Question about RCA 25413RE3 Corded Phone
Need to register phone with the h5400re3-a. looking to sync with base unit.
SOURCE: Uniden DCT648 register phone problem
I have contacted Uniden about solving this problem. They suggested I clear the eeprom on the handsets and reset the base. To clear the eeprom detach all of the batteries and reattach while holding the star and pound. You'll hear a beep. Press select and the unit will clear the eeprom. Now hit end and the unit will say "Welcome...something or other". Next unplug the base unit reattach while holding delete. Next hit delete twice...the base is reset. Apparently this is the last possible solution to marrying the handsets and base. This didn't work for me and the units have been declared dead. Good luck in solving your electronic problems.
Posted on May 14, 2007
voodoomox
  • 1689 Answers
SOURCE: 43-139 5.8 Ghz Corless phone
you may need to RESET the handset before getting them registered to the base station. this will ask for a reset code, just consult the user manual to get it.
if you have other issues just let me know
Posted on Aug 18, 2008
  • 4 Answers
SOURCE: RCA 900 MHz Accessory Handset- H5400RE3 for 4-line systems 25413RE3, 25414RE3 & 25415RE3
Donna75603,
Go near the base of the corded phone to register your cordless phone. Press "menu" on your cordless phone and press arrow key till you see "Registration". Press "Select" key. The sreen will show "Yes" and "No" sign. Press arrow key once to select "Yes" then press "Select" key. The sreeen will show "Registerring.." , at this time press "Page" key on the corded or base phone and hold it for a few seconds until you hear a beeping sound. This is the sign the the phones are syncronized. You can now use your cordless phone.
Jun
Brooklyn
Posted on Jan 25, 2010
  • 5 Answers
SOURCE: Phones won't Register!!
It is possible that you have maxed all of the headsets that can connect to the base. Yes, the base can support 10 headsets, but there is a small chance that in some way you registered more to the base or you purchased a base that had phone registered to it that are not in your possession. Either way, if the base is maxed out, you will not be able to register any additional headsets to it. The only option is to do a factory reset of the base unit if this happens to be the case. This is done as follows according to Uniden Tech Support:
1. Disconnect the power from the base
2. hold down the following three (3) keys: [dnd] + [middle soft key] + [*]
3. While holding down the keys, plug in the base (hold the keys down until you hear a long beep). This is supposedly all it takes to reset the phone.
The way to determine the number of hand sets tied to the phone is to press the intercom key on the base and scroll through the list of phones. if you see more than the number you anticipate still being tied to the base, you will have to utilize the above procedure.
Posted on Mar 09, 2010
  • 10 Answers
SOURCE: my motorola d10 phones will not register to the
Hi, I may be late at posting a reply but I had the same problem and I'm an IT Practitioner - So Motorola don't seem to like making things easy or even giving instructions - I tired out Google and eventually came across the result myself:
1. Go To Advance Settings
2. Then Go To Registration
3. Then Go To Search Base
4. And Keep Hold Of The Page Button On The Main Unit
( You May Have To Do This Several Times)
5. The Screen A Should Display PIN
6. Enter The PIN Which Is 0000 (Unless Changed)
7. REGISTRATION COMPLETE!!!!
Also I had problems with the intercom feature - when I attempted to intercom another handset - It wouldn't ring but this was fixed by turning the room monitor (Baby Monitor) off.
Best Wishes PINDY92
Posted on Oct 07, 2010
How do I reset the base of an att E5914b phone?
flip it over and look for tabs holding it in positing move the tabs and reposition it and then lock the tabs.
Jan 18, 2015 | Lands Phones
Had service interrupted yesterday and had it restored today but i cant get my phone to work
Can you please provide us the model number of this unit so we can help you better....
Oct 31, 2008 | Panasonic Lands Phones
How do i sync my panasonic phones cordless kx-tga810
335 is the magic code when you want to remove a previous handset or base station registration!
Handset:
1 " (middle soft key) i L i #
2 Enter "335".
3 "Cancel Handset" i #
LThe numbers of all handsets
registered to the base unit are
displayed.
