Question about ASUS A7S333 Motherboard
No video input signal No power to disk drives
Recently my power supply becuame U/S and i replaced it but since then i have no power to my disc drives and my monitor gives the message that there is no video input signal HELP HELP HELP
    Scholar:
  • 187 Answers
If you mean the PSU, have you checked the cables from the PSU are actually plugged in correctly to the drives? (it's been known for folk to plug them in the wrong way). With regard to the monitor, check your graphics card (if not onboard) is still correctly plugged into the board (remove and re-seat it), and that the monitors cable is correctly and securely plugged into the VGA port.
Posted on May 29, 2008
I have a old (but almost unused) Korg d1200 recorder. Recently started getting disc error messages. Followed manual instructions to check disc drive and still get same results. Powered it up just now to...
First thing would be to check the power supply voltages. It may be the disk drive is failing. Drives are inexpensive, might be worth a try with a new drive. Also check that cables to the drive have not been loosend by handling.
Jun 17, 2011 | Korg D888 8 Track Recorder
All disc recorded on the recorder now say unknow disc
Take the disk out, power off, and on again. If it still says "unknown disc type" instead of "no disc," the internal disk drive is the problem. You can try to clean the sensor, but there is a good chance the drive needs to be replaced. I have a Philips DVDR3400 that did the same thing. I bought a regular computer internal drive, connected the power supply and IDE cable, and it now works.
thanks.
Apr 15, 2011 | Philips Cameras
Usb input broke need replacement
Go to any computer-store. Purchase an "empty" external disk-drive enclosure & power-supply.
Then, open your "old" enclosure, and remove the disk-drive from it,
and "transplant" the disk-drive into the "new" enclosure.
Nov 09, 2010 | HP Computers & Internet
Emachines T2891 Problem
Check output cables from your new power supply.
The connectors should be foolproof,but they might not be plugged in correctly.
Mar 06, 2010 | Computers & Internet
Mother board just replaced...now blue light not coming on...wont read disk
make sure the power supply is hooked up properly to the motherboard, if it is and your still not getting power to it properly then either the motherboard that it was replaced with is bad or the power supply is bad or both.
Even though the ps3 isn't reading disks, i wouldn't worry about that until you can get power and video back up on the tv, if at that point it won't read discs then the dvd drive is bad and would need to be replaced.
Jan 23, 2010 | Sony Playstation 3 (PS3) Console
Hitachi PDP 55HDT79 got no picture
that power supply is a switch mode power supply,which means it looks for an input signal to turn on.
that signal comes from the main pc board.
if there is excessive current draw,it will shut down.
check the input,and the screen circuit it is driving
May 13, 2009 | BenQ PDP-46W1 46 in. HD-Ready Plasma...
No Picture. But on the screen it shows the channel number and the menu. I have a ps2 and dvd/vcr sound works fine.
We know that high voltage and raster are okay. Suspected defective circuits are somewhere in the video drive chain or power supply system, so
the problem is definitely not a quick fix. Although the problem could be bad connections and weak filters which should be checked first.
After checking for quick fixes, you need to check video drive circuits which entails checking the video output wave form from the luminance processor. If video is not present check composite video coming into luminance processor. If input ok check voltages going to processor to determine if problem is power supply or processor. If input is not ok to luminance processor trace back to I/O port where the video switching processor is located. Check for input to input I/O processor. If good check I/O processor output, and if bad check voltages going to processor and switching data port to determine if processor, power supply, or systems control circuits are defective. If input to I/O processor is bad then trace signal back to where it is good and repair applicable circuit[s].
Apr 27, 2009 | Proscan PS36109 36" TV
No disks reading.
That would have been my first answer.  Glad it is working for you now!
Oct 24, 2007 | Sony PlayStation 2 Slimline Console
Power Supply/Video on/off problem
hi, seems to be a problem design, you can check the users review on: http://reviews.digitaltrends.com/review1430.html options 1,5 even 6 is ok. sorry.
Aug 26, 2007 | Gateway /ton 160W Power Supply (6500582)...
ASUS A7S333 Motherboard Logo
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
