I have a mini laptop with windows 7 and it won't shut down or restart, i keep trying but it doesn't respond. how do i fix this?
    Genius:
  • 1,098 Answers
You may need to force shutdown your laptop. try pressing the power button for a longer time until the power led is off. then try pressing the power button again.
Posted on Oct 07, 2010
Why my windows explorer does not respond
Try this:
Reboot the computer. As soon as the "Starting Windows" screen comes up, hold down the Power Button until the computer shuts down. Now, restart the computer, and a Windows Tools screen should pop up. Choose Startup Repair (recommended). Be patient and follow the directions. Good luck.
Jun 07, 2016 | Microsoft Windows 7 Ultimate for PC
HP LaserJet 4100 for all applications in windows 7. When I go to print a document and click on print. The print screen exits, the print job doesn't processes, and the print queue stays empty. Noth
Ideas? Yes. I had this happen on an LJ 1000 while trying to print my tax return. I tried emptying the queue, removing power from the printer, etc, etc. What finally worked was to empty the queue (again), disconnect power from the printer, shut down the computer, plug in the printer again, restart the computer, queue up a print job again, and hit PRINT.
Hope this works for you
Apr 11, 2013 | HP LaserJet 4100 Printer
I have a msi a6000 laptop and it keeps shutting off itself and wont boot windows when windows stars booting it shuts off and i clean the fan so thats not it can someone tell me what it's hapening
try replacing the thermal grease on your cpu.
the BIOS have a protection that restart or shut down the computer/laptop when the cpu get to hot.
You can also check if the power suply is working in parameters
Dec 06, 2012 | MSI A6000-226US Core 2 Duo T6600 2.2GHz...
Can't restart windows 7 on my dell d610, did a format on the hd, re-loaded the windows 7 disc, everything runs great until I shut it down then it won't restart
Recently a put windows 7 on my latitude d610 only problems I had were incompat. Drivers (wifi, sound, graphics.) all were fixed with googling those drivers with windows 7 because this hardware is not compatible with 7 but seeing as it is a restart thing,
Check the drivers u have installed try to see if any need updating or are no compat.
Nov 19, 2012 | Dell Latitude D610 Notebook
System Reference
it might be the resolution or the frequency
check your monitor compatible frequency and resolution,try 60 Hz and 1024x768 resolution
just comment this solution if it doesn't work and give me more details
Aug 23, 2012 | Apple Computers & Internet
Hp pavillion dv9815 won't start. it just reboots over and over. shutting down each time.
take out the battery, then take out the memory. Put one of the two memory modules back in, and turn it on. If everything looks ok, shut down and put the other one back and try again...if everything is ok...then ok. If it doesn't work after the first one, let me know...
Jun 11, 2012 | HP Computers & Internet
Hi, My Samsung R580 I3 JBB2-US keeps on shutting down. If I close the lid when I re-open it shuts down & I have to restart or it freezes and I have to force restart. Sometimes when I boot up it...
You can try go to Start - Control Panel - Power Options and check what you want computer do when you close the lid of your laptop. Fix that and restart laptop to apply the setting.
If the boot up not complete and restart by itself, in my opinon, there is something wrong on the start up process, could be hardware malfuctions, could be a software not compatible. Try check the start up process to see.(use Start- Run: msconfig)
If this happen often, you should call the Samsung customer services to find out. Laptop i3 should still under warranty.
Hope this will help.
Thanks for reading
Jul 20, 2011 | Samsung R580 Notebook
My HP Mini 110 touchpad mouse is frozen. Pls help
Hello
If the touchpad does not responds then make sure that the touchpad lock switch (just above the touchpad) is not turned off.
If this doesn't work,Restart the computer and repeatedly tap the F8 key (you need to press F8 before windows starts to load) You should see a menu "Select Last Known Good Configuration" and press Enter.This should solve the problem if not,try to download the synaptics drivers for any of the Mini 1000 series laptop edition as you have a Mini 110. It does works.
Apr 12, 2011 | HP Computers & Internet
How may I fix my cursor not responding problem ? when I try to type on my office word 2007 ,the curso gets stock and I have to shut down my laptop and restart it to restore it .
Hi
if you go to
start
over to and right click on my computer andgo down to properties
then go over to the left to device manager
then scroll down to mouse/pointing devices
un install the touchpad
then restart the laptop
and hopefully windows will re install it correctly
also if neccessary pressing FN+F7 to make sure that the touchpad is enabled
good luck
if still no luck go to
www.hp.com
go to support/downloads search your make model and windows 7
then scroll down for the touchpad driver
download it
install it
then restrart and once again if necc press the FN+F7 to enable the touchpad
Mar 21, 2011 | HEWLETT-PACKARD HP Pavilion DV6-3013CL...
How to reset windows 7 password on HP Mini 210
You can restore the computer to factory settings. Note: This process would delete all of the data ( like picture, documents) and software from the computer.
1.Shut down the computer. 2. As soon as you restart the computer, start tapping F11 and follow the on screen instructions.
Apr 17, 2010 | HP Mini 1000 Netbook
Computers & Internet Logo
David Payne
David Payne
