Panasonic PT-50LC13 50" Rear Projection HDTV Logo
Posted on Oct 07, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Shuts off without warning what the cause - Panasonic PT-50LC13 50" Rear Projection HDTV
BONES420
Level 2:
  • Expert 171 Answers
  • Posted on Oct 07, 2010
BONES420
Expert
Level 2:
Answers
171
Questions
Helped
57064
Points
537
Did you all ready replace the lamp,this might be a lamo burning out this lamps are made to last 6000-8000 life hours so that could be the issue
you might also want to reset the lamp timer if you just replaced the lamp
http://www.fixyourdlp.com/wp-content/uploads/2007/09/panasonic-tyla1000-lamp-instructions.pdf
If you have done the above and still have the same issue then most likely you have a BALLAST BOARD issue
PLEASE RATE THIS SOLUTION AS I DO THIS FOR FREE !!!
2answers
Security light issues. How to bypass it or shut it off altogether.
The warning light will keep coming on until you deal with the cause. So you either fix the problem or have the warning continue to display and potentially have another problem develop which will stop you starting the car.
2007 Dodge Dakota, engine shuts off while driving without warning, no fault codes
When does it shut off, what driving conditions, hot engine or in between or cold engine.
2helpful
Why does my computer keep shutting down?
Is Windows crashing or is it just shutting down without warning? If it is without warning, then I would suspect a failing power supply. May want to look at getting a replacement power supply.
2answers
I have an acer 5520 laptop,it has started shutting of without any warning even though plugged in and fully charged
Causes:
1. Overheat
Most cases this is caused by a over heat where the system fan gets blocked or there is not enought air flow, this can damage the system cpu.
Other known causes
AC/ adapter needs to be replaced some case were found that the ac adapter would be the cause as well it would be something to have checked out.
Now if the system shuts off without the ac adapter and its running on the battery as well you might want to look at the overheat issue.
thanks for using fixya please do be considerate and post you ratings and feedback for your answer today.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
2answers
The warning ding does not shut off or shuts off and comes back on
try spraying all of your door latches with w-d40. This worked on my van and it's been 2 yrs. now without another ding.
Computer keeps shutting off without warning
If the PC doesnt show the shutting down dialogue, then hardware proble if it does then its a software problem. Try to replace the powersupply, abnormal voltage sometimes causes this problem, memory and motherboard errors can cause your PC hangs up or blue screen but will not shut off.
2answers
The pc turns off without warning
Sometimes when you add a new device to your computer, you computer will have a driver conflict and just reboot or shut off. If nothing was introduced to your computer here lateley then it may want to run Windows updates.
Another thing that may cause thing like this to occur is if your CPU fan is not functioning properly. The computer will automatically shut off because of overheating. If you can, unplug everything from your computer, open it and with a can of air, blow it clean and look at all the cooling fans.
If you need further help, reach me via phone at https://www.6ya.com/expert/hugo_f827544e52871d36
Explorer shuts down without warning when uploading
Now would be a great time to switch from Internet Explorer to FireFox wutxtye0rjd9d9ekmodqt1eoxkvn9hr9qjz1l3dabggyud7sdgr36czsrfxqenadhnijx9nfayi+sz1sug0aaaaasuvork5cyii=
1helpful
DirecTV DVR Shuts Down and Re-boots Without Warning
With the DVR up and operating well I would lift up one corner about 1/2 inch and drop it to see if that causes it to malfunction. If it does, then you likely have one or more bad solder connections inside that need repair. If no change is noted, then it could possibly be defective capacitors or a voltage regulator going bad on you. There is also a possibility that it could be a worn recepticle the unit is plugged into, as a power interruption may be all it needs to reboot.
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
