Question about Panasonic Panafax UF-585 Plain Paper Laser Fax
Sending Faxes Our Fax machine will receive but we can't change it from receiving to sending and receiving. how do we change the setting on it?
  • robert rudlin Jun 29, 2008
    our machine was send faxes but not receiving- we phoned canon and they thought maybe we need to slow down the speed to receive , when they could not help me we took it back up to its original speed but somewhere on the was l must have pressed something and now l cannot even send-please help me to send again and maybe you could help me receive as well l could be most grateful
There is no need to change the setting.just feed the document to be sent and dial the number of the recipient.after hearing the fax tone press enter key
Posted on May 29, 2008
Hp officejet 6500 instructions for receiving a fax? Thanks
You can receive faxes automatically or manually. If you turn off the Auto Answer option, you must receive faxes manually. If you turn on the Auto Answer option (the default setting), the device automatically answers incoming calls and receives faxes after the number of rings that are specified by the Rings to Answer setting. (The default Rings to Answer setting is five rings.)
If you receive a legal-size fax and the device is not currently set to use legal-size paper, the device reduces the fax so that it fits on the paper that is loaded. If you have disabled the Automatic Reduction feature, the device prints the fax on two pages.
NOTE: If you are copying a document when a fax arrives, the fax is stored in the
device memory until the copying finishes. This can reduce the number of fax pages stored in memory.
This section contains the following topics:
• Receive a fax manually
• Set up backup fax reception
• Reprint received faxes from memory
• Poll to receive a fax
• Forward faxes to another number
• Set the paper size for received faxes
• Set automatic reduction for incoming faxes
• Block junk fax numbers
• Receive faxes to your computer (Fax to PC and Fax to Mac)
When you are on the phone, the person you are speaking with can send you a fax while you are still connected. This is referred to as manual faxing. Use the instructions in this section to receive a manual fax.
NOTE: You can pick up the handset to talk or listen for fax tones.
You can receive faxes manually from a phone that is:
• Directly connected to the device (on the 2-EXT port)
• On the same phone line, but not directly connected to the device
NOTE: The automatic document feeder must be empty to receive a fax. If there are documents in the ADF, then the device will not be able to receive incoming faxes.
To receive a fax manually
1. Make sure the device is turned on and you have paper loaded in the input tray.
2. Remove any originals from the document feeder tray.
are documents in the document feeder, then receiving the fax will be
3. Do one of the following to answer a fax manually:
• Set the Rings to Answer setting to a high number to allow you to answer the
incoming call before the device answers.
• Turn off the Auto Answer setting so that the device does not automatically
answer incoming calls.
4. If you are currently on the phone with the sender, instruct the sender to press Start on their fax machine.
5. When you hear fax tones from a sending fax machine, do the following:
a. Press START FAX Black or START FAX Color on the device control panel.
b. When prompted, select Fax Receive.
NOTE: Depending on your country/region, the device might receive the fax
automatically when you hear fax tones from the sending fax machine.
6. After the device begins to receive the fax, you can hang up the phone or remain on the line. The phone line is silent during fax transmission.
Jan 30, 2011 | HP 1250 Plain Paper Thermal Inkjet Fax
Canon MP830 has stopped receiving faxes. When the fax phone number is called it rings but the fax does not pick up.
Can you still send fax? if sending and receiving are not working you can try to update or uninstall/reinstall the software for this unit..
Hope that helps.............
Aug 15, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Can't send or receive faxes ADSL
If you want to use the FAX - use the dedicated line to the FAX Machine..
Hi check the following steps
Problems with sending and receiving FAX
Make sure that you have plugged the phone cord directly and securely into the wall jack and into the back port of the fax product. The fax port on your product is marked "Line," "To Wall Jack," or with a wall jack symbol.
Check LIU
Make sure the Line Interface Unit (box that the phone cord plugs into) is fully seated into the back of the fax product.
Remove the SPLITTER
Remove any other devices from the line such as splitters, credit card machines, or telephone answering machines.
Can try sending the Fax on Another Line
Try using a different telephone cord.
Jan 22, 2010 | Samsung CLX-3175FN Color Laser All-in-One...
We can send faxes but we can not receive faxes. The fax machine that sends the fax tell it that our line is busy. Is that a machine problem or a phone line problem?
Problem lies in your Receive Mode setting. If you don't have a dedicated phone line for the fax machine, you need to set it up for either Manual where you answer every call or Fax/Tel whereby the Fax machine determines if the incoming call is a fax or phone call. Instructions per Intellifax 4100 Manual.
