Question about Maytag Neptune MDE5500AY Electric Dryer
Change a three wire to a four wire. - Maytag Neptune MDE5500AY Electric Dryer
  • 259 Answers
To change from a three to a four wire cord you will need to remove the ground wire/strap that is currently connected to the center connection at the back of the dryer. This ground wire is going to look like a flat piece of either copper or aluminum that connects to the center peg and is screwed to the dyer cabinet right next to the cord terminal block SAVE THE SCREW. Doing this separates the electrical neutral and the cabinet ground.
Now when connecting the four wire cord, put the red and black wires on the outer connection posts (does not matter which goes on which side) and the white neutral wire connects to the center connector. The green or sometimes green with yellow stripe wire from the cord will connect to the cabinet where the ground strap you removed used to connect use the same screw that you removed earlier.
Posted on Oct 07, 2010
The plugin on my dryer has the terminals going in a slant. the outlet in my house are straight. what should i do
You can purchase a dryer main power cord that fits the type outlet you have. Some cords are three wire and some are four wire. Here is some information on changing from a three wire to a four wire configuration or vice versa.These two pictures illustrate the power wiring on a the terminal of an electric dryer. The one on top/left is the old-style three-wire configuration. Most people have this type in their homes. New code changes, though, require that dryers now have a four-wire cord, shown on the right/bottom.
Besides the number of wires in each cord, there are two important things to notice. First, in the four-wire configuration, notice that the dryer's grounding strap is folded back on itself. The whole point of the four-wire cord is to separate the ground from the neutral. The green wire (the "new" extra wire in the four-wire cord) is attached to the dryer cabinet. In the three-wire configuration, the grounding strap is left intact and the neutral and ground are tied together.
Sure hope this helped and best wishes.
Oct 15, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Plug problem
On a three wire configuration, the ground and the negative are tied together at the center position, using the dryer ground strap. Following is a description of the difference between three and four wire. Hope it helps you.
These two pictures illustrate the power wiring on a the terminal of an electric dryer. The one on top is the old-style three-wire configuration. Most people have this type in their homes. New code changes, though, require that dryers now have a four-wire cord, shown on the bottom.
Sure hope this helps you find a resolution to your delimma! Best wishes.
Oct 01, 2009 | Whirlpool LER4634J Electric Dryer
Repairing 3 wire drop cord
Sep 09, 2009 | Whirlpool LER5636P Electric Dryer
Changing dryer plugs
Sep 09, 2009 | GE DCVH515GF Gas Dryer
Convert three pin plug to four pin
Sep 06, 2009 | Frigidaire GLEQ2152ES Electric Dryer
I'm trying to replace the power cord on the Maytag Atlantis MDE7400AY. originally it has a three prong cord but i need to put on a four prong. in the back of the dryer it seems to only have three...
Sep 04, 2009 | Dryers
Conect 4 wires to 3 wires box in the wall
These two pictures illustrate the power wiring on a the terminal of an electric dryer. The one to the left here is the old-style three-wire configuration. Most people have this type in their homes. New code changes, though, require that dryers now have a four-wire cord, shown to the right. These are just just thumbnail pictures that you can click for a larger view. But I'll bet you already figured that out, didn't you?
tn_3prong_dryer_outlet.jpgtn_4prong_dryer_outlet.jpgIf you need to re-wire the outlet, these pictures will explain the anatomy of the three-prong (left) and four-prong (right) outlets. Once again, these pictures are just thumbnails--click 'em for a larger view.
Comments: Jul 23, 2009- bf71290.jpgfb4d3ed.jpg
Three wire Four wire.
Aug 18, 2009 | Whirlpool LER5636P Electric Dryer
Changing from a 3 prong to a four prong
grasshopper_2.gifWiring in a new power cord for your electric dryer? Upgrading your electric dryer outlet from the old three-prong to the new four-prong outlet? Well, grab hold of those two large lumps at the base of your spinal cord and let's romp through the wild and wacky world of dryer cords and outlets.
tn_3cord_dryer_terminal.jpgtn_4cord_dryer_terminal.jpgThese two pictures illustrate the power wiring on a the terminal of an electric dryer. The one to the left here is the old-style three-wire configuration. Most people have this type in their homes. New code changes, though, require that dryers now have a four-wire cord, shown to the right. These are just just thumbnail pictures that you can click for a larger view. But I'll bet you already figured that out, didn't you?
Jul 23, 2009 | Dryers
I need to change my eltric cor from a four wire to
The following link explains how to install a power cord for your appliance:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
Refer to the section that discusses converting from a 4-prong to a 3-prong power cord.
If you have questions, let me know. I hope this helps you.
PS The GREEN wire is ground and gets grounded to the appliance frame.
Jul 06, 2009 | Whirlpool LER4634J Electric Dryer
No Heat
no the four wire cord just has an extra green ground wire,the three pong will work just make sure you have the middle wire on the cord on the middle of the terminal block,let me know how you make out-mike
Apr 02, 2009 | Whirlpool LER4634J Electric Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
74 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
