Question about Akai CF2791 27" TV
My Akai TV not powering up(CTVCT29FS)
My TV is not powering up. I checked the power supply, its fine. Can you pls suggest a solution. Is there a fuse inside which could blow off??
  • Anonymous May 31, 2008
    MODEL# PT 4298HD X/SMS SERIAL # 39ZW65154R
    DATE OF MFG, JUNE 2003 . I have a 42 inch projection akai tv , that wont power up and come on.
    theres a timer button that flashs next to the power button..and thats all that happens,, when i ry to tuen on the tv...I live near san francisco and need to know who repairs them here in the san francisco bay area.
    anyone with information to assit me. Please call captain lewis at 415=424=1897, or email me at captainb333@yahoo.com
    Thank You ,for any assistance and information you may send
    and have a good day
    Model # pt4298hd Date Mfg june 2003 serial #39zw651594R
    I have an aki TV that wont power up,,,theres a flashing timer light next to the power buton that comes on...but that it when i try to power upand turn TV on...
    i live near san francisco and needs to know who works on this brand of tv
    PLease call me at 415-424-1897 ,,or email captainb333@yahoo/com if you have any information that may help me,,,Thank you and have a good day
    Best Regards Captain Bruce Lewis
If the standby indicator flickers,there may proberbly be a faulty carbon resistor in the power supply board.
Posted on Jun 05, 2008
Check main cord then fuse if fuse is blow then check diodes, power supply trnsistor also resistence.
Posted on May 30, 2008
    President:
  • 3,130 Answers
Most likely your convergence board is bad. If you have any electronic repair experience, you should be able to locate the convergence driver board. There will be two large black IC's mounted to a metal plate and they will start with the letters STK. Disconnect this board and if the set starts up, it is bad. There should be a number on the board. This will be a Samsung Number. Go to Samsungparts.com and enter the part number into the right box and see if it is still available. If it is not, you could always go to ptscorp.com, get their telephone number and call them about rebuilding your board. Good Luck!
My Akai Tv won't turn on at all
hello do you mean no power, if so have you checked the fuse in the plug if ok then it's possible that the glass fuse inside the tv may have blown this will be in the power supply
regards
shaun
Oct 08, 2010 | Akai PT46DL10 46" HDTV-Ready Television
Akai lct2721ad The TV was working fine when we turned it off and now it won't come back on. No red lite. The tv has had very little use. Is there a master power switch that might be tripped. thank...
Check the power source?Yes.Try tv unplug,replug it back an hour later.The tv now resetting it back to factory setting.The tv should work now.Not,than the power supply board is dead.That the board,where the power a/c cord plug into.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacemrnt.
Sep 08, 2010 | Akai LCT2721AD 27 in. LCD Television
Akai TV remote is not working correctly
I don't think the Akai remote is designed to work with cable or satellite service. I have to use both remotes & I have Direct TV.
Try unplugging the TV for a few minutes then plug it in and try the remote again. I had the same problem shortly before my Akai LCT2721AD quit working altogether. Three 1000uF capacitors blew in the power supply. Bought 3 new ones and replaced the blown ones myself rather than pay over $100 for a new power supply. Works fine now.
Oct 23, 2009 | Akai LCT2721AD 27 in. LCD Television
Power surge, TV will not turn on
Power surges are extremely unpredictable, they can damage everything inside the tv, from the power supply printed circuit board, to the main printed circuit board. Normally the power supply takes alot of the damage from these things, so check over the power supply for any damaged components, any burnt out parts on printed circuit board, and also check the fuse. Good luck.
Aug 28, 2009 | AOpen Televison & Video
The power supply on my Akai LCT2662 (Flat screen TV) has gone bad
I went to Radio Shack and purchased a replacement power cord 18-gauge, 10 amp, 1250 watts for 9.00 bucks and it works fine.
Aug 19, 2009 | Akai LCT2662 Television
No power
If you have an external power supply check it with a voltmeter
Is the red stand by light on?
yes, but no pictures ,no sounds you will need to be a good techies to fix it.
No , open the back and check the fuse close to the connector from the power supply cable.
cheeers
May 15, 2009 | Akai CFT2490 24" TV
LCD TV does not power up with on off switch.
Hi
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}You have power supply problem. Please go to ebayand buy cheaper price:
AKAI LCT3201AD POWER SUUPLY MLT169A REFURBISHED CHAINA
Thanks
GEORGE
Jan 31, 2009 | Akai LCT3201TD 32 in. LCD Television
Akai TV with Megmeet power supply
Hi artoo
if you want you can fix the power supply. i know service tech who fixed my tv power supply. His email is jah2mil@hotmail.com.
Apr 10, 2008 | Akai LCT3201AD 32 in. LCD Television
Akai
There are reports that the power supply has dry o leaky capacitors. If you open the TV you will see the power supply # MLT169A.
I have fixed a few of this power supplies.
Apr 09, 2008 | Akai LCT3785TA 37 in. LCD HDTV
Akai CF2791 27" TV Logo
141 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
