Question about Pioneer Televison & Video
When you turn it on, the power light goes green, as it should-- then switches to red, as it does when it is off
Your PIO-TV has two power buttons, the main switch will reset your TV. It is possible that the power/defelection board can be repaired but for best results a new board (about $250-350) will be a long term solution. Good Luck.
Posted on Jun 01, 2008
  • 203 Answers
Your tv is going into "shutdown" mode for one of many possible reasons. More than likely you will need a new circuit board. The only possible way to correct it yourself is to unplug unit from it's power source and hope it resets. Allow 5 mins. before restoring power. Do-it yourselfers can get prices online using part numbers from board. This can save service center's parts markup. Hope this helps, good luck.
Posted on May 30, 2008
Wiring diagram for 220 volt light with switch
ok here goes first what do you want to do? replace switch or what, all 220 volt lights have a switch, plug has 2 hots( one red-one black), then you have a white and a green, red and black are power, white is neutral and green is ground.whit goes all the way through to light, so does the green, switch controls power so red on one side of switch and black to other side, hopes this helps
Oct 15, 2011 | Home
Replaced bulb yesterday worked fine. Today light will not turn on. projector turns on both lights green for 10 seconds, then power goes red and status blinks green for about 5 seconds, then status light...
green green is power on, normal
then it tries to light the lamp, but it can't so the protection circuit comes activated.
you get red and green blinking
Then it goes to standby, red and off.
so something has happened to the lamp, or lamp ballast power supply.
Take the lamp out and check if all is OK with the 2 terminals in the connector, and the leads to the lamp are intact.
Failing that, I would suspect the ballast lamp power unit
Mar 25, 2011 | Mitsubishi HC1600 Projector
Cooper Industries Cooper Wiring 274W Switch and Outlet I need help installing this switch/outlet combo...I have 3 wires...a black, a red, & a copper. I hooked the copper to the green terminal, the...
Switch-plug combo:
bare ground goes to green screw
dark screw goes to hot from breaker
silver screw to neutral
brass screw goes to load (light)
Add a comment any time
You are replacing single pole light switch?
Single pole switch has 3 wires: black and red and bare copper
New device has 4 different colored screws: green, dark, brass, silver
Bare copper goes to green screw.
Black wire goes to dark screw
Red wire to brass screw
Nothing on silver screw for a moment. Test circuit and make sure light turns on-off.
If lights works, then good so far.
Now let look at silver screw. Neutral wire has to connect to silver screw.
In back of your electrical box are white wires twisted together and covered with wire nut.
These are neutral wires.
You must connect another short piece of insulated wire to these neutral wires and run that wire to silver screw.
The neutral wire will complete circuit to receptacle.
If you do not have neutral wire, then receptacle will not work in that box without additional wiring.
Hook up neutral wire to silver screw.
Now turn on power and click switch again.
If circuit breaker trips, then reverse your red and black wires.
Otherwise this should be correct wiring.
Dec 08, 2010 | Cooper Industries Cooper Wiring 274W...
Wiring diagrams for clarion dxz535 car stereo
Here's how it goes:
Speaker wires:
grey=right front pos.
grey/black=right front neg.
white=left front pos.
white/black=left front neg.
violet=right rear pos.
violet/black=right rear neg.
green=left rear pos.
green/black=left rear neg.
red=12 volt switched power source
yellow=12 volt constant power source (direct to battery)
black=chassis ground
orange/white=illumination (switched source,not to head light switch)
blue/white=amp turn on lead (to remote turn on lead of amp)
blue=auto antenna (switched power source)
brown=phone mute lead (to cell phone mute lead)
RCA connector leads:
grey lead:
red=right front
white=left front
black lead:
red=right rear/right rear subwoofer
white=left rear/left rear subwoofer
(connect to external amp)
red lead:
red=right aux input
white=left aux input
(connect to external unit)
green lead:
red=right dual zone output
white=left dual zone output
(connect to wireless head phones)
That should be all there is. on the yellow that goes direct to the battery you need to use an inline fuse holder with 30 amp fuse.
Sep 26, 2010 | Car Audio & Video
I am trying to replace a two wire light switch(both white) with a leviton photoelectric 3 wire motion activated light control(red, black and green). I am trying to determine which wire goes to which?
one of the white wires has power on it constantly....that wire connects to the black wire of the leviton.......the other white wire which has no power to it is going to whatever needs power so that wire connects to the red wire of the leviton....the green wire connects to the metal box where your mounting the leviton.
Feb 08, 2010 | Leviton Decora Light Dimmer Switch
My ps3 it goes green beeps twice then goes red and flashes on/off
you might be holding the power on button to long. you hold the power on button until it beeps to reset the video output. try turning it on by using your controller. just press the ps3 button and if the red light is on then it should come on.
Oct 14, 2009 | Sony Playstation 3 (PS3) Console
How can I wire fluorescent tube light.There's 2 cables incoming through the wall.One has red,black and green/yellow.Other has red and black only.I've tried connecting both reds from the incoming cables to...
if you have 1 switch ! take the cabel wiv the yellow red black an green conect green to E earth , conect the to reds together that will feed the switch connect the black to the nutral on the light fiting and tape up the yellow not needed !,then take the cabel wiv only red and black , the red is connected to the other red as explaind above ,then the black is the return from the switch therfor connect it to the live tuminal on the light fiting MAKE SURE U TURN IT OFF AT THE FUSE BORD FIRST PLEASE!!!!!!!!!!!
Sep 29, 2009 | Hydrofarm Hydrorfarm Flco200d Fluorescent...
Televison & Video Logo
117 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
