Back to:
Tags:
Marantz DR-4050 2-Disc CD Recorder
4050
posted by valveampnut on May 29, 2008
Hello I have a Marantz DR 4050 for repair, the left hand record/play deck will not recognise a CD (says no disk) I have cleaned the lazer but can not find any adjustment, do I have to replace the lazer or the whole unit?
If so where do I get spares? I am in Spain but can have stuff delivered to England.
Regards
Kevin Mooney
Comment by valveampnut, posted on May 30, 2008
Thanks for that Dan it's what I thought but it's nice to have confirmation. They are Phillips decks so I can probably get generic parts.
Kevin
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
Helpful (85)
Abrsvcs
Rank:Guru Guru
Rating: 86%, 786 votes
The optics are most likely defective. Yes you will need to replace the optics assembly. I don't have a location for parts outside of the US, but you should be able to locate a parts distributor for Marantz in Europe.
Dan
Rating Locked! (?) valveampnut has rated this solution as Helpful
Thank You!
Was the solution helpful?
Show your appreciation by commenting on 4050:
I don't want to Accept this solution
Can you Help with these CD Players problems?
CD Players
i have the above cd system and have lost one of the main...
CD Players
Our nutone cd player has started to make a buzzing sound.
CD Players
why dose lense jump the tracks .i have changed the lense...
CD Players
I never had the instruction booklet but a few years ago i...
CD Players
Okay...either I'm getting cheap stereos, or I'm doing...
Loading problems.
Repair Service
Find CD Player Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
