Power/charging light flashes in a sequence of five flashes three flashes, repeats - - - both with and without charger attached - is supposed to be blue when connected - - - system does not boot toshiba u205-s5057
    Brigadier General:
  • 3,513 Answers
Please check the bellow link if it helps:-
http://superuser.com/questions/74282/hp-dv1000-laptop-wont-start-flashing-power-light
Please accept the solution if it's helpful. Do get back to us for any further query.
Posted on Oct 07, 2010
Nikon s6300 won't turn on
Coolpix Cameras are tricky to use with chargers. I will assume your USB Charger EH-69P is 100 - 240V 50/60 Hz so it CAN work in many places around the world with an adapter. Do not go over 240V or you could damage it.
These cameras like to have the power supply connected when it is on to charge - meaning if you have it connected and you plug the charger in the wall it will NOT charge. So if you plug the charger in the wall first and then plug the cable in the camera it will work. The camera is actually ON when it charges and I never REMOVE the memory card when it is ON.
When you have a dead battery. Plug the camera in and make sure the ON LED lights and the Charge LED flashes. Then don't mess with it. Let it charge completely (Charge LED stops flashing and is OFF) and then unplug it. It will turn off. Then later you can turn it on.
May 08, 2017 | Nikon COOLPIX Cameras
Sony LCD turns off 34 flash turn on 30sec repeats ...
The self-diagnostic function of the projection television will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue, some of which you may be able to resolve without the need for service.
  • If the STANDBY light flashes three times in sequence, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
  • If the STANDBY light flashes four times in sequence, the television may be overheating. To resolve this issue, ensure that the back of the television is well ventilated.
NOTE: If the television will not turn on immediately after being turned off, wait for the fan to finish its cycle, then attempt to turn it on again. This is part of the cooling process of some projection televisions and is normal operation.
If the flash sequence is not listed above, or the light continues to flash after troubleshooting the indicated issue, follow the steps below to perform a power reset on the television:
  1. Turn off the television. IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
  2. Unplug the television power cord from the electrical outlet.
  3. Let the television remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
  5. Turn on the television.
If the issue is still unresolved after following all of the troubleshooting steps, service may be required. Please note the number of times the STANDBY light flashes and relay that information to the service center.
lno2()
Dec 14, 2007 | Sony Grand WEGA KF60XBR800 60" Rear...
Standby time light on and keeps flashing
The Standby/Power light of the TV blinks when there is any internal malfunction in the TV.
The self-diagnostic function of the projection TV will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue. As per the two examples below, some of the issues may be resolved without the need for service.
If the STANDBY light flashes four times in sequence, the TV may be overheating. To resolve this issue, ensure that the back of the TV is well ventilated.
If the flash sequence is not listed above or the light continues to flash, follow the steps below to perform a power reset:
Try the following steps to check if the issue can be resolved.
If the issue continues to occur, service may be required.
Thanks for using Fixya.
May 21, 2011 | Sony FD Trinitron KD-36XS955 36" TV
Red blinking light
Aug 14, 2010 | Sony KP-53HS10 TV
My display keeps shutting off five minutes after starting to watch TV- the sound continues, but the screen is black and the red warning light flashes
Please check the sequence in which your warning light flashes.
I will tell you what might be the problem according to the fashing of warning light,
If,
Flashing repeatedly --- Improper voltage supply
Flashing once --- Malfunctioning of fan
Flashing twice ---excessive temperature
Flashing 3 time or more--other problem
When flashing occurs please remove the power cord from receptacle and inform your dealer about the flashing sequence.
Thanx
Jul 02, 2010 | Fujitsu Plasmavision 42" TV
Tv keeps turning itself off and then back on. green power light blinks. If i tun it off when it does that the red power light blinks 5x repeatedly.
Jun 22, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
Have a p103 battery that was in the p113 charger overnight and don't think it ever got out of the testing phase. The only difference was that the red light would flash about 5 or 6 times then stay on...
If you are sure your charger is working properly then your one battery may be shot.. i even had a new battery quit charging and had to replace it. they do not come cheap.
Apr 10, 2017 | Ryobi Two 18V Lithium-Ion Batteries +...
I have a problem with the charging bias software. The power button light starts to flash and charging stops. I have to disconnect the mains power, wait until the pb light stops flashing and then power up...
I had this with a laptop recently. It could be one of three things, the first is the charger, which was my problem. The second is the battery. The third is the charging circuit which is also the most expensive to repair.
Please take a moment to rate my solution.
Thanks.
Simon.
Rytech Computer Services Limited
Dec 01, 2009 | HP Pavillion ZV6000 Athlon 64 3500+ 15.4in...
My camera has focus error. How to solve the problem?
Performance wise, the camera has a couple of niggles. Start up to first shot time is around a second, and shot to shot (without flash) is good with three shots (the top three or the last three in a sequence are captured) in around 1.5 seconds unless the camera needs to refocus ort the flash fires. Flash recharge is around five seconds and disappointingly, the camera locks up as the flash charges, which is a shame.
But, focusing becomes an issue in low light too, where the camera will hunt trying to key on the subject or just continually fail to focus. So, beware in low light. There was another focus niggle on smaller subjects in macro mode where the camera would simply refuse to focus on anything in the frame smaller than the central AF area, and no matter what you do. Thanks
Oct 12, 2009 | Fuji FinePix Z100fd Digital Camera
Motorola i880 white screen flashes i880 won't charge
the i880 & the i885 needs a quality charger, if you get a original Motorola charger IT WILL WORK. There are some aftermarkets that will work, but not many.
Mar 24, 2009 | Motorola Mobility i880 Cellular Phone
Computers & Internet Logo
83 people viewed this question
David Payne
David Payne
