.
TPH553 T568A T568BPin 1 - BL White/Green White/Orange Pin 2 - OR Green Orange Pin 3 - BK White/Orange White/Green Pin 4 - RD Blue Blue Pin 5 - GR White/Blue White/Blue Pin 6 - YL Orange Green Pin 7 - BR White/Brown White/Brown Pin 8 - WH Brown Brown
REF: wikipedia
Feb 17, 2010 | Computers & Internet
Wireing
3-pair version of (red/green, black/yellow, white/blue). But the first two pairs are not twisted
So it becomes green/red, yellow/black, & white-black/blue. G1/ R2 /3Y /4B /5*Blk/6Blue (this is what you physically see on the other RJ11 connections since this is a data connection and not a phone connection it should be a straight-through instead of cross-over connection.
These RJ 11 PINOUT assignments may be incorrect because they apply to a color camera instead of B/W
1 SPEAKER (+)
2 VIDEO_OUT
3 GND
4 SPEAKER (-)
5 AUDIO_OUT/ALARM_OUT
6 12V DC
Back of Camera
Clip up, contacts down
123456
RJ11-e starts off like a RJ45 Stranded Patch Cable.
The color code used in stranded patch cables is different from solid-conductor cables. For NorTel Digital Patch Cable (DPC), the coding is; Pair 1: Green & RedPair 2: Yellow & BlackPair 3: Blue & *Orange White\Black
*In Pair 3 the color coding is Blue & Black instead of Blue & Orange and the pair is twisted so that the Blue wire is the 6th pin instead of the 5th pin.
Jun 27, 2009 | Samsung Weather Resistant Security Camera...
Wiring on a RCA RJ-45 wall jack
the RJ45 wallplate is not meant for ethernet. It's an 8P8C connector for a phone. Will it work as a network jack? Maybe. I wouldn't use it, but if you really want to try, wire it thusly:
1 Blue --- Orange/White
2 Orange --- Orange
3 Black --- Green/White
4 Red --- Blue
5 Green --- Blue/White
6 Yellow --- Green
7 Brown --- Brown/White
8 White --- Brown
I'd still recommend a CAT5 wallplate with a CAT5 jack.
Apr 11, 2009 | Computers & Internet
Replaceing phone wall plate
Hi Leanne!
Normally the conductors in phone cable are colored green, red, black and yellow in older style wiring. Green and red are used for a single line, and black and yellow are for a second line. Newer systems use wires that have conductors twisted together in pairs. White with a blue stripe paired with solid blue or blue with a white stripe is line 1. White with an orange stripe paired with solid orange or orange with a white stripe is line 2. (At least this is true in the US. You said "cheers" so maybe you're not in the US and the color coding's different.)
Chances are your line is using the blue and white wires.Residential telephone equipment isn't polarity sensitive so it really doesn't matter which wire you hook to L+ and L-. Try the white/blue combination first. If you don't get dialtone then try red/black. If still no luck you only have two more combinations to try.
Before you start with the wiring, take another phone on the line off the hook (if you have another one). This will prevent an incoming call from ringing the line, which can give a shock if you happen to be touching a bare end. The ringing voltage is much higher than the normal phone line voltage which won't bother you.
Apr 11, 2009 | Lands Phones
What cables are what
black is ground red is power with key on yellow is power all the time blue white is amp remote wire you dont use this if you dont have amp.
Sep 23, 2008 | Kenwood KDC-3024 CD Player
Ethernet cable
568-B Wiring
Pair Wires RJ-45 pins
1-White/Blue White/Blue 5
Blue/White 4
2-Wht./Orange White/Orange 1
Orange White 2
3-White/Green White/Green 3
Green/White 6
4-White/Brown White/Brown 7
Brown/White 8
568-A Wiring
Blue/White 4
2-White/Green White/Green 1
Green/White 2
3-White/Orange White/Orange 3
Orange/White 6
Brown/White 8
RJ-45 Pins are with the spring tab down and read left to right. Do you have an RJ-45 Crimping tool?
Just use 568-B or 568-A on both ends of the same cable.
Jul 05, 2008 | Computers & Internet
I have a Philips wall jack model number ph69636. and i need to know how to wire it up with a cat5e cable
Pin Std Phillips
1 White/Orange BLUE
2 Orange Orange
3 White/Green Black
4 BLUE Red
5 White/Blue Green
6 Green Yellow
7 White/Brown Brown
8 Brown White
May 16, 2008 | Computers & Internet
Gateway GM5084 PC Desktop Logo
43 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
