Question about Hotpoint Ultima WF860 Front Load Washer
My hotpoint bwd129 is stuck on superwash, any idea's how i can get it on to a quick wash
  • 1314 Answers
SOURCE: Hotpoint bwd129
o k find the acess panel in the front or back then follow this procudure most likely there is something jamming the pump look on the back and you might see an access panel remove it and you will see a large hose coming down from the tub.Now the washer will still be full of water.There are three ways to deal with this the best way is to get a shop vac.remove the drain hose from the stand pipe and vac the water out,the second is to get a pair of radiator hose clamps from the auto parts store and clamp the large hose as close to the tub as possible ,the third is you can get a bucket remove the drain hose from the stand pipe and getting as close to the floor as possible let the water drain in the bucket .after that put some towels around the pump.Remove the clamp and slide the large Rubber boot off the pump look in the pump for foreign objects jamming the impeller blades and for broken blades if broken replace the pump.feel in the boot for same as pump .Then reassemble if nothing found then go check drain hose.
Posted on Jan 17, 2008
  • 90 Answers
I'm not familiar with this machine with out a picture, but does it have a control knob that would allow you to advance through the cycles? If so you should be able to go to a spin cycle and empty the unit. How long did you leave it unplugged? Sometimes it requires several minutes to loose its memory. If not you may need to empty the water manually as it may be a fail safe to keep you from getting the floor all wet. Take a bucket and lift the drain hose out of the house drain pipe and lower it into the bucket to empty. It may take several trips. This will not work unless the hose comes out of the bottom of the machine which I think yours does. Once empty try plugging the unit back in and see if that helps. If not the main control processor may have taken a voltage spike and has suffered irreversable damage and will need to be replaced. Please give me more info..
Posted on Feb 03, 2008
Had this same problem on BWD129, had a tech in and there is generally only one cause. Something stuck in the impeller (pump) in our case it was a shirt collar insert but is normally coins. If the machine makes any noise on the spin, this is likely the cause too (but it hasn't jammed.. yet)
Look at the front of the machine. In the bottom right corner there is a black cover.
Tilt the machine backwards so any water would run to the back of the machine.
Put a bowl under the filter cover and use a pair of pliars (other sites had said they use a special tool so I hadn't done it) to remove the cover slowly.
Remove cover & filter, check inside and remove the blockage.
This is a no fault found tech call and will set you back £106 + VAT.
Posted on Sep 22, 2008
barkencoa
  • 3463 Answers
SOURCE: hotpoint bwd129 how can i open the filter at
If you have located the fliter, then grasp the filter cover, and twist and turn to the left to remove the filter
Please rate my solution.
Thanks.
Posted on Jul 21, 2009
SOURCE: Hotpoint bwd129 washer dryer won't dry my clothes.
my Hotpoint dry will not dry my clothes. It will run for hours and the clothes still haven't dry just felt hot.
Posted on Jul 23, 2009
I have a Hotpoint BWM129 washing machine and the Delay start and Superwash lights are flashing. Can anyone explain what fault code this is? The door locked light is also on.
Manual says to unplug maching from wall for at least 40 seconds to a minute. This will reset the unit. If that does not work you will need to call a service tech.
Jan 30, 2015 | Hotpoint Bwd12, Bwd129, Bwm129 Washing...
Hi, filter grip on my hotpoint bwd129 has snapped off trying to open it. Any ideas how I can now get it off? The machine was not spinning properly & started to smell awful. Thanks
You where headed in the right direction-something is stuck and is burning up the belt-check appaliance pro on line for filter lid-then drill it and drive a striaght blade screw driver into it cheers Denny
Oct 15, 2013 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint bwd 129 leaking from underneath (left side when looking at the machine) - i have checked the plugs at the back - all okay.
Hotpoint bwd 129 leaking from underneath This video will show you how to find that leak on any front loading washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Apr 08, 2010 | Washing Machines
I have a Hotpoint BWd129 washer/dryer. When I
I have a similar Hotpoint model to this, that does something very similar now and again, usually when trying to set a delayed start.
The only way I have found to "fix" it is to turn the machine off for at least 5 minutes, and then try again.
Hope this helps.
Jan 13, 2010 | Zanussi WJD1257W Front Load Washer
We have a washer dryer hotpoint bwd129. Can you
a washer dryer has a different approach to cleaning fluff. It has an internal flushing system.. only do routine check on pump filter.
Oct 15, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint bwd129 how can i open the filter at
Thanks.
Jul 21, 2009 | Washing Machines
Hotpoint BWD129 stuck in rinse phase
Problem was caused by a faulty water temperature sensor. The clue was that the owner reported increasingly hot washes, then the machine stuck at rinse. A test resistor replacing the sensor allowed the cycle to finish. A replacement sensor is on order.
Jan 10, 2009 | Hotpoint Ultima WF860 Front Load Washer
HOTPOINT BWD129
Please provide more details about your appliance. What brand and the age.
Nov 06, 2008 | Hotpoint WD52 Front Load Washer / Dryer
Oct 05, 2008 | Washing Machines
Hotpoint Ultima WF860 Front Load Washer Logo
63 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
