Question about GE DBXR463EDWW Electric Dryer
My GE dryer has no heat but runs. Also when you put the setting on more dry or less dry the dryer will run for hours, but will run the correct time on the timed dry setting. Either way the dryer will not heat up.
  • GE Master
  • 43,501 Answers
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Jan 15, 2011
GE dryer dwsr463eg7ww timer isn't working and doesnt heat up
The heating element assembly warms the air before the air enters the dryer drum. If the dryer won't stop, it may be because the heating element assembly isn't working - which greatly increases the drying time. Check the heating element for continuity. http://www.repairclinic.com/RepairHelp/How-To-Fix-A-Dryer/7-3-850356-/GE-Dryer-won-t-stop-DWSR463EG7WW
This GE Website has descriptions and videos you can watch. Also shows the price of replacement parts and the skill level needed to preform repairs yourself.
Sep 12, 2014 | GE Dryers
Amana ALG443raw gas dryer
sounds like the thermostat is shot..do you fix this sort of thing yourself?
Mar 17, 2008 | Amana ALG443RAW Gas Dryer
Ge dryer dcvh515efoww runs on air dry, but when set on any heating cycle, it runs for a few minutes and then it turns off on 00
it is over heating you might have unplugged a wire to the thermostat when you had it apart or the thermostat has went out.
Mar 21, 2014 | GE Dryers
My kenmore elite #110.73012181 electric dryer with autonsense feature no longer sensing, keeps on drying for hours after clothes dry when on less dry mode or normal dry mode
The drying circuit has to have a sensor to control heat and the timer controls time (on timed drying). Often sensors fail "open" and dryers stop drying. This sensor or the circuit seems to have failed closed (runs all the time). I suspect the sensor has failed in the drying control.
Jan 02, 2014 | Kenmore Dryers
Problem drying
no, what setting do you have the dryer on? is the dryer getting hot? if it is set correctly and is heating as it should then you need to check the vent hose, it is probably restricted with lint. Be sure and clean it from end to end.
Mar 12, 2010 | GE Profile Harmony DPGT750EC Electric...
Sensor and timed dry isn't working. Dryer runs but never stops.
if the timer dont run on the timed dry setting the timer is bad.if it works on the timed setting but not the auto setting you have a heat issue.
Mar 06, 2010 | GE Dryers
Dryer Shuts off with full load
ok so it runs for the full time set when on timed dry. auto from optimum or less dry runs quickly, correct?
Auto runs on yours by advancing the timer whenever the thermostat is satisfied with the temp coming out. This has a wire that runs from the heater to a resister mounted in the console area then to the timer providing the power to run the timer motor. Most commonly the heater is the cause. GE dryers have 2 elements side by side that operate indepenently but if one goes out the unit will still heat but the circuit for auto is like the heater is off advancing the timer.
the heater is located behind the drum on the wall. first measure the resistance on the resister, i believe 1.4 k ohms see diagram behind it.
to get to heater, remove 2 phillips screws inside door opening top holding top down. then lift top and slide to left if plastic console. to unhook from console. remove 2 screws holding front to cabinet, disconnect wires at bottom left on panel. reach inside on bottom (2 hands may be necessary) pull tensioner arm to right and hook on motor side, it will stay there till pushed. you will get red grease on you. Now you can pull the drum straight out, its a tight fit up front you can remove a side screw to help. you now have an excellent view of the heater. any breaks in either coil?
May 03, 2009 | GE DBXR463EDWW Electric Dryer
Electric GE dryer DBXR463ED2WW is not drying
The exhaust hose or piping is clogged, try cleaning it or replace it.
Mar 26, 2009 | GE Dryers
DBXR453ET3WW Electric Dryer Won't shut off unless on timed cycle.
hi thanks for the question in the ge dryer theres 2 elements so if one is not working you only get half heat i would check the heater thanks the appliance doc
Jun 18, 2008 | GE DBXR463EBWW Electric Dryer
GE DBXR463EDWW Electric Dryer Logo
386 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
