Question about Vacuums
I need to replace the hose that comes out of the shower and connects to the shower head. Where can I purchase one?
  • 377 Answers
You can find them at Lowe's or Home Depot or most any hardware store. You might be able to find them on line if you go to Google and search under the brand name you have, such as Waterpick.
If you find this solution to be helpful, I would appreciate a Thumbs Up from you. Thank you. Paul
Posted on Oct 07, 2010
How can I replace or repair the small hose that is split connecting the brush roll case and the vacuum itself. It does disconnect to the main body of the vacuum. can the hose be replaced?
get an exploded parts diagram of your machine. if the hose (part) is listed separately, then a replacement should be available from the manufacturer. otherwise you may need to take the vacuum in for service from a dealer shop. More than likely, if it is NOT warranty work, it will be less expensive to replace the item.
Sep 20, 2014 | Shark Vacuum. Navigator Lift-Away Bagless...
How do I installa new hose to the mortorized brush head on my shark lift waway
Hi, it's Allie from Crucial Vacuum!
Replacing your Shark Floor Nozzle Hose is very easy. Start by unplugging your unit to avoid any safety hazards. The floor nozzle hose's side that attached to the floor base of your Navigator can easily be pulled away. The other side of the floor nozzle hose has two tabs that can be pushed in while pulling it away from the base.
When installing, connect the floor nozzle hose to the canister first by pressing both side tabs while placing it until it click in its place. Then connect the hose to the floor base.
You can purchase direct your replacement hose and filters from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/catalogsearch/result/?q=NV352
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Alejandra (Allie) Sepulveda-Rivera
Crucial Vacuum Customer Care
Sep 10, 2014 | Shark Vacuum. Navigator Lift-Away Bagless...
Dyson slim, all the suction is coming through the hose and not in the power head of the vacuum
This is a very common problem with the DC18s. basicly the carraige assy needs to be replaced. what happens is that there is a valve that is engaged when you recline the vaccum. well when the peice that is broken the valve wont move so it is stuck with constant suction and the hose and will never swich to the cleaner head. You need to take it in to a Dyson Authorized Dealer and have it replaced. if you have your proof of purchase and your within the first 5 years of owning the vacuum it will be covered under warranty. if you dont have your proof of purchase they will not be able to cover it under warranty. it will run you about $100 to $115 to get it replaced.
Sep 05, 2011 | Sharper Image Dyson Slim DC18 All Floors...
My Epic 6500 power head will not turn on. Had to push the reset many times the last time it ran, and now it will not turn on. Help!
Does the power nozzle motor come on? Is it just that the brush won't turn? If it's just the brush not rotating, the belt probably broke and needs replaced.
Is the brush clean? If not, clean all threads, etc. off.
Check all wire connections for breaks, cracks, and discoloration. Power nozzle to wand, wand to wand, wand to hose. If any of those are found, that part, and probably the one it connects to. will need replaced.
Ensure all connections are snug.
Internal wiring, including connections, could be bad. This would include wiring in the power nozzle, wands, hose, or canister.
Reset or hose switch could be bad. These would need replaced.
Power nozzle motor could be bad. Generally the belt will break before the motor burns out, but it's possible it's didn't.
For any internal repairs, including belt replacement, the entire vacuum should be taken to an authorized Aerus Electrolux dealer. The service technician can also troubleshoot and find the problem. This is generally done at no charge.
You've got a great machine, and with proper care and maintenance it should last for years to come.
Dec 22, 2010 | Electrolux Epic 6500 Vacuum
The head on a epic doesn't work
first check the reset button on the head . next connect the hose directly to the head if its a cannister make sure your hose switch is on . if your mechanically inclined remove the screws on the bottom plate and remove the top with the hose disconnected directly connect the reset switch wires with a small piece of electrical tape connect your hose turn the vac on if it comes on either a buy a new reset switch b save money skin the wires and connect them . if that doesn't work go to the nozzel motor with the hose disconnected cut the lead wires leave plenty of slack connect an old electrical cord to the two terminals plug into a 110 outlet if it comes on your problem is in your elbow neck about $19.00 it is the part that your wands connect to if the motor doesn't come on then its your pn motor and it will need replaced $34-$50 dollars . connect everything back the way it was using correct sized wire taps and ul approved electrical tape put your screws in a safe place they are easy to use parts are avaiable on ebay cheaper than anywhere else . if you feel this job is too big contact me and i will repair it for $20.00 plus parts
Aug 03, 2010 | Electrolux Epic 6500 Vacuum
The power head has developed an intermittent, but frequent, electrical short. Is there an easy way to assess where? Or is this a matter for a repair shop.
