Question about HP Compaq nx8220 Notebook
Black screen,F10 not work,BIOS needs reset,how to reset without opening.thank's
Hp dv5020us won't boot. upon power up I get some brief hard drive activity and fan noise. No blinking LED error codes. Caps and/or Num lock LED's do not light. Power LED will glow and HD...
step one, big battery out? skipped that?
step 2, a good power pack , that means 19vdc on those 2 pins.
bingo BIOS screen now work ,yes?
step 3, try an external VGA screen at the P15 VGA jack there
screens work now (BIOS first) yes/no?
remove DVD, drive
and all USB devices
there booting with only 1 memory stick. (got more?, try each 1 by 1)
black screens of *****'.
the lack of flash codes, Implies Power pack is dead. or CPU overheated, and selfshuts down. that fan going dead tells
me the power park is dead.
http://pcdied.com/#black-screens
May 01, 2017 | HP Pavilion dv5020us Notebook
I was playing around in my bios and must have set something wrong because no I get the black screen with F9, F10,F12 at the bottom right (Boot, Setup, Network) but not the blue F! at the left to boot it...
Just set the BIOS configuration to its default settings. Simply access the BIOS again and on the BIOS, Press F9 and select "Yes or press Y" to load BIOS defaults and Press F10 to Save and Exit BIOS setup.
Thank you for visiting FixYa!
May 19, 2011 | HP Compaq dc5100 Small Form Factor PC...
My husbands ex wife bought my step son a used HP compaq d530 SFF desktop. She set an admin password on it and now she cant remember what it is. Is there anyway to restore it back to the factory settings...
If you are talking about problem with your password
You need to prepare:
1:A blank CD/DVD or USB flash drive
2.A computer which can link to internet
3.A program called Windows Password Recovery 6.0
Get started with this 3 simple steps:
Website: http://lost-password.net/products/windowspasswordrecoery.html
Step 1 - Download windows password recovery utility and install it.
Step 2 -Burn your Windows Password Reset CD:
To burn your CD, you'll need a blank CD-R and the .ISO file of Windows Password Reset.
Step 3 - Put in your newly created CD and remove your Windows password.
hope this helps
http://majorgeeks.com/download.php?det=5710
UBCD4Win is a bootable CD which contains software that allows you to repair, restore, or diagnose almost any computer problem also has a bios reset tool which can remove your password and bios password
you will have to burn it to a disk as an ISO then you will have to boot from the disc During the boot process you will see on the screen to press a certain key to enter setup Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd press escape then press f10 to save to cmos to restart (note after you have removed your password you will have change first boot back to your hard drive) also
Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10 key,ie: Alt+F10, it will open the recovery console ,select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer) or
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
click start all programs accessories scroll to system tools from there you should see a system restore click next a sytem date should open up select the date you want to restore your computer to or if you want a full factory restore or
Hope this helps
Hope this helps
Apr 08, 2011 | Compaq Computers & Internet
I have a Gateway Laptop, I cant find a model number, but the computer had a virus in which a so call tech removed, now the computer boots the the first screen , at that time you can press f2 and go into...
You can restore the computer back to factory default,to do so, follow the below steps: Turn OFF the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10" key, i.e Alt+f10, it will open the recovery console, select full factory restore and follow onscreen instruction. NOTE: This will erase all the datas on the computer.
Thank and regards,
Anil.B.R
Nov 06, 2010 | Gateway M305CRV Notebook
HP Laptop won't come back on after sleep mode - have to reboot
Check the Power settings in BIOS. Some of the laptops have a S1 and S3 setting. Check to see what setting it is on, and switch to the other one. Most likely, it is set to S1.
Without the model number, it is kind of hard to tell you how to navigate through the BIOS, but with HP laptops, you can get to the BIOS menu by pressing "F10" when you first turn the computer on and you see the HP logo.
Oct 26, 2009 | HP Computers & Internet
How do I reset bios on HP laptop?
To restore the BIOS default setting, open the BIOS Setup screen as follows:
(i) Turn off the computer and wait five seconds.
(ii) Turn on the computer.
(iii) When the first screen displays:
(a) Immediately press the F10 key if your computer was built in 2006 or later (came with Vista).
(b) Press the F1 key if your computer was built before 2006 (XP or earlier). Press the key once every second until a BIOS Setup utility screen opens.
NOTE: On some Compaq Presario computers (before 2002), press the F10 key at the logo screen.
(iv) After the Setup Utility screen opens, press F9 key to select and load the BIOS Setup Defaults .
(v) Press F10 to Save and Exit .
(vi) Using the arrow keys select Yes and then press Enter when asked Exit Saving Changes?.
Sep 20, 2009 | Computers & Internet
Hp business pc/912: error while booting/ reset case disabled
Go into the BIOS and disable the error message. You will need to look around in the BIOS to find the exact location of the enable/disable setting for case intrusion.
May 22, 2009 | HP Computers & Internet
I need to reset the system password on a HP NC 4010 notebook
If it is a bios password, you can reset by using the jumper which should be located near the cmos battery.
Mar 16, 2009 | HP Compaq nc4010 Notebook
HP Compaq d530 SFF PC Desktop. Black Screen and Cursor blinking..
Try to enter in to BIOS by restearting the notebook (Pressing F2 function, if the notebook enters in to bios then no need to worry. after theat i suggest you to reinstall the notebook to original factory settings dy the recovery disks.
Mar 06, 2009 | HP Compaq d530 SFF PC Desktop
HP Compaq nx8220 Notebook Logo
254 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
