Question about Frigidaire FGF316 Gas Kitchen Range
At times my oven does not come on. I have noticed when the house is cool/cold it immediately comes on. Somedays it will not come on at all. If I attempt to turn the oven on the next day/morning it comes on. The igntion light does come on (a light orange color light)
    President:
  • 1,430 Answers
The problem is usually the igniter not reaching the correct amp draw .When the igniter does not reach the correct amp draw it may allow the gas valve to partially open or not open at all. The igniters are inexpensive and easy to replace. This video will walk you thru the correct procedure for testing an oven igniter. It may be a different model but the testing will be the same.You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available. All parts come with installation instructions.
Posted on Oct 07, 2010
My AEG competence oven is making a loud buzzing noise coming from the top fan? The food tonight was either burnt or under cooked? The buzzing is also loud when switched off/cooling down? Any ideas please.
I would suspect that the problem is caused by the external cooling fan located under the outside cooker cabinet housing, which continues to operate as the oven is cooling down if it is built in, you will have to remove it from the oven housing to access the fan
Dec 12, 2010 | AEG D4101-4 Electric Double Oven
Oven only works when house is cold
all gas range ignitors have to be just hot enough. i would say put an amp clamp meter on it. if it draws over 2.8 amps its probably good. if under that its bad and replace it.
Aug 01, 2010 | Brown Stove Works TTM721-DK Gas Single...
I have the York Outdoor Split System Air Conditioner- Model # h4de024S06A, Installed in my home on june 12, 2004. We had no problems at all until last night when we noticed that the Furnace of the Fan is...
I think you may have 2 problems. Thje outdoor fan not coming on would cause the compressor to either go out on high discharge pressure or internal overload. Either the fan is bad or the capacitor is bad or both, which can be replaced.
The second problem is either the unit froze up on you and for the short time that it will cool before it quits. You may want to make sure you cool speed for your indoor unit is set to hi cool speed which is usually black
Jul 06, 2010 | Heating & Cooling
My furnace comes on and heates the house for about
Make sure filters are clean . if they are stopped up the unit will over heat. Lets start there. Russ
Mar 22, 2010 | Ruud UBHC Air Conditioner
Everything works except nothing get heated..remains cold
It usually cost a lot to fix a cooking problem on microwave. Take it in for consult only. Compare repair price to new price before deciding. Don't ask them to come to your house. It will cost! You can get repair or replacement ins. to cover all your used appliances. Including heating and cooling. Not very expensive. Check on line.
Nov 03, 2009 | GE JVM1650 1000 Watts Microwave Oven
Beeping with 'f2' & 'f3' message when cleaning but did not finish cleaning. Oven now cooled but still locked.
All F3-E Codes - Oven Temperature Sensor (RTD) or Warming Drawer Defect - Replace oven temperature sensor (RTD).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question%$@#
May 25, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Whirlpool oven accubake system
I have a whirlpool accubake wall oven. Half-way through baking a pie ,unknown to me, the oven went to the self-clean mode , the door locked and the pie started to burn. I tried to turn the oven off but it would not cut off. I immediately ran to the house's main power and turned off the oven breaker. I waited for a short time to let the oven cool enough to open the door and get the burned pie out, then went back to turn my breaker back on and the oven (even though in the off mode) started heating again with the bottom unit turning red again. I had to then go back and pull the power. We tried this several times trying to push the off button but the oven will not go off until we throw the breaker. Help please!
Jul 01, 2008 | Whirlpool RBS245PDS Electric Single Oven
Turning off oven.
The fan only comes on in the back of the oven when convecting and Automaticaly turns off when you open the door. The exhaust fan coming from the front stays on for qutie a while, maybe 2 hours or so till the oven cools. I think it is just a function of the oven. A good thing in the winter but uses a bunch of airconditioning in the summer
Oct 23, 2007 | Electrolux ICON 30 in. Double Wall Oven
Cold air from outside coming in house through vent
Sounds like your damper (flap) outside is working, and that's probably the first thing to check. Wind may be also pulling the damper open from time to time. Hopefully the pipe fitting is sealed, and the pipe is insulated anywhere it runs through any unheated portion of the house. Some amount of cold air getting in will be unavoidable. The best bet next might be to look over the two pages in the installation instructions that deal with outside venting. If you don't have the installation instructions, you can get a copy here: http://www.geappliances.com/service_and_support/literature/ Then if you don't notice any obvious problems with the installation, it may be time to contact the installer for their two cents.
Feb 05, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Frigidaire FGF316 Gas Kitchen Range Logo
447 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