Greetings,
A majority of the time when this happens, it's caused by the hose having a short in it. You'll need to first identify what the source of the short it. To do this, turn the power brush on, and then swivel the hose on both the end before the handle, as well as the end that plugs into the vacuum, can you get the power brush to cut on/off for you from here? If yes, then you'll need to purchase a new hose. You may purchase this hose directly from Sears, however when you buy the hoses through Sears you have to assemble the hose yourself, which is very challenging. An easier way for you to replace the hose, is to purchase a Panasonic canister hose. There are two types of hoses, a 2 wire hose, and a 3 wire hose that fit most Kenmores. When you take the hose out of the canister, look on the part that plugs into the canister, how many prongs do you see here? If 2 then you'll need a 2 wire hose, if 3 then a 3 wire hose.
If you are not able to locate the short in the hose, then you may have a short either in the wand, or the power nozzle neck wire. For the wand, put one foot on your power nozzle while it's running, then pull up and down on the end of the wand that plugs into the canister, as well as the end that the hose plugs into. If you can get the vacuum power brush to cut on / off when you're doing this, this indicates your wand is bad and needs to be replaced. If it doesn't cut on / off, remove the wand and hose from the vacuum completely. Now look where the wand connects into the power nozzle. You should see two electrical prongs on the neck of the power nozzle. Do you see any burns, or black marks on the prong, or the plastic part that it comes out of? You can also test this part by turning the vacuum's neck to the left and to the right as if you were turning the vacuum.
Hopefully this helped you. If you need further help on figuring out which part is bad, please just use the clarification request here on Fixya, and I'll be happy to try and diagnose this further with you.
Thanks,
Chris J.
GoVacuum
Mar 25, 2010 | Kenmore 23812 Progressive PowerMate Bagged...
Just bought new power head electrolux guardian and
Did you get new wands with the power nozzel? The wires that power the nozzel run through the wands from the hose to the nozzel.The connectors at the end of the wires are fomous for getting too big and making a bad connection. This causes the on/off problem. This will only get worse if you continued use. The wires in the hose handle, the hose and the power nozzel elbow can all be changed out. You will not have to replace the hose handle or the wands unless the plactic has been burned. (A loose electrical connection causes heat). Take your hose,wands and nozzel to the shop for repair. Don't let the sales/service manager tell you that you need new parts until you can see the parts are bad. I think they saw you comming when they sold you the new nozzel.(just my opinion)
Oct 15, 2009 | Electrolux Guardian Bagged Canister Vacuum
Don't know how to use carpet shampooer
You should have the new aquamate, it has a blue top to fill with the water and water/soap solution that pops down into place. You will need to use your power nozzle hose and tube, connect it to your shampooer (make sure to connect the power connection just like the power nozzle). Fill your water up, large compartment is for cold water only and the smaller compartment is for one cap full of soap then the rest filled with cold water. Start with just a splash of water or an empty basin in the rainbow. The trigger will control your water spray and the brush underneath. There are two levers on the back of the shampooer marked with a shower head and a bar of soap. Use the soap with the shower head and the soap on and the water only with just the shower head on. You will want to also go over the area shampooed with both off to **** up the remaining water. Make sure to clean your floor thoroughly before shampooing.
Aug 13, 2009 | Rainbow E series Canister Wet/Dry Vacuum
Need to know if a replacement part can be purchased and where
Kenmore canisters are privately labeled Panasonic canisters and sometimes panasonic parts will fit them. Any reputable independent dealer should be able to tell you if the part you're looking for is intercharngable with a Panasonic, but he/she will probably need to actually see the unit.
Your other option is to take it to the Sears service dept. They are the only ones who have access to the schematics and "Kenmore" parts. It'll probably be more expensive through them though.
Dec 02, 2008 | Kenmore 22812 Bagged Canister Vacuum
Hose connection broken.
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=552957
Generic problem for all Vacuums
Posted by nualaheaneyi on Apr 28, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
If you have a broken hose connection, and not knowing the brand name of the vacuum, I can suggest 2 things. If you have an electric hose, meaning that it is attached to a electric power head or power nozzle, some can be repaired depending on what was wrong, but most of the time you have to replace the hose, some pigtails can be replaced but if the electric connection is broken, you need to replace the hose. If it is a non-electric hose, you can use a shrink tube, or cut out the broken part and use a hose cuff to join them together, so just shorten the hose and screw back on the original ends. In either case you need to check with a local vac dealer. Or you can make a new hose with new ends and leave the canister @ the bottom of the stairs and go up with just the long hose, unless you have an upright then you have to make it the length that is on the upright. Or replace it with the genuine hose from the factory or use the ends from the old hose on the replacement hose. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
Thanks, Don – The Vac Man
Go Ahead. Use Us.
Apr 28, 2008 | Vacuums
Vacuums Logo
21 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
