Shutting down it self when I'm watching, typing and surfing..
  • 2,567 Answers
This could be a sign that your laptop is overheating. If you touch the laptop while it is running & you find it too hot, make sure that the fan is running properly & that the air ways are not blocked.
You can blow compressed air into the cooling vents of the fan. If you notice clouds of dust coming out, then it might be a good idea to disassemble the laptop, clean the fan & air ways, & reassemble it back. If the fan has failed & is no longer running, it might need to be replaced.
Posted on Oct 07, 2010
Why does it keep shutting down?
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Type in the brand name and type of your device, in the search box [at the top right] of the display window; to gather down all the posts related to your device brand. It will make surf easy.
Jun 15, 2015 | Dynex Televison & Video
My tv shuts down when watching it.
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time.
Sep 03, 2014 | Olevia 227-S11 27 in. LCD TV
Neo m1110 beeps and shuts down
Hello
This is a common laptop problem. Your need to open it and clean your Laptop fan. Laptop heat sink are covered are dirty and the air can't go through and the laptop shut it self off so your laptop doesn't burn any components. If you're not good in opening laptop. I suggest take it to a Computer repair service. If you can to open it and do it your self. There are a lot of videos on YouTube.
Tare-down link : http://www.youtube.com/watch?v=021O8rIffsk
Please rate and Thanks
Feb 06, 2014 | Computers & Internet
While browsing net r watching movies my lap(acer extensa 4630)shut down itself
The processor has to perform large amount of work while surfing , especially while usingvideos and animationMultiple windows/tabsnumber of browserwhich in turn produces lot of heat . The heat produced is managed by the interneal heat sink and inbuilt cooling fans.But this cooling process may get affected by the blockage in air vents due to dust.So to safeguard the laptop form overheat, it automatically shuts down.
One simple try :Go to the Adobe flash properties and disable Hardware acceleration for online content. That ought to stop the system from rebooting or crashing.
Else...Its better to call a technician when it shuts down often.....
Apr 10, 2012 | Acer EXTENSA 4630Z COMPATIBLE LAPTOP LCD...
Stops after i take it off, I have to shake it to get it going again, problem is intermittent, I have no clue...
Your watch is self winding and will run down (if fully wound) for about 2 days.
This type of watch thrives on use and if not used will stop. To avoid having to re-wind by shaking, it should be worn every day.
(Some makers say that to full wind up their self winding watches, they need to be shaken (gently) aboiut 200 times).
Apr 15, 2011 | Rolex Daytona 116520 Wrist Watch
My iphone randomly shuts down during calls, can you help me?
As your phone shuts down randomly please restore the settings and you wont have this problem again.
Note: Resoting will delete all content from the phone.So please take back up of the content from the phone.
To restore the iphone please watch the videos below.It is self understanding.
http://www.youtube.com/watch?v=P9BFanKzCKc&feature=related
http://www.youtube.com/watch?v=ofpinyGlQ8I&feature=related
thank You
Aug 16, 2010 | Apple iPhone 3G
I bought it new and then a few weeks later the battery seemed to stop. I did not wear it often. I heard some watches do not use battery and function with the movement of one's arm. Is this the case for...
If the watch is a self winding type, then it generally says "automatic" on the face. These will run for about 2-3 days if they are not worn, as the self winding action only works when the user is moving).
Battery driven watches should run for at least a year before needing a replacement, so if it has stopped already, it could be self winding or manually wound type. Some self winding watches can be manually wound so you could try this to see if it starts.
Aug 14, 2010 | Watches
Turning off
Perform power drain ( remove all accesories including the battery and the power adapter) press the power button for 1 minute.
Connect the power adapter only then turn on the computer - try using for more than 1 hour. If the computer does not shut down then the issue is the battery.
Run anti virus software.
If problem still persist it is a posible hardware issue. If you are still in warranty you can call sony and they can help you fix the issue for free.
Mar 27, 2010 | Sony VAIO Notebook
Shutting down
Hi, Try cleaning the air outlet vents on your Laptop. you can try blowing a can of Air and also chk the power option on your computer control panel.
Jan 31, 2009 | Dell Inspiron 1501 Notebook
Shut it self down after 5 seconds.
TV's have a circuit that monitors the high voltage and shuts down the set if it senses something amiss.
On projection types, figure on just replacing the entire board that has the flyback transformer on it.
Jan 02, 2008 | Panasonic PT-53WX42 53" Rear Projection...
Computers & Internet Logo
David Payne
David Payne
