Question about HP Computers & Internet
HP had slow problem
Hello I had HP Compaq d7200 microtower PC. It contains 248 MB of RAM and 80 GB hard disk. Since 4 month it is going slow so I format it from Restore CD but it had problem still. If I right click on desktop menu appear after 30 seconds.
I want to full format it but I dont have it motherboard CD, so I dont have sound and other software, I have only restore CD, and operating system CD.
Please tell me how would I full format it.
  • kfamer Sep 28, 2008
    dear sir, i had hp Compaq d7200 microtower PC. It contains 1000 MB of RAM and 80 GB hard disk. last hard out and i put new hard and setup it xp windows . I want to full format it but I dont have it motherboard CD, so I dont have sound and other software, .
    Scholar:
  • 187 Answers
Your restoration CD should be doing the full format for you. If not, and your operating system CD is the actual Windows CD (with the logo etc), then you can use that instead. Simply put the CD in and have the system boot with that. Once the CD loads, it will ask you whether you want to install Windows, or repair the current installation - ask it to install (NOT repair), then follow the on-screen prompts.
Posted on May 29, 2008
Hp Compaq dx2200 MT RAM Problems
Firstly, you have to know that you can upgrade RAM as Double or Half of your pre-installed RAM. For example, like your pre-installed RAM is 256 MB, you can only upgrade RAM of capacity 128 MB or 512 MB. Secondly, check your previous installed RAM's speed that is shown in Ghz. You can only upgrade RAM to its similar speed, otherwise you get slow performance of PC.
Jul 18, 2010 | HP Compaq dx2000 Microtower PC Desktop
I got 256mb internal ram and i put 1gb external ram on my hp compaq nx6110 laptop and after few months my hard disk stops working. so now i want to buy a new hard disk so how many gb of hard disk i should...
I think you're confusing RAM (memory) with hard disk space (storage). Installing more RAM makes your computer run faster. More hard disk space gives you more room to store stuff. Which would you like to do?
Apr 03, 2010 | HP Compaq nx6110 Notebook
I have sys which contain main board marrcury(p1865d7).now i will run visual studio2008 but not properly run so plz give suggetion @ processor & ram
According to Microsoft: Minimum: 1.6 GHz CPU, 384 MB RAM, 1024x768 display, 5400 RPM hard disk Recommended: 2.2 GHz or higher CPU, 1024 MB or more RAM, 1280x1024 display, 7200 RPM or higher hard disk
I know that Visual Studio 2008 runs fairly slowly on a 2.4GHz laptop with 1GB RAM, so I can't imagine that it would run all that well on a 1.6GHz machine.
Feb 01, 2010 | HP Compaq Presario SR2013WM (RE468AA#ABA)...
IS IT POSSIBLE TO INCREASE MEMEORY? BOTH RAM AND
Yes, it's possible to increase both RAM & HARD DRIVE Capacity.Your Pc comes with RAM: 512 MB in size and Storage (hard drive)Capacity: 80 GB.
You can put One more 512 MB of RAM or you can replacethe ealier RAm with 1GB RAM or Put two 1 GB RAM Instead.
For Hard Drive,use your 80 GB Hard drive as external storage device, and Put a 320 Gb new Hard drive.
Dec 26, 2009 | HP Pavilion dv1000 Notebook
How much i can upgrade my d530 ultra slim desktop RAM and HDD
You can install up to a max 2 GB RAM and can add a 2nd hard disk
See the following Specs for your computer.
dotclear.gif HP Compaq Business d530 Ultra-Slim (Pentium 4 2.8GHz, 256MB RAM, 40GB HDD, XP Pro) Type Personal computer
  • Product Form Factor Ultra-slim desktop
  • Built-in Devices Speaker
  • Width 12.4 in
  • Depth 13.1 in
  • Height 2.8 in
  • Weight 15.4 lbs
  • Color Silver
Processor
  • Type Intel Pentium 4 2.8 GHz
  • Installed Qty 1.0
  • Max processors supported 1.0
Cache Memory
  • Type L2 cache
  • Installed Size 512.0 KB
  • Cache Per Processor 512 KB
Mainboard
  • Chipset type Intel 865G
  • Data bus speed 533.0 MHz
RAM
  • Installed Size 256.0 MB / 2.0 GB (max)
  • Technology DDR SDRAM
  • Memory Speed 333.0 MHz
  • Memory Specification Compliance PC2700
  • Form Factor DIMM 184-pin
  • Upgrade Rule Max 2 x 1 GB module
Storage Controller
  • Type 1.0 x IDE - Integrated - PCI
  • Controller interface type ATA-100
Storage Controller (2nd)
  • Type 1 x Serial ATA - Integrated
  • (2nd) storage controller interface type Serial ATA-150
Storage
  • Floppy drive type None
  • Hard Drive 1.0 x 40.0 GB - Standard - ATA-100 - 7200.0 rpm
  • Hard Drive (2nd) None x None
Dec 08, 2009 | HP Compaq Business d530 Ultra-Slim PC...
I need to replace the hard drive in my v5000 Compaq laptop. it is currently a mk8025gas toshiba 80gb. how do i choose a newer updated hard drive to match? do i just install and turn back on with the xp...
Basically you insert a new drive and insert the Windows XP installation CD and follow the screen instructions.
The specification for hard drives for the Compaq V5000 are as follows :-
Table 6-3
Hard Drives
120-GB* 100-GB* 80-GB*
Dimensions
Height
Width
Weight
9.5 mm
70 mm
102 g
9.5 mm
70 mm
102 g
9.5 mm
70 mm
99 g
Interface type ATA-5 ATA-5 ATA-5
Transfer rate
Synchronous (maximum)
Security
100 MB/sec
ATA security
100 MB/sec
ATA security
100 MB/sec
ATA security
Sep 30, 2009 | Compaq Presario 1.8GHz Mobile AMD SempronT...
Will a hp compaq 6735s support spore?
This is something simple you can do yourself. In the future, look up your model laptop then the specs on game, use google.
"HP Compaq 6735s spec"
http://www.cdfreaks.com/hardware/product/86792-HP-Compaq-6735s-Notebook-PC.html
Processor Processor family AMD Turion X2 Dual-Core Mobile Processor RM-70 Processor clock speed 2000 MHz
Memory Memory upgrade <8192 MB GB Internal memory 2048 MB
Video Video card features ATI Radeon™ HD 3200 Video modes resolution 1280 x 800 WXGA Disk drive Total storage capacity 160 GB
"Spore spec"
http://www.spore.com/what/specs_spore
  • FOR WINDOWS VISTA
  • * 2.0 GHz P4 processor or equivalent
  • * 768 MB RAM
  • * A 128 MB Video Card, with support for Pixel Shader 2.0
  • * At least 4 GB of hard drive space, with at least 1 GB additional space for creations.
Everything seems good, the only thing is how much HD space you have.
My computer>Roll over your mouse above the C drive and you will see how much is free out of your 160gb space.
Sep 10, 2009 | HP Compaq 6735s Notebook
Adding an RAM to a Compaq PC
The laptop supports upto 4 Gb RAM.
Following is the user manual on how to replace the RAM
http://h10032.www1.hp.com/ctg/Manual/c01118662.pdf
Thanks
proton
Jan 10, 2009 | Compaq Presario C700T Notebook
Entering bios
the bios wont support anything higher. Go the the website and flash it with the new bios download.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&cc=us&docname=c00004461&dlc=&product=92867&lang=&
Jun 07, 2008 | Compaq Presario 5000 PC Desktop
Computers & Internet Logo
60 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
