Question about GE Monogram ZISS420NRSS 42" Built-In Side-By-Side Refrigerator (ZIS-S420NRSS, ZIS S420NRSS)
Freezer sometimes works - GE Monogram ZISS420NRSS 42" Built-In Side-By-Side Refrigerator (ZIS-S420NRSS, ZIS S420NRSS)
  • GE Master
  • 43,501 Answers
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Oct 07, 2010
Why freezer part is not working on my samsung rb2055sl
The most common part to replace is the timer motor. It's usually located on the back bottom of fridge, It's a little thingy about 1 1/2 " in diameter. One screw will usually get it loose where you can take a look at it better to see if it's turning. It has a small window where you can see a little wheel turning.
Sep 05, 2014 | Samsung RF265AA Bottom Freezer French Door...
Why does my daewoo fridge freezer works intermittently ?
You either have a faulty thermostat, a loose connection or most likely a build up of ice inside the freezer. I had the same problem. Almost replaced fridge. Took all the food out one day, took out the racks and disassembled bottom and rear and found a two foot log block of ice inside air return. Removed ice everything works perfectly.
Jul 22, 2014 | Daewoo Freezers
Freezer doesn't cool to 0 even though it's set at -5
There is a fan that blows air past the coils in the freezer. Either the fan is not working or the coils are blocked with ice. Sometime ice stops the fan from turning. listen for the fan spinning by turning the thermostat down. Defrost the coils and fan and see if the frig returns to normal. Sometimes the drain tube is clogged causing ice buildup.
Feb 13, 2014 | Whirlpool GB2SHKXL Bottom Freezer...
Ge side by side refrigerator GSS25XSRDSS freezer not freezing
Do you see any ice buildup on the back wall of the freezer or behind it?
Nov 04, 2012 | Refrigerators
My ref is not cooling, sometimes its cold sometimes its not. but the freezer works ok.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Sep 04, 2011 | GE Refrigerators
Fridge not staying cool, freezer still freezing
Try defrosting freezer, sometimes when the defrost thermostat fails it causes ice too build up behind the walls of the freezer then it restricts the air flow to the refer side. If it works after defrosting then you probably need to get a new defrost thermostat.
Mar 14, 2009 | Maytag MBB1956GES Bottom Freezer...
Fridge/Freezer combo - Freezer working fine but fridge is not
There is a duct between the freezer and refrigerator. Sometimes this duct blocks off with ice and won't allow airflow. Open your refrigerator door and check for air flow if there is none the duct needs to be defrosted. turn off freezer/ refrigerator and defrost.
Feb 24, 2009 | Hotpoint Freezers
Have got fridgr freezer freezer has been leaking water for sometime now freezer has stopped working but the fridge is fine
You have a plugged drain hose it is behind the evaporator cover in the freezer, remove the cover defrost the ice , clear and clean the hose ... and it will work again
Sep 14, 2008 | Refrigerators
Freezer is not working properly.
http://forum.appliancepartspros.com/refrigerator-freezer-repair/4220-ge-refrigerators-gs-ps-models-evaporator-fan-motor-test-replacement.html
Try this link with step by step instructions
hope it help
Mar 06, 2008 | GE GSS25LGM Side by Side Refrigerator
GE Monogram ZISS420NRSS 42" Built-In Side-By-Side Refrigerator (ZIS-S420NRSS, ZIS S420NRSS) Logo
69 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
