Question about Car Audio & Video
Is it my amp not working?
Hi dont no if u can help but i have a problem with my sound system,
everything seems to be wired up correctly but my sub only seems to working as a speaker, and my 6x9's arnt producing any sound at all. My amp Led is on but im not convinced its working properly.
The whole system is kenwood, the amp is 1000w and the sub is 800w
does anyone have any ideas whats wrong?
  • rob324 May 30, 2008
    cheers maybe it is that with the amp,
    i forgot to say the sub is working fine because it was used and was working fine.
    Problem Solver:
  • 6 Answers
First, provide the amp model number. Second, ensure that you are not using a Front or Rear line-out of the radio and have the radio in High Pass Only mode. Third, ensure that the switch located on the amp is is LP (low pass) mode and that you turn down the frequency control on the amp to somewhere around 80 or below. If none of those things are doing the job then you need to ensure that you have grounded the amp securely with it's own ground (not with a factory bolt or screw) on the floor of the vehicle. Scrape away any paint and use a self tapping bolt without over-tightening it. Also ensure that your power lead at the battery is tight as can be and that the connection is clean. Hope this at least helps determine if the amp is at fault or not.
Good Luck! Dan
Posted on Dec 15, 2008
Maybe the amp is fr the high and lows because if its bass that shukd do it but most of the time it could also be that the sub is poped
Posted on May 29, 2008
Sub system won't play can't find in settings amo hooked up to subs yet still nothin help plz
Is the amp switching on? There are two 12v wires that have to be connected. One from a direct constant 12v supply source, and the other one from the ignition switch 12v source.Find a single 12v. supply which you can take from the lighter connection and then trace a 12v wire that runs from your ignition switch. This is mentioned in the amp manual.Double check. If the amp is coming on but no sound, then your wire connections from the amp are not correct.Or you have also connected the speaker wires incorrectly.Remmember not to connect the earth of the speaker wires to the direct earth(body of the car) but to the earth wires that are shown in the manual as this could blow the amp power IC. The earth wires of the speakers are marked -- and + respectfully and are also colour coded.You should have a RCA female plug connector from your amp to the subs. Check everything double and if still no luck their is a possibility that you could have blown an IC in the amp from wrongly connected wires. Hope this is not the case.
Apr 15, 2013 | Car Audio & Video
I just bousght a martin ash home thearer ..how can i conect the bass??
I bought one last night i think its a fake.... doesn't even have instructions. If u figure this out let me know. But i just look up the site called the white van scam... i bought it from some guys in a white truck. And it sounds just like wat they sold me with the same canvas
Apr 18, 2012 | Audio Players & Recorders
I have all alpine speakers,deck,amp, and subs. My subs were working for about a year until one time i started my car and they keep cutting in and out .. at times they will work but then they cut off...
Sounds like blown subs, in the process of completely dying out, or a loose wire, possibly inside the box or from the box to the amp. Have your subs tested at a sound shop, or using a multi-meter, check for resistance across the sub terminals. An open line indicates a blown sub.
Jan 19, 2011 | Alpine MRP-M500 Car Audio Amplifier
No sound from subwoofer Solo Baric L7
check the resistance of the sub with a digital multi meter, make sure you dissconect the sub from everything before you check the resistance, if your sub is supposed to be 4 ohms than it should be between 3-5 ohms, if it is under 1 that the sub is blown, while the sub is dissconected from the amp, turn the system on, does it still go into protection?
Jan 17, 2010 | Kicker Solo-Baric L7 10'' Car Speaker
Subwoofers dont bump
No such thing as a typical sub system. Be more specific? If the subs are moving well and just not basing you will need to check 2 things first. Try the polatity of the speakers (reverse one) they may be out of phase and will cause the bass to cancel eachother. Another cause is the box may the incorrect size for the speakers and will not give you the correct sound the speakers are capable of. If neither of those work check your amp settings and make sure its set on sub/low frequency.
Sep 05, 2009 | Kicker KX600.1 Car Audio Amplifier
I turned my car on and when the amp turns on one speaker pushes out and the other pushes in and stay like that and dont produce any sound. i checked the wires and fuses and everything is correct but i cant...
Hello mikhail_1994,
I'm assuming that the amp was installed and was working properly.
It sounds like the output is shorted. The CH450 may be operated as a 2-channel amp or both channels can be bridged for mono powering subs at an impedance of 4ohms or more.
I'd test the sub voice coils and then test each channel of the amp separately.
Hope this helps.
Jul 20, 2009 | Boss CHAOS CH450 Car Audio Amplifier
My amp was bad so i replaced it now my sub does not work i checked the wiring that goes from the amp to the speaker and everything seem to be ok then i put another speaker thinking it might be the sub and...
It doesn't sound like the wiring from amp to sub is your problem.
Is your amp getting a power light ?
Are you sure your remote wire is hooked up properly ?
Check both ends of your RCA cables
Jan 05, 2009 | JBL GT150 Car Subwoofer
My Subs blew out but I dont know why??
rewire the whole system with new wires,you could have a bad ground or wire try it first if that dont work rewire
Jan 08, 2008 | Jl Audio 12W3 Car Subwoofer
Car sound system. only sub is giving off sound. other 4 speakers dont work at all
Could be bad outputs from the back of your head unit or also could be bad rca cables. Make sure the amp is on and powered.
Dec 13, 2007 | Kicker CompVT CVT654 Car Subwoofer
No sound comming from car speakers
What kind of car? What kind of system? More details will help me assist you better. If it is an aftermarket in-dash stereo, it sounds like the blue/white wire is not hooked up correctly. This powers up the car's amplifier and lets the sound through.
Sep 20, 2007 | Car Audio & Video
Car Audio & Video Logo
102 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
