Question about Hotpoint HTS16HBR Top Freezer Refrigerator
Hi the freezer trianle keeps on flashing and made everything defrost
  • 31 Answers
Hi- could be many things, but first check if the coils are clean. they need to be able to breath and dissipate heat. Does it run constantly? Was the door open. check for obstructions and close it. Allow time for it to reset.
Is the refrigerator cool and functioning correctly? If not, it may be the compressor.
Check to see if the evaporator coil is clogged with ice. It looks like a small car radiator, with aluminum fins. If the defrost is not working, it will be clogged with ice. Transfer food to a cooler and examine it. Can't get to it, try an old fashion defrosting, and see if it works. If it does, you may need a new control board.
Hard to say without seeing it.
Good luck
Spencer
Posted on Oct 07, 2010
H 1 Flashing
This is actually stating "HI", as in either the refrigerator or freezer, temperatures are Hi and not at a safe level. First, press any button to stop the alarm and clear the HI temperature. If you are still receiving the alarm, I suggest checking the freezer, to make sure that everything is still frozen, and nothing is defrosting as, well as checking the refrigerator temperatures. If things are defrosting or the temperature is Hi in your refrigerator, I suggest resetting your appliance, by either unplugging it or shutting the power off at your homes circuit breaker, for 3-5 minutes. When power is restored, Give your freezer 24 hours to stabilize at the default temperatures of 0 degrees for the freezer and 37 degrees for the refrigerator.
Mar 24, 2015 | Frigidaire Refrigerators
What does it mean when the freezer flashes h 1
Good Afternoon Friend,
I understand that your Frigidaire freezer is flashing an "H1" code. This is actually stating "HI", as in the freezers temperatures are Hi and not at a safe level. I suggest checking the freezer, to make sure that everything is still frozen, and nothing is defrosting. If things are defrosting, I suggest resetting your freezer, by either unplugging it or shutting the power off at your homes circuit breaker, for 3-5 minutes. Give your freezer 24 hours to stabilize at the default temperatures. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your freezer status has changed successfully. Please leave me the model number of your freezer, if you do need more troubleshooting, this way I am able to better assist you. Hope this is helpful.
-Best Regards-
WP
May 15, 2014 | Frigidaire Refrigerators
Myfreezer keeps freezing up and everything defrosts, and now my fridge is not cold also model no LG GRB227STS
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jul 28, 2011 | Refrigerators
How do you activate the flash defrost function on a Kenmore 16082 model? I can't find any flash defrost button.
Hi
Not all these models were fitted with a flash defrost plunger, if fitted it is inside the lid on the left hand side.
You will need to remove all the product from the freezer and store it elsewhere.
1. Pull out the flash defrost button
2. Put a chock of wood or similar to prevent the lid from closing (if the lid closes it will stop the flash defrost)
3. Wait until all the ice has melted then clean out the casing, some of these models have a drain plug in the base, (put a shallow tray under the outlet to catch the water) others you will need to mop out the water.
4. Push in the flash defrost button and wait for a couple of hours and then you can reload the freezer.
If there is no flash defrost button then follow the above instructions after you have emptied the freezer, all you need to do is switch off and unplug the freezer then go to 2. above. When finished plug back in and reload.
Regards
Gordon
May 05, 2011 | Kenmore Chest Freezer 16082
I keep finding a lot of water at the base of the refrigerator under the storage trays. Where is the water coming from? how to stop it?
hi defrost water. drain stopped up take everything out of freezer take bottom up in freezer get heat gun or hair dryer out and start defrosting once you get the ice gone blow out drain hope this helps jim
Oct 08, 2010 | Kenmore 64802 Top Freezer Refrigerator
I have a hotpoint freezer which is self defrosting but its icing up and warning message keeps flashing up
There is defrost timer, that will shut off the freezer and turn on a heating element that quickly defrosts the cooling fins. then it cycles back on. If any part of that system goes out the freezer will not defrost.
Sep 21, 2010 | Hotpoint 6.92 cu. ft. / 196 liter Upright...
Defroster get red hot
Kenmore Frostless Upright freezer model# 23971. The alarm sounded, all contents in freezer is frozen solid. We turned the alarm off, but the red light continues to blink. How do you reset the alarm and stop the red light from flashing? It has been 3 days now and every time we have check to see if the contents has started to defrost, there is no signs of defrosting, everything inside of the freezer remains frozen solid.
Sep 01, 2010 | Kenmore Freezer 20.6 cu. ft. Manual...
I have to keep the temperature turned up to 9 in order to keep the food at 45 degrees. The fridge is only 3 years old.
If it's the freezer control you keep at 9, it's probably a defrost problem. If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If it's the fridge temp control you're talking about The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Aug 15, 2009 | Refrigerators
Ge side by side refer, no model number available at this time
a flashing DE usually indicates a defrost problem on any unit, they don't flash indicating they are in defrost, soner or latter the problem will show. You could have an intermittant bi-metal or most likely it being a ge - a bad defrost heater. and there is always the possibility that it could be the board. It would have to be trouble shot properly
Aug 04, 2008 | GE GSH25JSTSS Stainless Steel Side by Side...
Whirlpool side by side fridge freezer alarm keeps bleeping and freezer has defrosted
whirlpool side by side fridge freezer alarm keeps bleeping and freezer has defrosted. the temp display on freezer shows - - flashing
May 16, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Hotpoint HTS16HBR Top Freezer Refrigerator Logo
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
