Question about Nokia 3110 Cellular Phone
Hi my nokia 3110c...phone whenever...i switch the phone on...the keypad doesnt work..infact it just works a few seconds as the phone is loading..(enough time to unlock the keypad using the security code) but then the keys dont work .....only the power switch works..nothing else.... im really stuck can u plz help??
  • 358 Answers
Hi, when a keypad does not work on a phone, it is usually caused by dirt inside the keypad area of the phone,you can open the phone and clean up the keypad area.
Sometimes too, as the case may be Chips also can affect the keypad and allows the phone keypad not to function.
There is an IC chip inside that controls the function of the keypad.
You can fixed the IC chip inside the phone by replacing the damaged IC inside the phone.
When you replace the damaged IC .i assure soluton tothe problem.
Take care.
Posted on Oct 07, 2010
Testimonial: "thnks buddy..i opened the front side..and there was some water drops ..its working fine now..cheers..!!! :)"
Hanged and off
Try pulling the battery out and put it in carefully, make sure everything is lined up right. If that doesn't work, try plugging in the charger and leave it for an hour.
Apr 19, 2014 | Nokia 3110 Cellular Phone
How to download nokia 3110c keypad schematic diagram.
Nokia flash file click here select BB5 Support which is shown at the left Taskbar again select 3110c.You can download it from the second column.Good luck
Oct 09, 2011 | Nokia 3110 Cellular Phone
My phone switchd off imediately whenever i switch
may be it is bcoz the battery life is over. Try by putting Nokia battery similar to phone and check if it works then please change battery.
May 06, 2010 | Nokia 3110 Cellular Phone
Restart my 3110c nokia phone how to format my phone with install any software
my nokia 3110 is not starting upp.whenever i try to switch on the phone a light blinks 3-4 times and than again it switch off.. so what should i do
Feb 19, 2010 | Nokia 3110 Cellular Phone
I have a problem with switching my nokia 3110 classic answer pls!
The Problem with Nokia 3110c – Switching off and automatically restarting This is what happens. Nokia 3110 hangs, gets switched off and restarts randomly. More often, it restarts around 3 times or so and then gets switched off.
Possible Causes and Solutions Cause 1 – Phone Memory Full – Nokia 3110c mobile phone has got 9MB of internal memory.
Solution – Keep the free space between 350 to 500 KB, so as to keep things running smoothly on your phone and prevent Nokia 3110c from restarting.
Cause 2 – Changing Themes – Some people have reported that the phone restarts automatically when they try changing display themes on the phone.
Solution – Don’t get your phone loaded with too many themes downloaded from the internet or atleast, don’t switch themes frequently. These themes, mind you, also load up things into your already falling Nokia 3110c phone memory.
Cause 3 – Memory Cards – Some people have reported that Nokia 3110c restarts due to some issues with the memory card.
Solution – Remove the card, get it formatted and then insert it back and then restore factory settings. This just might solve the issue.
Cause 4 – Transferring data via Blueooth / USB data cable (or) Updating Music Library – A few people have reported that their Nokia 3110c mobile phone restarts when updating the music library.
Solution – Don’t try updating of music library frequently or don’t often transfer data in/out of your Nokia 3110c phone.
Cause 5 – MP3 files
Solution – This may seem dumb, but consider converting all your MP3 music files to WMA and then store them on the memory card. Some users suggested this.
Also try this:-----
It ll work . you dont need to go 4 the firmware v5.05
If ur phone restarted 3 or 4 times and switched off automatically. Try this
method
1] Remove the battery and Micro SD card
2] wait about 5 minutes
3] Then switch On the phone WITHOUT the memory card
Now ur phone working well without restarting
4] Then you must restore Factory settings frm the Settings Menu
[default security code:12345]
{i know most of people have done this thing,but remember u have 2 go
with the correct order.Unless it will not work.OK}
5] Now apply a theme. The theme's size should be below 100kb
6] Now ur phone working fine without the Micro SD
7] Then wait about 5 minutes and Switch off ur phone
8] Remove the battery and insert the Micro SD
{Don t Format the memory card}
9] Switch On ur Nokia 3110c phone.
10] Now Keep ur free Phone memory space [Not the memory card's free space]
between 470kb - 499kb.
Now surely ur 3110c working fine about 5
months.During these time u can
1] Send/receive any file via bluetooth.
2] Enjoy Music,video, GPRS,Yahoo Go .....etc
3] Also u can Update music library anytime.
but remember below DONTs
1] Don t try to change themes.{u have to stick with a theme}
2] Charge ur phone in ON mode
3] Dont fully discharge the battery
4] Start charging ur phone when there is only a bar on Battery indicator
5] Dont erase calender notes
Make sure about above 5 Donts
Dont worry if ur phone restarted once.{U know the problem is restarting several times
and automatically swiched off.}
After 4 or 5 month there is a possibility to occur the problem again.
if so Follow the above steps again.
Good luck
To be frank, This mobile has this as a generic problem. As I told, The problem can come back again.
Thank you Sir, Have a nice day.
Sep 21, 2009 | Nokia 3110 Cellular Phone
My nokia 6300 restart itself whenever i switch it on and automatically switch off after few seconds. Phone software is not working properly
maybe your phone got virus so that its not working properly
u just install anti virus software for your mobile and delete virus or reset your mobile
Jul 13, 2009 | Nokia 6300 Cellular Phone
My Nokia 5300 music xpress phone is frozen
Hi , see what u could do is , switch on the phone without the memory card .see if the phone allows to send u messages , u can send ur imp messages to a different number..if the phone still doesnt work then u will have to get it FLASHED once..olly
Nov 17, 2008 | Nokia N95 Cellular Phone
How to format nokia 3110c
Hi i m Almadani, i have Nokia 3110c,
in 3 or 4 days when i change my sim or insert a memory card,
so when i on my mobile after few seconds the cell switch off then on every time i on my cell then switched off after few seconds,
when i on with out memory card then the cell work normaly,
so waht i do for that?
can i formate it?
if i want to formate, then how i to formate?
reply me.
thankyou
Sep 05, 2008 | Nokia 3110 Cellular Phone
Nokia 3110 Cellular Phone Logo
216 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
