Question about RCA HD61LPW42 61" Rear Projection HDTV
Turning tv on it keeps going on and off picture weak then comes on and works fine
  • RCA Master
  • 17,130 Answers
This is a true case of a circuit that develops voltage to trigger the circuit but stabilises after some time when the voltage develops to the threshold that is necessary for the circuit.
Please have these tips and look into the power and main sections of the circuit to find the faulty section
http://www.fixya.com/support/r6055091-slow_start_up_circuit_cold_starting
Posted on Oct 07, 2010
Keep losing signal
You have a weak signal. There are many possible reasons for this, such as:
The aerial has moved or there is a poor connection.
You are tuned to the wrong transmitter.
Aug 05, 2014 | Humax Televison & Video
Philips Magnavox 27MS343S 27" TV picture stretched or zoomed !
Take of the back and there is buttons inside, try turning them.
Nov 25, 2013 | Philips Magnavox 27MS343S 27" TV
THE TV PICTURE KEEPS GOING BLANK THEN COMES BACK ON ALL BY ITSELF. THERE IS A GREEN LIGHT FLASHING, NO RED LIGHT.
This is symptom of weak lamp in TV.
How old is this TV and did you replaced lamp recently?
If not, replace lamp in TV to fix this issue.
Lamp light does not lit solid if lamp is not broken or dead.
Lamp replacement procedure is easy and would written in user manual.
Thanks.
Jan 26, 2010 | Sony KDF-E50A10 50 in. LCD HDTV
The screen shows ''Weak Signal'' and no picture, even though audio is coming through from both the Cable DVR box and Blue-Ray player. The cable box connects to the TV with an HMI cable - all five TV inputs...
Mine did the same thing once. I think all I did was hit the setup on the remote, and let it run back through all the channels and then it worked just fine.
I hope this works for you.
Dec 29, 2008 | JVC LT42P789 42 in. LCD TV
We keep losing sound and picture on our TV
If you haven't replaced the lamp, it is almost certainly time to change it. A weak lamp will cause the TV to play for a short time. As the old weak lamp heats up, it draws more current, and the reflector in the lamp, having become cloudy over time, converts the light into more heat rather than reflected it out into the set. Eventually the lamp draws too much current and the set turns it off, going into a restart cycle. Buy an original Sony lamp, as the aftermarket replacement lamps are known trouble makers. Be sure to rate this solution. Thanks!
Nov 13, 2008 | Sony Grand WEGA KF60XBR800 60" Rear...
Won't keep digital signal
If you're connected to a digital cable box, I would try using the external component connections and bypass the TV's tuner. If all you have is straight cable coming into the house, it could be the cable signal itself or a defective tuner in the TV assuming all the menu settings are correct in the TV.
Jul 25, 2008 | Toshiba MW20H63 TV
Projection TV turns off for a few seconds
Good Day, boattech1;
To my understanding the Model 53UDX10B is a rear projection, that uses no fans. I think maybe your LAMP may be getting weak.
Good Luck, big IRISH.
Jul 20, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Sony KV-35S66 Audio ok but no Video
Is your picture somewhat weak ? This could be a problem with the picture tube . One thing you can try is to turn the screen control up just alittle at a time to see if the picture comes in . Once it does turn off and back on to see it it comes back on again . It might take 10 to 20 seconds but if it does your picture tube is weak . The control is on the flyback transformer it is the bottom control . Or it may be on the crt board on the picture tube . One thing to check once the picture comes is the video input . If you go to this mode and see faint white lines might want to try to turn the control down a little more to see if you can get them out and the picture stays on , if not thats how going to have to watch it . These picture tubes are expensive $500.00 to 700.00 depending on which one you have . One possible other thing if you tell me the picture was a great picture almost like brand new check the horizontal section for a loose connection as this will cause this problem . Don't get shocked and be carefull , Good luck
Mar 14, 2008 | Sony KV-35S26 35" TV
No sound on my 8year old panasonic tv.
It worked fine yesterday. Sound on all channels. Sometimes the picture goes black on channel 6. We can get it back by going up one channel, then back to 6. it is due to cable signal ie weak. now there is no sound this is due to sound section 1 loose connect in sound section 2 speaker 3 problem in sound section some part must have failed.
Sep 17, 2007 | Panasonic CT-32SX12 32" TV
Sony tv picture keeps flashing
You likely have bad solder connections around the tuner area. This model has a history of problems in that area or the tuner itself.
Aug 29, 2006 | Sony KV-32S35 32" TV
RCA HD61LPW42 61" Rear Projection HDTV Logo
46 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