Select a Receive Mode
Choose the mode that best suits your needs by pressing the Mode button
repeatedly until the FAX and FAX/TEL lights show the setting you want to use.
You must answer every call yourself.
The Brother machine must be started manually
to receive faxes.
For use with a dedicated fax line.
Every call is answered as a fax.
For receiving fax and voice calls on one line.
The FAX answers every call and receives a fax or
double rings for you to pick up a voice call.
For use with an answering device.
The TAD answers every call and stores voice messages.
Fax messages are printed.
Apr 20, 2009 | Brother IntelliFAX 4100 Laser Fax
Not receiving any faxes but sending
Note: check your equipment for:
Fax machine must be connected to an answer machine
Receiving a fax automatically:
1 Make sure the Fax Auto Answer light is on.
2 To set the number of telephone rings before the printer automatically receives faxes,
Receiving a fax with an answering machine
When a telephone ring is detected, the answering machine picks up the call.
If the printer detects a fax, it receives the fax and disconnects the answering machine.
If the printer does not detect a fax, the answering machine receives the call.
2 Set the answering machine to answer incoming calls before the printer does.
For example, if you set the answering machine to answer calls after three rings, set the printer to answer calls
after five rings.
3 To set the number of telephone rings before the printer automatically receives faxes.
Oct 31, 2008 | Lexmark X5470 All-In-One InkJet Printer
Hp 5610 won't receive fax from lexmark fax
Are you able to receive faxes from others from the same location, if not just ask her to consult her service provider and ask to get the no checked of yours why is it that you she is not able to send fax to you only as your fax machine is capable of sending and receiving fax from others it should be dsome issue with her service provider.
If it was your All-In-One printer thrn you should not have received faxes from any one, not a specific number.
Good Luck
Aug 19, 2008 | HP Officejet 5610 All-In-One InkJet...
Fax will not send
Does the receiving or sending party have a DSL phone line?
Aug 01, 2008 | Brother MFC-8220 Fax
Setting up fax machine to receive
Receive Mode Setting
On the operation panel, press the following buttons to select the appropriate receive mode.
  1. Press <Fax>.
  2. Press <Menu>.
  3. Press the right or left arrow button to select [Receive mode set], then press <OK>.
  4. Press the right or left arrow button to select the receive mode that best suits your needs, then press <OK>.
    FAX ONLY MODE: When you want to receive only faxes automatically with your machine, or have a dedicated telephone line for FAX use only.
    MANUAL MODE: When you receive mainly voice calls and sometimes faxes, or want to receive faxes manually.
    ANS MACHINE MODE: When you want to receive voice messages on your answering machine and receive faxes automatically.
    FAX/TEL AUTO SW: When you want to receive faxes automatically as well as voice calls.
    DRPD: When you have subscribed to a DRPD service with your telephone company.
  5. Press <Stop/Reset> repeatedly to return to fax standby mode.
Sending Methods Sending From Your Machine (Memory Sending)
  1. Load the document on the Platen Glass or the ADF.
    Sending from the platen
    Important: When sending a double-sided document, set the document on the Platen Glass. You cannot scan double-sided documents from the ADF.
    Sending from the ADF
    *MP830 shown
  2. Press <FAX>.
  3. Adjust the settings for your document as necessary.
  4. Dial the recipient's number using the numeric keys or speed dialing.
  5. Press <Color> for color sending, or <Black> for black & white sending.
    • When the document was loaded on the Platen Glass:
      1. When the following message is displayed, load the next page on the Platen Glass.
        If you have only one sheet to scan, press <OK>..
      2. Press <Color> to send in color, or <Black> to send in black and white.
        IMPORTANT: If you do not press the same button you pressed in step 5, the machine does not start scanning.
      3. Repeat steps 5a and 5b to scan in all pages of the document.
      4. Press <OK>.
    • When the document was loaded in the ADF:
      The machine starts sending automatically after the document is scanned in.
      Note: Color sending is available only when the recipient's fax machine supports color faxing.
  • To cancel sending before sending a fax, press <Stop/Reset>.
  • To cancel memory sending while sending a fax, follow any instructions on the LCD after pressing <Stop/Reset>.
  • If the document remains in the ADF after pressing <Stop/Reset> during sending a fax, press <OK>. The remaining document is automatically fed out.
Sending From Your Machine (Manual Sending)
Use manual sending when you want to talk to the recipient before sending a document, or if the recipient does not have a fax machine that can receive automatically.
  • With manual sending, you cannot use the Platen Glass to send documents.
