Question about Mitsubishi WS-55313 55" Rear Projection HDTV-Ready Television
Picture is good but it keeps flashing on and off randomly. It is not the cable signal.
    Novelist:
    Champion:
  • 203 Answers
This is a nice set but there were a few problems to watch out for. When you say the picture is fine that leads me to think you have an issue with coolant leaking. If you disconnect the power from the set for thirty seconds then plug back in, the set should reboot. Green light flashes for 70 seconds then you can turn it on. If it does this, the power supplies are okay. If that doesn't clear the problem, then you need to disconnect the power and remove the speaker grill. Then take off the access cover in between the speakers. Using a powerful light look at the circuit board between the two tubes on the right hand side. Usually this is where the coolant starts to drip down from the reservoirs above. If you see any liquid or drops coming from beneath tubes please do not continue to use television. This is more than likely the cause of the problem. Many times the set can be repaired for this. Sometimes ,however, it can destroy the set. Let me know if I can be of any more assistance. Good Luck, Russmann.
Posted on Oct 07, 2010
Why do leds flash randomly on faulty mackie dfx-6 ?
Genuine and consistent random flashing is normally a cable fault if is the main VU graph but there are other symptoms as well. If is the O/l (Clip) or Solo Leds on a channel strip have you checked for earth loops etc? Does it do it all the time or only when there's a signal? Which Leds are flashing and is there anything else that is not behaving correctly? It would seem if you can get a repair shop to have a look this would be your best bet.
Jul 27, 2014 | Mackie 1604 Vlz3 16 Channel Mixer
My picture and keep on breaking up on some channel
If you have a good picture on some channels and the picture breaks up on others , it could be the input signal. What is the source of the input signal; i.e. cable, satellite, antenna???? Do you have a cable box? The problem may be with the box or with the provider's signal.
Mar 30, 2014 | Sony KDL-46S4100 46 in. LCD TV
Viera TH-50PZ83U, 20 months old, used nominally (average 15 hours a week). The screen will intermittently flash red, sometimes for a few seconds, sometimes for more than a minute. Imagine the entire...
The main Tuner signal board have problem.That the board,where the broadcasting signal cable plug into it.U have some skills,like take things aparts and put it together again?Yes,than.Try website like Ebay.com buy a refurbish Tuner signal board for the replacement.Or pay the shop for part and labors they'll to do it for u.
Oct 21, 2010 | Panasonic Viera TH-50PZ80U Plasma TV
Signal drops out, displays "No Signal"
My best guess is the signal to the Cable box. It is not a hardeware problem if you replaced the box it has to be the cable signal. Loose connections are sometimes the problem.
Nov 08, 2009 | Daewoo DP42SM 42 in. HD-Ready Plasma...
My Dell E151FP LCD monitor keeps randomly flashing OSD menu, help
The cable might be pinched or bad.Have you tried the monitor on another PC?
Good luck
Oct 17, 2009 | Dell E151FP 15" Flat Panel LCD Monitor
Turn signals stop working
Replace the flasher unit with an electronic version.
The electronic flashers keep the flashing cycle constant no matter what the load is on it.
Your standard flasher sounds like it is failing.
Sep 26, 2009 | 1993 Buick Regal
65" Mitsubishi Projection Television keeps flashing black screen
check your closed caption, long time ago there were 4 cc options. Turn it completely off, that might get rid of it.
Jul 18, 2009 | Televison & Video
Picture quality in cable mode only, watching dvd picture is
Herringbone pattern?
House stray AC 60hz signal is getting into the cable b/c the shield is not properly grounded. Call the cableguy
Mar 26, 2009 | Samsung 50 in. Plasma TV
Screen randomly flashes black
First and foremost you need to change one of two things. Either your video output settings on your xbox 360, or use an hdmi cable as opposed to component cables. Component cables are only designed to output video up to 1080i, not 1080p(big difference). So if you try to run a output signal of 1080p with cables only made to send 1080i, you will have picture issues.
Nov 23, 2008 | Sharp Aquos LC-32D40U Television
"No Signal" Keeps Flashing on the Screen
I would suspect you have a weak or intermittent source. If it is cable, you may want to have them check it for you. If you are using an antenna, you will want to get a better one or at least try a different position.
Dec 20, 2007 | RCA 14F512T 14" TV
Mitsubishi WS-55313 55" Rear Projection HDTV-Ready Television Logo
32 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
