Question about Stoves 720EF Electric Double Oven
Hello, i have a stoves q720 grf do double oven and the problem is with the lower oven, after about 20 minutes the oven switches itself off and the lights on the front of the oven flash on and off. van anybody help please? would it be the pcb or not? regards, Graham
I have the same problem. After anywhere from 5 to 30 minutes the oven(s) switch off and the light and clock start flashing - I have to switch the cooker on and off to start using the oven again.
Any resolution please?
Posted on May 30, 2011
STOVE Q 720 GRF DO continuously on OR does not maintain the right temperature and goes off. Could it be the thermistor? Problem in both ovens
If it has a digital display, then it is computer controlled... which means you need a new controller board.
Dec 31, 2014 | Ovens Ovens
Stoves 720EF oven switches off after 20 minutes
CHECK THAT THE OVEN TIMER IS OFF AND NOT OPERATING EVERYTIME YOU TURN THE OVEN ON IT AUTOMATICALLY SWITHES THE OVEN OFF AFTER 20 MINUTES
Oct 16, 2014 | Ovens
Stoves Q720 GRF DO main oven ignitor clicks / sparks continuously
Might be the PC board, or it might just be the switch behind the oven knob - try disconnecting the wire leading to that switch and see if the clicking stops. If it does, the switch is bad. If not, suspect the electronics.
Aug 23, 2014 | Ovens
I have a Stoves double oven and after a power cut the clock has stopped working and the main oven is not working either. the clock is completely off. the small top oven is still working though. what can...
The clock controls the ovens. In other words, directly you set any time on the clock, a contact operates within it to provide power to the ovens. (Normally the grill remains operational). You may need a new clock/timer. Before you do so, try switching the power off at the main isolating switch and leaving it off for a few mins, then switching it back on, to try to get the clock to operate. You may need to do this a few times.
Normally Stoves stick a label identifying the model on the left hand edge of the lower oven. You see this when you lower the main oven door. it will probably start with a 05 and be 9 digits long. With this number you can identify the oven and obtain parts.
Nov 07, 2010 | Stoves 720EF Electric Double Oven
My stoves 720ef oven keeps cutting out after 20 minutes and will not turn back on, the grill continues to work ok. I know the timer is set to manual so I guess it must be a thermal trip. As I do not have a...
There are seperate thermal (overheat) cutout devices for both the top and bottom ovens. First check to see if the lower oven fan is running ok and is not restricted by grease or fat (there are 4 self tapping screws that hold the fan cover on) and the thermostat is switching off and on as it should. You should also check that the main background cooling fan is running and switches off a few mins after the ovens have turned off. If these check out ok, then it is possibly the lower oven thermal cutout.
Aug 04, 2010 | Stoves 720EF Electric Double Oven
Bake element
It may have also Blown the Fuse, to the element, in the stove itself.
Feb 12, 2010 | Dacor ECD230 Epicure Electric Double Oven
Oven turns off if too hot
There is a temperature switch that shuts the power down if the temperature goes too high. This is to prevent a fire if your thermostat sticks on. Sometimes the switch will become weak and open the circuit at too low of a temperature. Replacing the switch should solve your problem.
If you need more assistance, post a comment with the model and s/n of your stove.
Thanks,
Tim
Jun 28, 2009 | Ovens
STOVES 600 oven door wont shut properly
open the door about 30 degrees, lift straight up to release the hinges, this will allow you to remove the door.
you will be able to assess the hinges from there.
most likely the hinges are just out of alignment
May 26, 2009 | Ovens
How does the q900 works
I do not know either but I would be tempted to turn off the gas, but keep the electric to the oven, and use a plastic Knitting needle to find out. It should show on a display somewhere.
Feb 11, 2009 | Stoves Premier 720GRa Gas Double Oven
Stoves 720EF Electric Double Oven Logo
739 people viewed this question
Top Stoves Ovens Experts
ashburton
Dan Webster
Dan Webster
Are you a Stoves Oven Expert? Answer questions, earn points and help others