  • You will need to connect a telephone to your machine if you want to talk to the recipient before sending a document.
Follow this procedure:
  1. Connect a telephone to your machine if you want to talk to the recipient before sending a document
  2. Load the document in the ADF.
  3. Press <FAX>.
  4. Adjust the settings for your document as necessary.
  5. You can lift the handset if one is connected to the machine.
  6. Dial the recipient's number using the numeric keys or coded speed dialing.
  7. Talk through the handset to the recipient. (If you hear a high-pitched signal instead of the
    recipient's voice, go to step 9.)
  8. Ask the recipient to set recipient's fax machine to receive faxes.
  9. When you hear a high-pitched signal, press <Color> for color sending, or <Black> for black & white sending. Then hang up the handset.
Jan 07, 2008 | Canon PIXMA MP530 All-In-One InkJet...
          A multitude of problems might cause receive problems, and the User's Guide has no "receive Problems" section under troubleshooting - so here goes:
        If I had to guess right off the bat, your problem is probably
that the FAX is in "FAX Storage" mode, and is out of memory.
In this mode, it will print FAXes until it runs out of memory.
See problem "g" below.
   a. Voice mail active on the line - if voice mail and FAX-2820 are
       set to answer the line on the same number of rings, there's
       no way to know which will answer first.
   b. Voice mail active on line - if voice mail is set to answer in
       fewer rings than the FAX, then the FAX will always lose
       (but you'll have no problems Xmitting).
   c. Call Waiting active on the line - the call waiting "boop" will
       kill incoming FAXes (and outgoing FAXes too, but your
       personnel will retry the outging ones until they succeed
       and you may only hear complaints about incoming FAXes).
   d. Your FAX-2820 is set to "Manual" or "External TAD" mode.
       Reset it to "FAX only" or "FAX/Tel" mode (depending on
       your office use of the FAX telephone line).
       How to do this: Menu/Set,0,1 <up/down to select mode>
                              press Menu/Set.
   NOTE: your LCD display tells you your receive mode:
       Mine says "Sleep 22:08 Fax", telling me I'm in "FAX only"
       mode, and its 10:08 PM.
   e. You've set the FAX to RING DELAY - if so, the FAX
       must win. Setting ring delay to 00 tells the FAX to answer
       the line silently (an advantage for a busy MD's office).
       How to change this: Menu/Set,2,1,1
       Ref: FAX-2820 User's Guide p.4-2
   f. You dont have a shared (FAX/human) line set to
     "Easy Receive"; if someone answers the call and
      Easy Receive is off, then they need to press START on
      the fax machine front panel or dial *51 and hang up.
      How to change it: Menu/Set,2,1,3
      REF: Fax-2820 User's Guide p. 4-2
  g. You may be set up for "FAX storage."  In this mode, received
      FAXes will be stored (and printed) until you run out of
      memory (quickly done on a Brother FAX-2820), then you
      get nada (but sending FAXes still works).
      How to reset this: Menu/Set,2,5,1 <up/down>
      REF: Fax-2820 User's Guide p.6-2
  h. You may have set up FAX forwarding.  In this mode, sending
      FAXes will work fine, but all incoming FAXes willl be sent
      to another telephone number.
      How to turn it off: Menu/Set,2,5,1 <up/down>
      If this laundry list of (sending OK, Receiving dead) scenarios
 doesn't resolve the problem, email your FAX number to me
and we'll do some cross-country FAX debugging.
                                  Dave in tech support
      The above features may have been set remotely by a
   nefarious (or somewhat knowledgeable) individual - remember
   that a little knowledge is a dangerous thing (even for
   FAXes). See (extensive) remote programming instructions
   on p.6-6 of the User's Manual.
        To print out the caller ID list - and possibly find out the
   source of the remote programming:
   Menu/Set,2,0,3 <up/down to "print report">, Menu/Set,
    Start, <Caller ID report prints>, Stop/Exit
   Ref: Brother Fax-2820 User's Guide p.A-3
Dec 20, 2007 | Brother IntelliFax-2820 Laser Fax
Sending Faxes
When the last page of your document has been sent successfully, the machine beeps and returns to Standby mode. When something goes wrong while sending your fax, an error message appears on the display. If you receive an error message, press Stop/Clear to clear the message and try to send the document again. You can set your machine to print a confirmation report automatically each time sending a fax is completed. If you get the error message write it down it should always supply an error message if the fax did not go through.
Jul 25, 2007 | Samsung SCX 4521F All-In-One Laser Printer
Panasonic Panafax UF-585 Plain Paper Laser Fax Logo
105 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