4 Select the handset(s) you want to
cancel, by pressing the desired handset
number. i #
5 "Yes" i # i {ih}
Base Station:
A handset can be registered to a maximum
of 4 base units. A handset can cancel a base
unit that it is registered to. This allows the
handset to "forget" the base unit.
1 " (middle soft key) i N i #
2 "Registration" i #
3 Enter "335".
4 "Cancel Base" i #
5 Select the base unit(s) you want to
cancel, by pressing the desired base unit
number. i #
6 "Yes" i # i {ih}
Dec 23, 2013 | Panasonic KX TGA810 1Line Cordless...
Have a DS6222-4 - bought 2 handsets to replace 2 that have the names of the buttons worn off. Charged the new handsets overnight - screen says "Connecting..." even though they are right next to the base....
If they (hand-sets) have already been synced to a base...
The preferred way is to UN-sync from their OLD BASE.
The manufacturers are SMART ENOUGH to realize
the bases & remotes may not ALWAYS remain associated.
You must first UN-REGISTER any association with their
PREVIOUS EXISTANCE... before you can register these on your base...
Likewise... you WILL BE A LOT HAPPIER if you
UN-REGISTER the REMOTES you are planning
to retire
The numbers are quoting are wireless (remotes).
DS6222-4 Wireless handset Manual:
Results 1 8 of 8
You should also look at the instructions for
your (wired) BASE.
There are at least two ways for EVERY TASK...
(you only need one (your choice)).
Carnac the Magnificent
Jul 01, 2017 | Vtech Lands Phones
Sync
If by "sync a handset" you mean register a handset so it works with the base, then yes. It doesn't even need to be the same model. The manual gives instructions for registering a handset to work with the base. If you need a manual, select the model of your Uniden DECT 6.0 phone from the list beginning at http://www.uniden.com/owners-manuals/dect-phones/scat/dectphones_mnl .
Jun 03, 2013 | Uniden DECT 6.0 Cordless Telephone...
How to register a panasonic a kx-tga850e
Look on the base unit, not the charging cradle. The charging cradle merely plugs into a wall outlet for power. The base unit is the device that's hooked up to the phone line.
Aug 24, 2012 | Panasonic Lands Phones
I have a siemens 4000 handset and I like to register it to a ssiemens 4215 base. Is that posible? Please help.
Yes. All DECT compatible handsets will register to a DECT compatible base unit.
If you have the manual for either phone, just follow the instructions.
If you dont, some manufacturers do have some odd quirks to the registration process, but most follow the following.
Look on the bottom of the base unit - there should be a 4 digit number somewhere. There will probably be lots of other longer numbers and bar codes also, but these are unrelated.
The base unit needs to be put in to registartion mode - usually done by either switching it off, waiting about 30 seconds, and then switching it on. Or, press and hold the base unit's page / find handset key. NB. the base unit stays in registartioon mode for about a minute, so if you dont complete the handset steps before this time, you have to start again.
Somewhere in the handsets menu will be a register handset option. On selecting this it will then ask for the 4 digit number above. Enter this, and after a short wait, the handset will be registered. Remember, this has to be done before the base unit times out.
Also note; base units can only register 4 or 5 handsets (depends on manufacturer), so if you've already got this number, you'll have to de-register one of the others first.
Sep 29, 2009 | Siemens Gigaset 4000 Phone
Sync a new handset to kx-tg5632 phone
This works on MY panasonic; May work on yours too!
Registering a handset
The included handset and base unit are
preregistered. If for some reason the
handset is not registered to the base
unit, register the handset.
1 Handset:
{MENU} i {0}{0}{1}
2 Base unit:
Press and hold {LOCATOR/
INTERCOM} until the IN USE
indicator flashes.
LAfter the IN USE indicator starts
flashing, the rest of the procedure
must be completed within 1
minute.
3 Handset:
Press {OK}, then wait until a beep
sounds.
4 {OFF}
Registering an additional handset
See page 5 for information on the
available model.
Start from step 2.
Dec 29, 2008 | Panasonic KX-TG5632 Phone
Donna75603,
Jun
Brooklyn
May 14, 2008 | RCA Lands Phones
RCA 25413RE3 Corded Phone Logo
199 people viewed this question
Top RCA Lands Phones Experts
Are you a RCA Lands Phone Expert? Answer questions, earn points and help others
