Question about HP Pavilion F1503 15" LCD Flat Panel Monitor
How do i take apart a hp pavilion f 1503 monitor to change the bulbs. someone told me this could be done. the monitor is so dark you can hardly see the screen
  • Louis Ebert Oct 07, 2010
    soulesy, You should visit here first: http://www.lesliewong.us/blog/2005/05/02... Then you will be able to make decision on what to do. Lots of video clips you should see at YOUTUBE also!!! Problem may or may not be the CCFL lamps at all!! Your unit is OLD!!! Look at the "date of manufacture" on rear of it!!!
    Good luck. 12fixlouie
  • soulesy Oct 07, 2010
    I know that my unit is old but my daughter only uses it to write papers on. She is only 10 and doesn't really need anything else for now. Don't want to spend the money on a new computer for her.
  • 11,361 Answers
It is the same as http://s807.photobucket.com/albums/yy352/budm/HP%20F1703/
17 model, just smaller. Remove the stand and Starting at the bottom edge first. It may not be lamps problem but inverter circuits probelm due to caps.
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://en.wikipedia.org/wiki/Capacitor_plague
Lamps: www.lcdparts.net
Posted on Oct 07, 2010
  • Louis Ebert Oct 08, 2010
    soulesy, You should explore links that are in the response you have from "budmrtn". If you are to repair this F1503 unit you will need to borrow or buy a cheap soldering pencil, solder wick, solder and be prepared to investigate the circuit board that supplies 5volts and 12volts to the other circuits inside unit. Doing the Disassembly is the hardest part and you should have someone document teardown with video camera so you can get it all back together again with no leftover parts on table. 12fixlouie
Screen is dark and contrast and brightness are up to max, can a new bulb be put into the monitor?
To replace the crt picture tube will be an expensive exercise as they are not bulbs as such but the entire screen needs to be replaced as they are a complete unit.
Jan 01, 2010 | HP Pavilion MX70 17" CRT Monitor
I have an hp pavilion 1503 monitor and it blacks out after a few seconds after turning it on.
Open your monitor up and look for 4 coils on the circuit board. Re solder these coils to the board and it should work fine.
Oct 14, 2009 | HP Pavilion F1503 15" LCD Flat Panel...
Monitor display is sideways not vertical
with some graphics card you can rotate the display try pressing ctrl and the alt key at the same time and while doing this hit the arrow key (or direction) that u want the bottom of the screen... so if u want ur screen upside down, hit ctrl alt and the up arrow
Aug 13, 2009 | HP Pavilion F1503 15" LCD Flat Panel...
Acer x 223w monitor and what video card
I have not answered the question about this problem, however someone else told me that I would have to change my graphics card to take full advantage of the features of the X223W monitor. But they did not know what I had to change it to.
Jan 18, 2009 | Acer 22" X223w LCD Monitor
Hp slimline pavillion 1503 LCD 15"
plug the speaker cord into the LIME GREEN port on your computer.
Click on the speaker icon at thee bottom of the display to make sure you are not MUTED.
Dec 19, 2008 | HP Pavilion F1503 15" LCD Flat Panel...
Ref:hp pavilion f 1503 power supply
HP / COMPAQ
PAVILION 1503 D5061-A F1044A F1044B F1503 1703 F1703 VF51 VF52 L1800 0950-3415 ADPC12416BB ADPC12350BB
Input: 110-240V 50/60Hz Auto-Detect International Compatible Output: 12V DC, up to 5A / 60W max (Great upgarde for lower wattage)
Connector: Barrel, Center +
Dec 14, 2008 | HP Pavilion F1503 15" LCD Flat Panel...
Display dims
My HP laptop monitor would go very dark (sometimes still legible) and it did it infrequently. The problem got worse and I could temporarily fix it by flicking the monitor off botton (i.e. the thing that sticks out to turn the monitor off when you close it). Ultimately, I had to replace the inverter. It was simple (once I found how to take it apart online) to replace the inverter and it fixed the monitor problem. This is after a computer technition told me that I needed a new bulb or for a little more he could get me a new monitor. Maybe there are some good computer repair guys, but I am now leary of them.
Jul 18, 2008 | HP Pavilion dv8000t Notebook
Hp pavilion 1503 monitor lcd
Believe it or not, I got given a f1503 not working but without the power cable. He said the same thing everyone else is saying. I did not have a 12 volt 3amp converter but a 12 volt 1.5 amp converter. Plugged it in turned it on and wow it worked fine. It has been working for 1 week on with no problems. So try a different power converter, worked for me.
Jul 06, 2008 | HP Pavilion F1503 15" LCD Flat Panel...
HP Pavilion F1503 1503 15in Flat. screen blanks out constantly
THis is a problem of the invertor board.If you are technically able you need to disasseble the monitor and resolder components around the red or yellow inverter transformers.
Samir
Mar 04, 2008 | HP Pavilion F1503 15" LCD Flat Panel...
HP Pavilion F1503 15" LCD Flat Panel Monitor Logo
438 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
