Question about Canon PIXMA MP830 All-In-One InkJet Printer
It keeps telling me its out of paper or something. When I check its always got paper in it and I cant get it to work at all. It used to be that when I turned it off then back on, it would work, but now it will now work at all. Thanks
    Scholar:
  • 107 Answers
Hello, this machine has 2 paper feed sections, you might want to check that both trays have paper, there is one under the machine, as well as the one in the back of the machine. on the control panel there is a switch called feed switch, you can see if you press it, the light will switch from bottom of printer to back of printer.
Posted on Oct 07, 2010
Wont print,keeps saying check paper size
You need to call service, because the flapper of registration sensor is worn out, and fax cant detect right paper size.
Jun 23, 2010 | Canon FAXPHONE L80 Laser
Misfed document error on screen
there may be a piece of paper or a sensor is stuck,
1st remove trays and open all doors
2nd locate each sensor and see if it stuck or has something blocking it
f9f8f36.jpgThe part that is up is the flag for the sensor , it tells the machine if there is a paper there, if it is late getting there, etc...
3 rd start with the trays, next to the wheels there should be two, one to tell it if the tray is full of paper and one to tell it it is coming out, you should be able to pull lightly on it and it should snap back into place (there is a spring inside that puts it back in place after the paper has passed)
4th look on the side where the paper should be going up
5th if you have a duplexer (2 sided option) look in there
ALL GREEN HANDLES ARE FOR USERS TO MOVE TO LOCATE PAPERS IN COPIERS
6th look in the exit where the paper comes out
some copiers ( possibly this one) you may have to physiccally remove it to see. ( wait until it cools off)
Good luck
Jan 22, 2009 | Toshiba e-Studio 205 Copier
Canon pixma mp150 saying paper jam but cant see one
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button.
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Dec 11, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
PAPER JAM
I have 4 hp printers. And usually a paper jam tell me I need to open the back of the printer to check is something is there. What is the substance of the paper you are using?
Oct 25, 2008 | HP Officejet 6310 All-In-One InkJet...
Canon mp145 error 3
it means that there is something still trapped inside. a piece of paper maybe or anything. are you sure you already remove the whole piece of the paper or not?
Oct 18, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Paper jams every time I try to print something
2 possible solutions.
1 The paper itself. Check that the paper tray is not overfull. this can cause multiple sheets to feed through. Also make sure that you use good quality paper suitable for the particular type of printer. Always keep the paper dry Damp (not wet) paper will also cause the sort of problem you describe. another good reason for not keeping to much paper in the paper tray. Paper will keep better in the packet than in the tray. Always store the paper in the packet in a warm dry place. I keep mine near a radiator and away from the Air con.
2. The printer driver. Download the latest driver for your printer from the manufacturer and update the printer driver, via the control panel/printers. If you don't know how to do this you can simply uninstall the printer and then install it again using the new printer driver.
Good Luck
Carrieone
Jul 08, 2008 | Lexmark X7170 All-In-One InkJet Printer
Always paper jam.
Check to see if something isn't blocking the paper path.
You could try cleaning the feed rollers as well.
Jun 12, 2008 | HP LaserJet 2420 Printer
Paper keeps jaming
I have the same exact problem -
Dec 03, 2007 | Canon PIXMA MP160 All-In-One InkJet...
My dvd cant eject
You need to provide more information.
A CD-ROM/DVD drive only needs power to eject a disc. It does not care if the drivers are installed, for that function, it only needs power.
If this is a new drive it might be a bad one. If this is a drive you have used before, it might have gone bad.
If you have a Disc stuck in the drive, you can always use a paper clip to preform a manual eject. Just unbend a paper clip, and stick it in the pin size hole on the front of the drive. Keep pushing until the drive door opens.
If this is new drive, make sure it is connected correctly.
Nov 10, 2007 | LG GCC-4522B (0048231293594) CD-RW/DVD-ROM...
Canon PIXMA MP830 All-In-One InkJet Printer Logo
106 people viewed this question
old marine
old marine
