Question about Toshiba Computers & Internet
I have a Toshiba laptop that is approximately 1 1/2 years old. Well anyways, I turns on but it will not boot up. Any ideas?
    President:
  • 2,571 Answers
Make sure there is no disc in the dvd drive or usb device plugged in.
Try booting into safe mode (F8 while booting) and try a system restore
It may be that its just your MBR (boot file) that is damaged, if you google fix mbr, you may be able to get it working again. (may need a windows disc)
You may also have an option of system recovery (factory restore) from the F8 menu or other boot menu depending on the make of the laptop
Posted on Oct 07, 2010
  • 479 Answers
If the laptop turns on and does not bootup, the issue may be with the operating system itself. You will need to recover the operating system with the help of cd.
Thanks
  • azsrule Oct 07, 2010
    Well, I figured it out through the internet. It is a faulty battery. I removed the battery, plugged it, and it worked. Thanks anyways. FAULTY BATTERY!
How much is this?
approximately $57-58 dollars. Most of retailers gives the suggested price at $57.99
Nov 05, 2010 | Toshiba Satellite A100-S8111TD Notebook
My toshiba won't boot up after self-hibernation
yes but frirst try to see in the power obtions if yoy have set the note book for this or it is a hardware problem
Oct 24, 2009 | Toshiba Satellite Pro A210-EZ2202X...
Gateway MA7 laptop
If display issue: connect an external monitor to see if any change.
Could be spyware - boot in Safe Mode (F8) - download, install and run SpyBot (spybot.com).
Good luck.
Jun 12, 2009 | Computers & Internet
Problem with toshiba A135-S4527 ,MOTHERBOARD NOT INITIALIZING
Have you left a cd in drive? It could be trying to read a disk to boot from if thats how your boot order is set up. This is the first simplest thing to check.
Char S
May 24, 2009 | Toshiba Satellite A135-S4527 Notebook
Can't recover
Toshiba Laptops: - Toshiba Utility
Toshiba: - Press Esc during boot
Toshiba, Phoenix, late model PS/1 Value Point and 330s: - Press F1 during boot
Oct 24, 2008 | Toshiba Satellite 5005-S504 Notebook
Laptop monitor goes black
If you're working on the computer when that happens, it's not probably a power setting. Try to update your BIOS to the most current version at the toshiba support website (support.toshiba.com) & see what happens. Fixes the issue most of the time
I hope this helps.
Aug 25, 2008 | Toshiba Satellite A100-S8111TD Notebook
Toshiba Satellite Laptop Power Failure (A105-S1013 System Unit)
Okay, lets troubleshoot this:
1)Does your laptop run on battery alone ?
yes )test your jacks continuity to the motherboard using a continuity tester or Digital Multimeter.
a)test between the center contact and the motherboard.
b)test between the outside metal cover of the jack ,and the motherboard.
c)If either of these fails continuity,replace the jack.
2)does your laptop now power up on AC ?
yes)Stop
No)Try the BIOS upgrade.
Feb 10, 2008 | Toshiba Satellite A105 Notebook
Power cycling
Hi, If the power on/boot up sequence does not even reach the Windows logo before recycling, it is not a software/virus issue. If at certain times the laptop would continue powering up and booting into Windows but more often recycle the powering up process then I am inclined to think that it is a hardware problem. Hardware possibilities: 1. Might be loose connection or corroded terminals/connectors; 2. Cold solder of surface mounted components in the mainboard; 3. a USB device is interacting - try booting without any USB devices attached; 4. try running the Toshiba without the battery and just the AC adapter; Your possible options: a. Try performing #s 3 and/or 4 and note if there is a significant change in the booting process; b. 1 & 2 would require opening the laptop and do a circuit diagnosis, you might be better off seeking the services of a qualified professional. Hope this be of some help/idea. Post back how things turn up or should you need further information. Good luck and kind regards.
Sep 03, 2007 | Toshiba Satellite M45-S169 Notebook
Computers & Internet Logo
156 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
