Question about Teac DV-3500 DVD Player
Now display hi imtrying to fix my dvd player evry thing is working but theres now display
    Habit-Forming:
  • 166 Answers
Display problems are usually due to low supply to display caused by capacitor on PSU nominal value 330uF 10v but you will need a technician to sort it for you.
Posted on Jun 02, 2008
Hi there, I don't want to buy another dvd player, I would like to know how do I change the codes on a Panasonic-S54dvd player so that it can play all Regions?
This may or may not work i found it on a form and if it does not everthing other than this is a nightmare to get to work or you have to buy things
1. Remove any DVD discs from the tray/unit.
2. Switch off the DVD player and unplug the power cord.
3. Wait 30 seconds, then reconnect the power cord.
4. Turn on the DVD player with the supplied Samsung remote and wait for player to finish loading and display 'no disc' or the Samsung logo before you do anything else.
5. Press Enter on remote. (There will be no on-screen response to you doing this.)
6. Press the following numbers in sequency using the supplied Samsung remote unit's keypad -
8, 4, 2, 6, 9 (omit the commas shown here)
(Again, there will be no on-screen response to this action.)
7. Press Enter on the remote. The DVD Player will automatically shut off.
8. Now, turn the DVD player on.
9. When it is on and showing the "no disc" or Samsung logo, turn it off again.
10. Repeat this action by turning the DVD player on, then off again.
11. The DVD Player should now be Region-free.
Feb 28, 2011 | Panasonic DVD-S54 DVD Player
Panasonic Dmr es35v VCR/dvd recorder 'Set 1' problem
My remote is not working. When I press a button, I get the following message on my unit: U12, U30, SET #, CHK REMOTE #, or RC #. What can I do to fix this? The message displayed means that the remote control and unit are not communicating and the remote needs to be programmed. To program the remote, press and hold the same number that is displaying on the unit and the [ENTER] or [OK] button for more than 2 seconds. For example, if the unit displays “SET 2”, press and hold [2] and [ENTER] or [OK] for more than 2 seconds.
Feb 10, 2009 | Panasonic DMRES15 DVD Recorder
Recording from Tuner
I would suggest using the programme guide on the tuner and setting the record up from there rather than trying to set up the whole thing from timer mode.
Mar 18, 2008 | Wharfedale DVD-M3 DVD Player
Kenwood kvt 715dvd
I have seen problems in the hideaway (brain) where 8v reg circuit fails causing higher voltage(12v to 14v) to be on that 8v line. First component to fail is the Tuner followed by electronic volume ic. I have probably seen 6-8 failures where tuner fails. Fix is to replace tuner and replace open chip resistor in Hideaway box to restore 8v regulator to proper voltage. kstahl65@att.net
Feb 24, 2008 | Kenwood KVT-715DVD Car DVD Player
Samsung DVDR 120 SYS ERROR
You have an early unit and need to install the firmware upgrade. Download it from Samsung and burn to a CD. Insert the CD in the DVD player and the upgrade will be performed.
Dec 02, 2007 | Samsung DVDR120 DVD Recorder
Pink display
It seems the DV-S5950 has an incompatability with HDMI through Samsung TV's.
I work for an electronics store in Australia, and had same problem when running this DVD player on my Samsung KA40A650.
I tried it on my brothers LA40M51 and the same thing happened. Tried it at work on the A650 display model and same thing again. Then I tried it on the LG LCD that was next to it, and no problems. Also tried the DV-S5950 display model at work and it did the same thing.
It's not a general Yamaha issue, as we bought a new (higher model) Yamaha DVD player and it worked perfectly fine. I also tested the cables, and it wasn't them either.
It seems that that specific model of DVD player from yamaha just doesn't like the HDMI inputs on Samsung TVs...
Nov 26, 2007 | Yamaha DV-S5950 DVD Player
No clock display
plug out the DVD/VCR and let it stand for about 2days and see what it does.if that does not work,then call a tech to look at it.good luck.
Jun 04, 2007 | Zenith XBV342 DVD Player/VCR
Teac DV-3500 DVD Player Logo
Top Teac Televison & Video Experts
bengsoon Neo
JOHN TOPLISS
Are you a Teac Televison and Video Expert? Answer questions, earn points and help others
