How to change the bearings in a washing machine hotpoint model no wma40s thank you
  • Washing Mach... Master
  • 17,130 Answers
Please mention if the bearings are in the drum, If so the assembly must be mechanically removed with the pulley out of the shaft and the fittings removed with the mount of the bearings.
Once the agitator is removed fromt he top and the pulley from the bottom, the shaft will come off and the bearings can be pushed out with the same size fitting to the bearing outer..might need pressure or a slight tap to move it out.
All of this only if you have a confirmed bearing which is faulty with a good indication.
Posted on Oct 07, 2010
How do I change the door seal on my Hotpoint WMA40 washing machine
Best to watch this video on youtube which explains it in detail
May 14, 2014 | Hotpoint WMA40 Front Load Washer
How do i replace drum berings on a hotpoint wma40,and aprox.cost thank you
the bearings are about $20,the lip-seal to protect the bearings from water is about $45,and if you hire it done you need to find out the labor rates in your area,it can take from 2-7 hours to complete depending on how hard the old water soaked and rusted bearings come out of the bore
May 02, 2010 | Hotpoint WMA40 Front Load Washer
How Do you take the top off the Washing Machine Hotpoint WMA40
you need to remove the screws at the kick panel on the lower front panel by the floor, then the top cover screws are under top cover inside machine remove these and top will lift up
Dec 24, 2009 | Hotpoint WMA40 Front Load Washer
Hotpoint WMA40 washing machine is leaking from detergent drawer- any suggestions ? Thanks
Hotpoint WMA40 washing machine is leaking This video will show you how to find that leak on any front loading washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Nov 27, 2009 | Hotpoint WMA40 Front Load Washer
Hotpoint washer
common problems with timer which work like a clock and goes though the cycle, bad timer will cause it not to go through its cycle. it very cheap and easy to replace everything is all plug in.
Nov 14, 2009 | Hotpoint WMA40 Front Load Washer
Brocken door spring
If you have not rectified your problem, you need to seperate the 2 door halves by removing all screws securing the 2 halves, and prize`appart, then you can easily change the spring.
Please rate my solution.
Thanks.
Oct 05, 2009 | Hotpoint WMA40 Front Load Washer
How do I change the door seal on my Hotpoint WMA40 washing machine?
It's a push fit seal. Carefully remove the old one and for help, smear the new seal where it fits the machine and just push it into place securely.
Sep 07, 2009 | Hotpoint WMA40 Front Load Washer
Hello i have a hotpoint wma40 the machine will go
Hi, i have a wma40s had it for 7 ears now same thing happended would start a cycle but then stop halfway through make the noise but the drum would not spin etc. i bought some carbon brushes of ebay for 7 quid and it works better than its worked in years bit nosiey for first few washes but after it settles it is as good as new.
Jul 06, 2009 | Hotpoint WMA40 Front Load Washer
Hotpoint wma40 door seal
The black grime is mold. Once it is set into the rubber it is nearly impossible to remove. Bleach would have been my suggestion but since you've already tried that, replacing the bellows (door seal) is your next option. In the future, when the machine is not in use try keeping the door slightly open for any standing moisture to evaporate.
Feb 19, 2009 | Hotpoint WMA40 Front Load Washer
Washing Machines Logo
124 people viewed this question
Top Washing Machines Experts
