Question about Vacuums
Shuts off after prolonged use. - Vacuums
  • pwillitz Oct 07, 2010
    What make and model number is it?
  • 171 Answers
What is the make and model. Some machined have a sensor that shuts trhem off when they get warm because this usually means the bag is full. also make sure all the filters are clean, If they are sponge you can rinse them. dont reinse any other type odf filters and also allow thye sponges to dry before turning iy back on.
Posted on Oct 07, 2010
I need to know how much water to put in it.
press the helpful button
Fill the provided measurement cup to the maximum fill line with water. In areas with a high mineral concentration in the tap water, we recommend using distilled or demineralized water to prolong the life of the steam cleaner. Using the funnel, pour the contents of the cup into the reservoir.
Top Innovations, Inc.
400 NW Platte Valley Drive
Riverside, Missouri 64150
www.mitcoproducts.com
1-800-711-6617
http://steamerstore.com/steamfast/manuals/SF-250_Manual.doc
Jan 28, 2016 | Steam Fast SF-250 Mouse Vacuum
Tip
How to Prolong the life of your Vacuum leaner
There are several types of vacuum cleaners these days. Most people now seem to use the upright bagless vacuums since you do not have to buy the filter bags. Those vacuums are fine, if you take the proper care of them. Ithink it is a bit messy. In order for you to really prolong the life of any vaccuum, you must make sure the machine has plenty of circulation. In order for the vaccuum do the great job you expect, you have to do a little maintenance on it.
  • Each time you run the vaccuum,
  • Take out all filters (foam & the plastic inserts)
  • Wash the filters out with warm water.
on Jan 06, 2010 | Vacuums
Remington Cordless Salon Hair Straightener I don't know if I should charge it when it is set 'ON' or set 'OFF' ? Lost the instructions but seem to remember it was a definite one...
charge it after use ,, allow the battery to go down almost fully , then charge it . this will prolong the life of the battery
May 22, 2011 | Vacuums
What do the numbers on the Kirby G5 beater bar end caps mean?
The numbers on the beater bar end caps are used to lower the brush down as the bristles wear down. When you bought the machine, the brush roller started in the 1 setting. One year later, after the bristles have worn down, you can move the numbers to 2, then 3, etc.
It's a pretty neat concept by Kirby, it prolongs the life of the roller brush significantly.
Hope this helped you,
Chris Jones
GoVacuum.com
Jan 05, 2011 | Kirby Ultimate G Bagged Upright Vacuum
VACUUM CLEANING IS NOT COMING ON
Check for power in the plug to the main switch. In most cases the long wires break or damage affter prolonged use. If the switch activate power then check power tilll motor. If so the motor is defective and might be though of for estimation of cost. Look out also for a load trip switch.
If motor brushes are bad clean and set but if winding is open you need to estimate.
Sep 18, 2010 | Vacuums
How do you replace the belt on my Kirby G5 vacuum cleaner?
Hi There,
We've created a great video demonstration on how to replace the belt on Kirby generation vacuum cleaners. This will walk you through step by step on how you can replace the vacuum's belt, as well as do the basic maintenance on the roller brush to prolong the life of your belt.
I hope that this video helps you! If so, please be sure to rate my repair by clicking the 4 thumbs up icons in the top right hand corner of the repair.
Thanks again,
Chris Jones
GoVacuum.com
Apr 15, 2010 | Kirby G5 Bagged Upright Vacuum
Dyson 07 plug gets very hot after prolonged vacuuming
Electrical current passes through the electric cord and plug - it will get warm, that's normal. If the problem is worse where you smell an electrical burning smell, only an authorized dealer can fit a new power cord to your vacuum cleaner. Call the Dyson helpline, they will let you know who the closest repair dealer in your area is.
Jul 05, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Sparks and smoke
you either have something worn out or the motor inside is going bad. Sounds like the motor in the power head is going bad. Disconnect the the wand from the power head and flip over the head take the plate off. then take the plastic cover off uou should get to the motor then. look at all the parts. I would think you need to replace the brush roll, belt and motor. But this is just a guess
Jun 26, 2008 | Filter Queen Majestic Canister Vacuum
How long am i suppose to charge my vac?
If your battery is not holding a charge, then you will need to replace the battery. Unless the charger isn't working, but usually it is the battery.
Jan 28, 2008 | Black & Decker CHV9600 Handheld Vacuum
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
